Revolt RV-series motor review and comparisons
fechter   100 GW
Re: Revolt RV-series motor review and comparisons
Post by fechter » Mar 21 2019 2:49pm
Super Loctite was sort of joke. They do make many different flavors though. I used some green "wicking grade" stuff that was almost like welding the parts together. I don't remember the number. It was more like super glue.
Yes, any kind of anaerobic locking fluid doesn't work well if there is much clearance to start with. Epoxy might work.
Another option would be some kind of clamping arrangement like a Taper-lock bushing. If the parts are held together tightly enough, the whole shaft would shear off first.
larsb   1 MW
Post by larsb » Mar 21 2019 2:57pm
I've used the loctite retaining compounds:
https://www.henkel-adhesives.com/us/en/ ... ounds.html
worked well to fit loose shaft to bearing in that application
Ride on!
fechter   100 GW
Post by fechter » Mar 21 2019 2:59pm
larsb wrote:
Mar 21 2019 2:57pm
Which one? There are many.
larsb   1 MW
Post by larsb » Mar 21 2019 3:20pm
sorry, i need to look for it in my garage...
it was loctite 648
Ride on!
ElectricGod   1 GW
1 GW
Post by ElectricGod » Mar 21 2019 3:58pm
dead thread
XB-502: viewtopic.php?f=10&t=83302&p=1222730#p1222730
Currie scooter: viewtopic.php?f=35&t=83830&p=1227407#p1227407
Benjamin Franklin - "Any fool can criticize, condemn and complain and most fools do."
madin88   1 GW
1 GW
Post by madin88 » Mar 21 2019 4:20pm
As already mentiond, it is the Loctite 648 which should be used for that.
The feather key should be up to the task for what the motor is capeable to deliver to the shaft, but i agree that it is a little bit undersized.
btw: it is the torque which will shear off the key and not the power! :wink:
liveforphysics   100 GW
Post by liveforphysics » Mar 21 2019 4:52pm
madin88 wrote:
Mar 21 2019 4:20pm
You would be correct for static situations of a powertrain loading, like climbing a smooth flat hill. In practice, the torque the motor delivers is largely irrelevant to the peak loads a powertrain experiences. This is because the inertial loading when the wheel leaves the ground and freely spins up, and then re-contacts the ground again can easily be 50x or more of the peak loads seen by electromagnetic generated torque forces.
ElectricGod   1 GW
1 GW
Post by ElectricGod » Mar 21 2019 5:43pm
dead thread
ElectricGod   1 GW
1 GW
Post by ElectricGod » Mar 21 2019 5:54pm
dead thread
Post by liveforphysics » Mar 22 2019 1:47am
Shock loads from impacts, even potholes hit by the tamest of riders put so much higher loads on the powertrain than propulsion torque loads, you don't design a powertrain around the torque loads at all, but the shock loads.
Punx0r   100 GW
Post by Punx0r » Mar 22 2019 3:21am
I've not seen someone put a figure on drivetrain shock load Vs. steady state before so thanks for that :thumb:
madin88   1 GW
1 GW
Post by madin88 » Mar 22 2019 7:24am
liveforphysics wrote:
Mar 22 2019 1:47am
Do you think that size of the drive sprockets or pulleys would have an influence on the shock loads (the feather key sees)?
If we take for example a drive train with 1:5 reduction. one with 10/50T and the other one 20/100T. Same type of chain or belt.
ElectricGod wrote:
Mar 21 2019 5:43pm
Undersized...lol...can you present a motor that a typical EV builder such as myself would use that isn't undersized in the keyways or union between bell and shaft?
On my Neu 8057 the shaft is attached to the bell with 6xM5 bolts and inherently glued with loctite:
fechter   100 GW
Post by fechter » Mar 22 2019 8:16am
madin88 wrote:
Mar 22 2019 7:24am
I'm sure that has some effect. With smaller sprockets, the chain or belt can absorb more of the shock. It might just mean your chain or belt breaks before the motor shaft.
Speaking of which, on some motorcycles they use a rubber buffer between the sprocket and the hub to reduce the shock loading. Some of these are pretty simple. The sprocket floats on the axle and engages the hub with rubber covered pegs. If you have serious shock load, these things will help a lot.
ElectricGod   1 GW
1 GW
Post by ElectricGod » Mar 22 2019 10:33am
dead thread
larsb   1 MW
Post by larsb » Mar 22 2019 3:03pm
LFP quote:
I never had any issues with keys failing even though i see the point above, for the RV120 motors i am sure the grip fit on axle vs bell did a good job. Before that i used freewheel so no shock loads like described could transfer through to the motor key.
It wouldn't be too hard to do an ok calculation on the forces that can result from the shock loads.
Ride on!
ElectricGod   1 GW
1 GW
Post by ElectricGod » Mar 24 2019 2:00am
dead thread
ElectricGod   1 GW
1 GW
RV-100E stuff
Post by ElectricGod » Mar 24 2019 2:38am
dead thread
ElectricGod   1 GW
1 GW
Post by ElectricGod » Mar 28 2019 1:29am
dead thread
ElectricGod   1 GW
1 GW
Revolt RV-120-regular
Post by ElectricGod » Mar 31 2019 11:21pm
dead thread
ElectricGod   1 GW
1 GW
Revolt RV-100E bell to shaft reinforcing
Post by ElectricGod » Apr 07 2019 7:50pm
dead thread
ElectricGod   1 GW
1 GW
Post by ElectricGod » Apr 14 2019 11:12pm
dead thread
ElectricGod   1 GW
1 GW
Revolt RV-100E shaft to bell reinforcing
Post by ElectricGod » Apr 16 2019 11:00am
dead thread
drc   100 mW
Post by drc » Apr 16 2019 12:48pm
Look like you have worked very very hard on these motors EG. You should build your own motor from scratch! Are you going to test the RV100s on an EV to do a practical comparison?
ElectricGod   1 GW
1 GW
Post by ElectricGod » Apr 16 2019 3:23pm
dead thread
ElectricGod   1 GW
1 GW
Revolt RV-100E shaft modding
Post by ElectricGod » Apr 17 2019 2:17am
dead thread
