new cyclone 3000 w mid-drive kit?
Tommm   10 kW
Re: new cyclone 3000 w mid-drive kit?
Post by Tommm » Oct 12 2019 3:18pm
joshuahuang wrote:
Oct 12 2019 2:18pm
Anyone know how to fix the throttle? I have the stock non bluetooth 40a controller and the throttle response is terrible because it's speed controlled not current controlled. Do I need a new throttle or is there another solution? It's manageable on road but not for steeper technical trails.
If you have the leads for the bluetooth module you can buy one on ali for $20.
https://m.aliexpress.com/item/329627 ... 11340635
Or you can try to connect/disconnect the "soft start" leads. They are two grey wires and they plug into each other.
Tbh only way I got it just right was "fast start 8, adjust accelerator curve on" and a top of the line domino throttle ($70).
robocam   10 kW
Post by robocam » Oct 12 2019 4:02pm
What throttle are you using? Maybe give it some time to get used to?
joshuahuang wrote:
Oct 12 2019 2:18pm
markz   100 GW
Post by markz » Oct 12 2019 7:36pm
I already have a threaded arm for the freewheel, but I dont want to wreck that one too :oops:
I will first try some epoxy weld with the threads on the pedal shimmed for a tight fit.
Helicoil I doubt would work but might be worth a try, if the price is right.
Then I might have to get someone with a tig/gas to weld the hole in, drill it and tap it.
joshuahuang   1 mW
Post by joshuahuang » Oct 14 2019 11:26am
robocam wrote:
Oct 12 2019 4:02pm
nah I've had it for a couple months now. I had no trouble adjusting to other throttles. It jerks really hard on startup no matter how slow i go
joshuahuang   1 mW
Post by joshuahuang » Oct 14 2019 11:29am
Tommm wrote:
Oct 12 2019 3:18pm
joshuahuang wrote:
Oct 12 2019 2:18pm
woah i didn't know stock one had bluetooth. ill see if i have the plug on the controller when i get home
endrew   10 W
Post by endrew » Oct 17 2019 5:23pm
Couple of questions regarding controllers:
1) Is there a good current based alternative to stock controller? stock controller controls speed rather than current.
2) When I try to set overspeed in stock controller, I can only set it up to 15. If I try to set it higher, It goes down to 15 after I hit "save". Why is that?
3) What is "low speed ratio"?
Thanks!
Untitled (Recovered).jpg (73.2 KiB) Viewed 2200 times
Tommm   10 kW
Post by Tommm » Oct 18 2019 2:37am
endrew wrote:
Oct 17 2019 5:23pm
Thanks!
This menu sets the speed of the "high speed mode" and "low speed mode" of the 3 speed switch. If you are in the middle speed(default state without a 3 speed switch connected), it doesn't change anything. It doesn't change max power, it is just an rpm limit. The high speed mode is just field weakening.
15% is a lot, on 72v with the 15% setting you can run into the controller's rpm limit and experience some skipping, mostly without a load.
Reguarding the throttle, the best usability is with the "adjust accelerator curve" turned on. Slow start off, and fast start on 6 to 8 depending on taste.
minimum   100 W
Post by minimum » Oct 18 2019 2:50am
endrew wrote:
Oct 17 2019 5:23pm
Nucular.
12F if you're bold and do like changing your bicycle drivetrain components.
6F is good enough to destroy weaker links and get maintenance cycle low :D
robocam   10 kW
Post by robocam » Oct 18 2019 7:55am
What controller is this? Would you happen to have a link? What software is this screenshot from?
endrew wrote:
Oct 17 2019 5:23pm
Thanks!
endrew   10 W
Post by endrew » Oct 18 2019 10:56am
minimum wrote:
Oct 18 2019 2:50am
endrew wrote:
Oct 17 2019 5:23pm
Nucular.
Do you have experience pairing it with the cyclone? Seems to be pre-order
http://nucular.tech/#rec101723173
endrew   10 W
Post by endrew » Oct 18 2019 10:57am
robocam wrote:
Oct 18 2019 7:55am
endrew wrote:
Oct 17 2019 5:23pm
Thanks!
Its the stock bluetooth controller and its app. They have it at Luna and Sick bike parts.
minimum   100 W
Post by minimum » Oct 18 2019 11:08am
endrew wrote:
Oct 18 2019 10:56am
I wouldn't have suggested it otherwise.
endrew   10 W
Post by endrew » Oct 18 2019 11:09am
Tommm wrote:
Oct 18 2019 2:37am
endrew wrote:
Oct 17 2019 5:23pm
Thanks!
