portable air compressors for tires
alsmith   100 kW
Post by alsmith » Jan 01 2018 10:12pm
There are lots of cheap portable 12V portable compressors for lowing up tires, and there are even a few for 48V - 60V. What's the difference that makes them suitable for the higher voltage- is it just a series resistor? Reason is I generally run at 36V so would like to convert a 12V to run on a 36V battery. I'm guessing that a 48V would struggle/stall on 36V here ut since the prices aren't a very big jump from the 12V ones they can't be adding or changing much internally.
amberwolf   100 GW
Re: portable air compressors for tires
Post by amberwolf » Jan 01 2018 11:36pm
Like other motors, it depends on teh motor winding (or if it has an internal speed controller or voltage converter that runs a 12v motor on a higher voltage). Most likely they're simply using a motor wound for the voltage they sell it for.
If you run a lower voltage motor on a higher voltage it'll spin faster, but if it has enough of a load on it (like a compressor might) it'll have a lot more current flowing thru it, and heat up a lot faster, so the motor could overheat and burn out.
The higher speed could break mechanical bits of the compressor, too. (lots of these things are plastic or cheap die-cast potmetal).
There's a number of threads about various compressors and projects that may help you
https://endless-sphere.com/forums/searc ... mit=Search
There's probably more, but those were quick easy searches. ;)
LewTwo   100 kW
Post by LewTwo » Jan 02 2018 7:19pm
or you could just choose the compressor you want and use a voltage converter:
https://endless-sphere.com/forums/viewt ... =2&t=90369
The advantage of a 12 Volt is that you can steal power from a four wheeler in needed :D
The more I learn the more obvious the immensity of my ignorance becomes.
Weight Wennie E-Bike https://endless-sphere.com/forums/viewt ... 3#p1173723
Shaft Drive Grocery Getter https://endless-sphere.com/forums/viewt ... =6&t=90718
...and thanks to Justin!
MrDude_1   100 kW
Post by MrDude_1 » Jan 02 2018 11:01pm
just so you dont have to try... a 12v automotive compressor connected to 36v will burn up before your tire is full. :lol:
Warning:This post is being read via light, a substance known to the state of California to cause cancer.
Chalo   100 GW
Post by Chalo » Jan 02 2018 11:54pm
Not everything needs e-assist.
dogman dan   100 GW
Post by dogman dan » Jan 03 2018 11:01am
https://www.ebay.com/i/253237165814?chn=ps
This is the one I'm in love with. NOT cheap, but at the black Friday sale it can be. Useless of course, if you don't already have the Ryobi drill, and have the battery and charger.
A bit bulky to carry, but when you know you are heading out with a leaker, and need to keep pumping despite the slime, it sure beats a tiny hand pump. Easier to carry than a large hand pump, but it still fills a pannier or rack bag, so not that convenient in size.
CO2 rig for small size and ease.
fechter   100 GW
Post by fechter » Jan 03 2018 8:29pm
I have a 48v compressor that works great off my 52v bike battery. It's just like the 12v versions but the motor is wound with way more turns of skinnier wire to make it 48v. It draws less than 2A running.
wturber   10 MW
Post by wturber » Jan 03 2018 9:27pm
Chalo wrote:
Jan 02 2018 11:54pm
Completely agree. Part of the reason for riding is the exercise. Even my short stroke mini frame pump lets me pump up a 26x2 tire in just a couple minutes. It weighs almost nothing and deploys quickly. And because it mounts to the frame, it leaves room in my backpack for my electric scissors. :P
"Commuter - DC Booster"
viewtopic.php?f=2&t=90369
dogman dan   100 GW
Post by dogman dan » Jan 04 2018 9:11am
Bear in mind I'm handicapped. Its not just because I'm lazy that I want an electric pump with me when I know the tire is a leaker. By the time I get a tire hand pumped I'm trashed. Chronic fatigue syndrome is no joke.
