QS 3000w midmotor
PITMIX   100 W
Re: QS 3000w midmotor
Post by PITMIX » Jan 16 2020 2:24pm
Yes Speed 1 without Fw.
Speed 2 with Fw.
Speed 3 with Fw.
The engine runs empty without any transmission.
Aixam 550 Twin retrophite Qs 138 70H, Thermo-Nucular electronics 24F, LG Chem 20s 60Ah
PITMIX   100 W
Post by PITMIX » Jan 17 2020 12:25pm
Hi, I installed a temperature sensor on the motor winding. I disassembled the front flange and passed the probe through the silicone right next to the wire for the hall sensors. Then I fixed the probe with a plastic collar on the winding. There is plenty of space on this side of the engine, it's very easy to do. Don't hesitate to add a probe to your engine.
twikis   10 mW
Post by twikis » Jan 17 2020 8:49pm
Interesting. To get faster and more accurate readings (mounted like this, the reading will always be at least a few degrees under the actual copper temp when the motor gets hot), I'd glue it to the windings with a blob of any (high temp) 2 component glue, + maybe remove the rubber cap if possible.
Also, unless you used high temp zip ties, I'd really keep the temperature below 80-100C now...
Thanks for the pic of the ingredients!
edit: The airgap seems to be quite narrow, that's nice
twikis   10 mW
Post by twikis » Jan 17 2020 10:18pm
Ok here's one more question: Has anybody done a (more or less) direct comparison between running this motor with an IPM optimized (e.g. Votol, ASI, maybe Nucular, haven't found any concrete info) controller, that shifts the field around to utilize the extra torque-per-amp (and thereby efficiency and power) archieved by the reluctance, and non-optimized, standard SPM controller like a Kelly KLS?
Comparing the no load consumption is probably the most accurate value to get, short of putting both setups on a dyno...
larsb   1 MW
Post by larsb » Jan 18 2020 2:01am
None of those controllers are IPM capable or have MTPA algorithm for IPM motors, it requires dynamic phase angle adjustment to the specific motor. APT96600 might work but the field weakening setting in my controller did not work so i can’t be sure.
A noload would not answer this question either, has to be multiple dyno runs to get optimised phase angle for each rpm.
The low difference in inductance on rotation angle shows also that this motor will not have large benefit from the IPM design - it’s basicly comparable to a spm motor.
Ride on!
Overclocker   10 kW
Post by Overclocker » Jan 18 2020 2:38am
i'm planning to get the 2000w version (qs 120). i have a Kelly KLS7230 lying around...
now i'm wondering if it would be better to get the Votol also
just wanna confirm if Kelly KLS is compatible w/ these motors. i'm not really interested in getting ultimate optimization. i just wanna know if KLS will do a decent enough job
larsb   1 MW
Post by larsb » Jan 18 2020 3:42am
Hope someone has tried it already and can answer. I don’t regard kellys as good in any regard so therefore the votol (to me) is the obvious choice.
But if you have one lying around then why not try it, should work well enough.
Ride on!
PITMIX   100 W
Post by PITMIX » Jan 18 2020 4:07am
Nucular 24F is the best
Bartosh   100 W
Post by Bartosh » Jan 18 2020 4:50am
larsb wrote:
Jan 18 2020 2:01am
Can you shed some more light on that? Links to sources appreciated.
I've also been trying to make the fw work on the apt. It's the only controller I know where you can set the Id in a rpm-based manner. No success by now, but I will get back to it.
FYI phase to phase inductance of my 138 70h: 56.3, 55.7, 57.0 uH.
larsb   1 MW
Post by larsb » Jan 18 2020 6:46am
Try to find the largest difference max-min on the rotation of the rotor. It’s not much and can be related to the possible reluctance torque (if i remember it correctly.) A link to this is already in this thread i believe.
Ride on!
twikis   10 mW
Post by twikis » Jan 18 2020 12:43pm
larsb wrote:
Jan 18 2020 2:01am
Oh wow okay, basically I just guessed those controllers would try to find out the optimal angles during initialization, since I thought there wouldn't be much to it (spin it up slowly, while it's spinning up play around with phase angle to find out the lowest consumption at e.g. 10 rpm-points, generate a curve a out of that, then later during normal operation do slight adjustments, easy)
Of course that's just my theory, most definitely likely underestimating it ha
madin88   1 GW
1 GW
Post by madin88 » Jan 19 2020 9:45am
twikis wrote:
Jan 17 2020 8:49pm
Yep thats good for torque, but not so good for iron losses.
larsb wrote:
Jan 16 2020 11:31am
It’s at 12.5A / 72V on my motor, don’t know exact voltage when i tried it.
kv60 without flux
Thats around 900W which i find is a bit on the high side for ~4000RPM on a motor like this.
larsb   1 MW
Post by larsb » Jan 19 2020 9:49am
Yes, i agree, think it might be with field weakening and 6000rpm. Can’t remember :wink:
Ride on!
twikis   10 mW
Post by twikis » Jan 19 2020 10:22am
madin88 wrote:
Jan 19 2020 9:45am
twikis wrote:
Jan 17 2020 8:49pm
larsb wrote:
Jan 16 2020 11:31am
kv60 without flux
If it's high or not, mostly depends on the internal resistance (which the important number I haven't found yet). Judging by the numbers I've seen, it could be as low as 5-7 milliohm, so not to bad actually
larsb   1 MW
Post by larsb » Jan 19 2020 10:45am
It’s 5mohm.