Thanks!
What does "Fast start" do?
robocam   10 kW
Post by robocam » Oct 18 2019 11:21am
Thanks. That’s cool. I have 2 Cyclones from Luna Cycle but I guess it was before they had Bluetooth stock. Any idea when it started coming with a Bluetooth controller? Is it still 40A?
endrew wrote:
Oct 18 2019 10:57am
Tommm   10 kW
Post by Tommm » Oct 18 2019 4:30pm
robocam wrote:
Oct 18 2019 11:21am
endrew wrote:
Oct 18 2019 10:57am
It is an option.
You can upgrade yours like so:
viewtopic.php?f=28&t=69867&p=1503540#p1503540
endrew wrote:
Oct 18 2019 11:09am
Thanks!
It will try to accelerate faster to the requested rpm given by the throttle. More responsive. You decrease the jerkiness by doing "adjust accelerator curve" this option makes the first 25% of the rev range commanded by ~40% of your throttle movement range so you still get fine control.
robocam   10 kW
Post by robocam » Oct 18 2019 4:45pm
Do the older controllers have a place for this to plug into? I know mine don’t because I removed every wire I didn’t use :lol:
Tommm wrote:
Oct 18 2019 4:30pm
It is an option.
Tommm   10 kW
Post by Tommm » Oct 19 2019 4:22am
robocam wrote:
Oct 18 2019 4:45pm
Tommm wrote:
Oct 18 2019 4:30pm
It is an option.
It is 4/5 wires and it says bluetooth. If you removed it, you removed it.
You will need to look for internal solder points if you are interested.
robocam   10 kW
Post by robocam » Oct 19 2019 10:27am
Here are the wires I removed. Looks like the old controller did not have Bluetooth capability. So they all ship with Bluetooth capability now?
IMG_5236-20percent size.jpg (147.47 KiB) Viewed 2083 times
Tommm wrote:
Oct 19 2019 4:22am
Tommm   10 kW
Post by Tommm » Oct 19 2019 1:09pm
robocam wrote:
Oct 19 2019 10:27am
Tommm wrote:
Oct 19 2019 4:22am
No, there is a 40a silver non bt model and a 60a black bt model. They are yuyang king controllers btw.
endrew   10 W
Post by endrew » Oct 21 2019 7:52am
Anyone paired a Cyclone 3000 stock controller with a Cycle Analyst and an external shunt?
I am seeing strange behavior. The ESC will not pull the same currents as it will without the CA, even though the throttle voltage is higher with the CA.
Is it possible the throttle signal is current rather than voltage?
robocam   10 kW
Post by robocam » Oct 21 2019 10:11am
I have, and I've experienced nothing unusual.
endrew wrote:
Oct 21 2019 7:52am
endrew   10 W
Post by endrew » Oct 21 2019 11:05am
robocam wrote:
Oct 21 2019 10:11am
endrew wrote:
Oct 21 2019 7:52am
How much current do you draw? as I said, up to 40 Amps, it worked fine for me
robocam   10 kW
Post by robocam » Oct 21 2019 11:21am
The stock current of about 40A. I don't understand what you're saying. Now you're saying it works fine up to 40A but that's the stock current. Are you talking about the 60A controller? How are you measuring the current without the CA? Or are you just directly plugging in the throttle but still measuring the current with the CA? Measure the throttle output voltage of the CA.
endrew wrote:
Oct 21 2019 11:05am
endrew   10 W
Post by endrew » Oct 21 2019 11:58am
Oh, I got the Bluetooth ESC with my kit and I have added some solder to the internal shunt so it goes up to 80 amps. I want the CA for this reason - to be able to limit the current in a flexible way.
Anyway this was solved by disconnecting the gnd wire in the throttle connection from external shunt to the ESC, and leaving only the signal wire. I have no idea why.
robocam   10 kW
Post by robocam » Oct 21 2019 1:00pm
Oh, ok that makes sense. I did this to my other Cyclone 3000 controller too (soldered the shunt and let the CA limit the current). On mine I only have one wire going to the throttle input on the controller. Glad you figured it out.
endrew wrote:
Oct 21 2019 11:58am