But on a daily basis, not riding a bike known to go flat in a few miles, I just carry a tiny hand pump. Double slime and thick tubes usually do me ok until you hit a big nail or screw. But sometimes that works good enough that I put off replacing a tube with a bit too big a hole in it for slime, and just want to go to the store or whatever. Then I carry the Ryobi. I take it on any kind of car road trip too.
At home, I have a regular compressor, that I use to keep the 30 or more pneumatic tires on my property full. But that Ryobi, its nice to pump up a wheelbarrow or bike where it is, vs rolling it on a flat to the garage to fill it.
Cool 48v mini compressor. One of those would be great for e bikes.
fechter   100 GW
Post by fechter » Jan 04 2018 9:18am
When I got my fat bike, I quickly figured out that if I got a flat on the trail and only had a little hand pump, I'd be there for an hour pumping the thing up.
I took my compressor and cut away part of the housing to make it small enough to easily fit in my bike bag (along with the tire levers, patches and basic tools).
48V air compressor.jpg (54.29 KiB) Viewed 3038 times
ferret   1 kW
Post by ferret » Jan 04 2018 10:38am
Don't believe everything you think.
Cove GNG-Spot build thread
Astral Rune build thread
macribs   1.21 GW
1.21 GW
Post by macribs » Jan 04 2018 7:56pm
Or what about this one and a few spare cans in your pockets?
wturber   10 MW
Post by wturber » Jan 04 2018 9:38pm
dogman dan wrote:
Jan 04 2018 9:11am
Of course. If someone isn't able to operate a hand pump effectively, then it isn't a reasonable option. I'm betting there are some disabled folks out there who consider electric scissors to be just short of a godsend as well.
Raisedeyebrows   1 kW
Post by Raisedeyebrows » Jan 05 2018 2:37am
dogman dan wrote:
Jan 03 2018 11:01am
Ah yes, saw that and since I have a Ryobi drill and 2 18V batteries I went ahead and ordered one $29.00 free shipping on Amazon. Bought a 12V one at St. Vinnies a while back for $7.00 which turned out to not work and getting tired of mooching fill ups for my air tank from my neighbor across the street off his compressor. Thanks for posting that, it ought to be good for keeping the tires on the 15 two wheeled vehicles in my garage pumped up (wife pointed that number out a few days ago). Hand/foot pumps work fine but aren't as much fun.
Yuba Mundo w/BBSHD
Specialized Hard Rock w/9c clone, statoraid, hubsink
Trek Fuel 90 w/BBSHD
Above all run on 14s4p 52v li-ion
Ecobike folder 36v
Currie Flyer scooter 24v on 24ah of SLA
Every trip made with electric bike is one less car trip, saves money, no toxic fumes, less noise, less impact on roads.
docnjoj   100 GW
Post by docnjoj » Jan 05 2018 9:04am
Black and Decker have an inflator also for their "multi tools" (basically a 20 volt lithium drill) for about $25. Prolly not quite as good as the Ryobi but similar and cheaper, particularly if you use their tools anyway.
otherDoc.
E-bike stable at our house
Steintrike Mad Max full suspension trike rear Cute 100H going on: Whoops, Cute wheel broke but I fixed it.
Sun USX delta trike EbikeKit small geared front wheel sort of front suspension for wife
Agniusm/A123 AMP 20 36 volts on the Steini has been taken off.
2x16000 Multisport from HK now gone as they died after 2 years
New Luna 10S bottle battery 13.6AH now on mine
Relatively New 10S4Px2 for wife's bike giving 20ah @ 40 volts home made Panasonic from Tumich. BMS's rule.
dogman dan   100 GW
Post by dogman dan » Jan 05 2018 9:31am
B&D is good too I'm sure. I just went Ryobi for my drills and stuff a few years back, when they discontinued the 24v B&D NiCad stuff.