Ride on!
twikis   10 mW
Post by twikis » Jan 19 2020 11:09am
Well when subtracting the 1 mOhm of the 1m 16mm² phase cable off of that, you get 4 mOhm internal resistance.
At e.g. 500A that's only 1000W copper loss, which is great!
Also means though, that this motor simply is wayy to big for my 50 km/h Cityel, and I'll get the 120 2kW for it (hoping that it's got an internal resistance of ~10mOhm)
Edit: forgot factoring in that it's a star connected motor lol.
So actually the copper losses are I² * phase-to-phase-resistance / 2 * root3, which for 500A would be:
500²*0,004/2*1.73=865W
even better
HCx   100 µW
100 µW
Post by HCx » Jan 24 2020 1:48pm
Looking to purchase one of these for converting my MotoPed.
Planning to pair this motor with a Nucular 24F and a 20S10P pack (limited to ~70A) with the expectation of building a 200A+ capable pack down the line.
Anyway, Where are people in the US finding the best pricing on this motor with a sprocket drive? I've seen it listed on Aliexpress, Alibaba and cnqsmotor and i'm not sure if there is some other trustworthy source I have yet to find.
Also. Are more detailed 2D drawings (or better yet CAD) available for this motor? I've seen some blurry 2D drawings but they're missing critical dimensions like where the bolt holes are located in this photo Image
Or where the sprocket sits in relation to the rest of the motor.
AviatorTrainman   10 mW
Post by AviatorTrainman » Jan 25 2020 11:41am
I’ve made a rough cad model of the motor in fusion if you’d like me to export it, or I could post a screenshot of the dimensioned end sketch. I don’t remember where I found the image i worked from, but it had enough dimensions that I was able to calibrate and work from it. I was able to 3d print a prototype motor mount using what I have, so I know it’s at least accurate enough for that. As for the sprocket, the model doesn’t show the shaft accurately, but I’ll send pictures with dimensions in a bit.
With regards to where to buy it, I found aliexpress to have the same prices as the official QS website, and then you don’t have to go through the hassle of placing an order by email. If you put a comment on the order or message them with your order number right after placing it, they’ll send it with any size sprocket you request.
macribs   1.21 GW
1.21 GW
Post by macribs » Jan 25 2020 5:41pm
Stevebequik wrote:
Dec 02 2019 5:07pm
Finally got my build up and running.
Full size KTM 250 exc, QS3000, Nucular 24f. 18s 3kw Chevy volt.
Vas needs to build a 36f with 750 phase amps.
First I think that you got a sweet ride. Got a build thread planned?
Second, iirc vas already got plans for a 36f. But that nuc thread has grown big so you got to check it, or maybe just stop by his thread and ask when it will be ready or if he is still planning a 36f release. He is always working hard to improve and develop new cool stuff.
HCx   100 µW
100 µW
Post by HCx » Jan 25 2020 8:15pm
AviatorTrainman wrote:
Jan 25 2020 11:41am
Whichever is easier for you. I was planning on posting .stp files of the motor once I got mine in or found trustworthy drawings to work from.
thanks boss.
HCx   100 µW
100 µW
Post by HCx » Jan 25 2020 10:41pm
If anyone is able to provide me with accurate measurements for the sprocket offset from the mounting flange I can complete this model and release it for anyone else trying to figure out how to jam this thing into their project.
Post by AviatorTrainman » Jan 26 2020 11:29am
Your model looks significantly more accurate than mine, so I won’t bother to upload mine unless people want me to, but some (non-mounting) features are just flat out wrong on mine.
See the picture attached to see what I mean here: the center line of the 7mm thick sprocket sits 16.5 millimetres from the small circular area around the driveshaft. This small circular area is flush with the mounting area around the outside, where I have that 3d printed mock-up bolted on. The mounting holes are a metric 7 with a 1.0 thread, in case that’s not clear from the material you’re working from. It certainly wasn’t for me. The area where the lock ring/circlip goes is maybe a millimetre out from the sprocket outside face, so it might be possible to space out the sprocket just a little bit.
Haggan90   1 µW
Post by Haggan90 » Jan 27 2020 5:33am
Has anyone tried this motor with the Silixcon SL controller?
I wonder how much you could get out of it with this controller..
https://silixcon.com/product/esc3-sl-controller/
VasiliSk   1 kW
Post by VasiliSk » Jan 31 2020 3:48am
For those who will try to remove pulley with minimum tools:
Make two holes with thread M6 at some angle so axle will be not touched, tighten screws against axle using some plate, and heat up quickly belt side of pulley (spin it), it should pop out
HCx   100 µW
100 µW
Post by HCx » Jan 31 2020 1:44pm
A steering wheel puller from autozone or your local parts store will get the job done as well.
most auto parts places do tool rentals for free/cheap with a small part deposit.