All I can say is the Ryobi lasted me a year before my garage burned. Used it a lot. Got another about 9 months ago, and its still fine even after doing quite a bit of car tires before I got a new big compressor.
CO2 rig still the best for small size though. I just found the cans a bit pricy, for riding around through as many thorns as I do on the dirt bikes. If I can make it back to home or car, I get to skip the pumping with the tiny pump.
Raisedeyebrows   1 kW
Post by Raisedeyebrows » Jan 06 2018 2:00am
I have high hopes for the Ryobi, obviously it's going to be too big to carry in panniers but for home use it ought to be useful. Wife got me the drill/2 battery set a couple years ago, it's proved to be a pretty good tool, I've put it through hell, built a small house with it, a lot of use building guitar speaker cabinets and other assorted uses, liked it so well I ended up buying a Ryobi chop saw when my Makita finally became so sloppy it was basically unusable.
Gonna have to get a few C02 cartridges before spring when I start Mountain Biking more again, I have a couple of the little cheaply Bell handpumps I've been carrying for years along with spare tubes but they really take a lot of effort to get much pressure in a tire.
Yuba Mundo w/BBSHD
Ecobike folder 36v
alsmith   100 kW
Post by alsmith » Jan 09 2018 4:03pm
dogman dan wrote:
Jan 03 2018 11:01am
As is happens I have a ryobi drill and two of the batteries, I'd already looked at this unit but with UK duty and shipping its a bit expensive. Next big lottery win though...
And really it was something I could carry on the bike for emergencies I wanted, not frequent use. I got one of those (cheaper) drill shaped rechargeable air pumps for home use and it's over 5 years old now. It has nicd batteries though and they have been replaced once as the originals started leaking. The ebay supply sent NiMH not the NiCd's I'd ordered and I ended up using them. Not as good as the NiCds but then I'm using the NiCd charger and it was only ever meant as a short term answer.
alsmith   100 kW
Post by alsmith » Feb 11 2018 10:21pm
if anyone is interested there's a 48 - 60V portable compressor at banggood- 8.44 UK pounds delivered so that must be under $12. There's only a few left so if you're interested move fast. (I've looked at banggood a few times but not previously bought from them).
fechter   100 GW
Post by fechter » Feb 12 2018 12:40am
alsmith wrote:
Feb 11 2018 10:21pm
That looks pretty similar to the one I got. I've been real impressed with mine so far. Since I have a fat bike, it beats carrying a dozen CO2 cartridges.
tomjasz   10 GW
Post by tomjasz » Feb 12 2018 3:30am
I’m big on Banggood and generally pleased with their stuff. At $11.34USD I don’t expect it’ll take much of a beating but I seldom need a pump. I’m taking a flyer and going for one, last one i 5ook from the case, and cleaned up wiring and made it an even smaller package.
I have never ordered from them during this major holiday...I’d expect unusually long delays, typical was 2 weeks during non holiday periods.
ARGH! Under restocking. It will be available soon.
I went with the 48v black on Banggood from a 99.9% rated seller on eBay. $27.
Hooping it’s like this picture for case stripping.
Most desirable
Ok too
fechter   100 GW
Post by fechter » Feb 12 2018 9:33am
Here's what mine looked like inside before I cut down the case:
Tire Pump insides.jpg (47.92 KiB) Viewed 2536 times
dilkes   100 W
Post by dilkes » Feb 12 2018 9:56am
I ordered one.
When you "cut down the case" or did "case stripping", what did you put the guts into?
tomjasz   10 GW
Post by tomjasz » Feb 12 2018 2:39pm
dilkes wrote:
Feb 12 2018 9:56am
I ordered one.
I store mine in a nylon bag.
tomjasz   10 GW
Post by tomjasz » Feb 12 2018 2:42pm
fechter wrote:
Feb 12 2018 9:33am
Thanks, how much case did you remove? Any chance of a picture? Always up for one of your project photos! THANKS!
