new cyclone 3000 w mid-drive kit?
StinkyGoalieGuy   100 W
Re: new cyclone 3000 w mid-drive kit?
Post by StinkyGoalieGuy » Jun 10 2015 2:50pm
Hey Dekes, can you measure the length from one end of the motor to the end of the freewheel? Essentially, what is the minimum required crank spacing?
lantice13   100 W
Post by lantice13 » Jun 11 2015 3:17am
yes! a video of the drive in action would be great. I suspect the jubilee clamps is not enough to restrain the motor at 2kw and up....the mounting brackets are simple enough that simple metal tools and some thick steel plates from your local hardware store can make it stronger . I also have flex on my gng gen 2 which is very similar to this cyclone kit. the tesioner is fixed which keeps the 2nd reduction from dropping. even with all the flex, never had a single drop on the 2nd reduction. as for the final drive, I only drop chains if I shift too fast on power. my solution for that is proper gear shifting. lol it's not a motorcycle gearbox.....
Megsy73   1 W
1 W
Post by Megsy73 » Jun 12 2015 4:45am
jdevo2004 wrote:I feel like this kit has a lot of potential. With the right after market parts to fix some small problems it could be great. My only worry is the gears. Are they easy to replace? Are they cheap?
Looks like AFT is working on it...http://www.aft-ebike.com/kits--pricing.html
lantice13   100 W
Post by lantice13 » Jun 12 2015 4:52am
Nice! :twisted:
emaayan   100 kW
Post by emaayan » Jun 12 2015 4:58am
lantice13 wrote:Nice! :twisted:
don't go nice so fast :) check out their prices on their current kit, do you really think a new motor would change all that?
Trek 7.7 fx, 22.5" frame, 38x700c,10 gears.
ecospeed mid drive 1300 watt engine, max speed 45 kph.
battery1: 48v 14 ah, frame mounted battery, range 40km.
battery2(spare) 52v 10ah frame mounted bag, range, 30km.
jdevo2004   100 W
Post by jdevo2004 » Jun 12 2015 1:26pm
Cool, hopefully they keep the prices reasonable. The picture looks like a stock unit. I would like to see what modifications they did to the brackets to prevent torque twisting.
cwah   10 GW
Post by cwah » Dec 01 2015 8:13pm
subscribed
Overclocker   10 kW
Post by Overclocker » Dec 02 2015 4:58am
is there a support bearing on the freewheeling crankset? or does it rely solely on the freewheel?
jk1   1 kW
Post by jk1 » Dec 02 2015 6:18pm
it seems the problem is worse if you use the cheap DICTA or have a bad chain line, and the second bearing is a bandaid for these 2 issues.
Most of the kits even the LR just use a good quality ACS freewheel that has double row bearings and then you don't need a separate bearing the WI freewheel is not dual bearing and hence this MUST have the separate bearings.
The AFT kit looks interesting with the upgrades, also I notice they have 20% off now.
Just2807   10 W
Post by Just2807 » Dec 05 2015 7:37pm
Ok, i saw some1 opening cyclone 1680w gearbox after around 10 000 km, teeth were worn (by the looks of it) out but could take few thousand more.
Planetary gearbox is 99$ on their website.
Some1 even dripped oil inside gearbox which should prolong it's life. Can't find the damn post!
Regarding brackets, we are trying to figure out something here:
https://endless-sphere.com/forums/viewt ... 28&t=73027
There are some specs with overvolted (2kW+) motor too. Maybe it can help.
I am aiming at this 1.8-3 kW too
lantice13   100 W
Post by lantice13 » Dec 18 2015 2:51am
Seems like Lunacycle.com are selling these at their store. http://lunacycle.com/black-friday/cyclo ... planetary/ and for the flex, I would tune my controller's battery amps and phase amps ratio so that the motor will have a soft start/kick to it at dead stop. Same solution that I did with my 2015 GNG gen 1 mid drive. Bike will be less twitchy too which is important for controlling the bike.
1KW   1 kW
Post by 1KW » Jan 10 2016 2:19pm
any body build anything with this? LR is producing plates still for this kit?
cheers
lantice13   100 W
Post by lantice13 » Jan 11 2016 3:41am
I would wait for the LR version. It's looking mighty fine from the photos he posted in one of the threads regarding this kit at the ES Facebook group. :twisted:
lantice13   100 W
Post by lantice13 » Jan 11 2016 3:44am
I don't know if this is close to the final setup.
LR version
10583938_10206850057183005_2554532067289244868_n (1).jpg (55.31 KiB) Viewed 5798 times
LR version
emaayan   100 kW
Post by emaayan » Jan 11 2016 4:11am
Ohn yea, i forgot l-r block me on facebook too :)
BoomerChomsi   1 kW
Post by BoomerChomsi » Jan 11 2016 5:05am
I am considering to buy middrive kit after many hub motors....
How is durable is motor cog?
Believe and Do
TorEddy   100 W
Post by TorEddy » Jan 12 2016 2:29pm
Review of the Cyclone 3000w:
http://electric-fatbike.com/2016/01/12/ ... -the-cops/
This kit, with some LR love and a Grin Phaserunner bolted to the BB brackets, would be nice.
BoomerChomsi   1 kW
Post by BoomerChomsi » Jan 12 2016 2:58pm
Thank you for your link.
Will have a look 8)
Believe and Do
lantice13   100 W
Post by lantice13 » Jan 12 2016 10:45pm
Those programmable infineon controllers from Em3ev work very well with this motor. I would assume they are pretty much the same motor as the GNG gen 1. Tuning the phase amps and battery amps ratio is a must. It's no BBS02 or BBS-HD mid drive that are already programmed to start smoothly when you throttle up. For longevity of the whole drive system this is a requirement.
TorEddy   100 W
Post by TorEddy » Jan 13 2016 4:20am
lantice13 wrote:Those programmable infineon controllers from Em3ev work very well with this motor. I would assume they are pretty much the same motor as the GNG gen 1. Tuning the phase amps and battery amps ratio is a must. It's no BBS02 or BBS-HD mid drive that are already programmed to start smoothly when you throttle up. For longevity of the whole drive system this is a requirement.
Seems like LR is talking to Justin at Grin about programming the Phaserunner for this Cyclone 3000w kit. That combo with the controller between the BB sheets, would make a waterproof and stealth looking kit.
emaayan   100 kW
Post by emaayan » Jan 13 2016 4:28am
i wish i could use the phaserunner myself :( seems like a very compact controller, but i have no idea about it...
BoomerChomsi   1 kW
Post by BoomerChomsi » Jan 13 2016 4:38am
What kind of brand are those controllers?
Believe and Do
Warren   100 kW
Post by Warren » Jan 13 2016 12:05pm
Man. I wish I had seen this motor before I bought the Crown 4080 for my recumbent cargo bike. I wanted a 2000 watt, geared motor small enough in diameter to fit in between the frame tubes, but couldn't find one. This would have worked perfectly. Replacing the single cog freewheel with one of these Enos
http://harriscyclery.net/product/white- ... l-1554.htm
would have allowed me to run the same setup I have loved on my old mid-drive for over 20K miles. Single front chainring geared for 65-100 rpm cadence with the motor running at 50-80% of no-load, and the motor running the rear gears.
TorEddy   100 W
Post by TorEddy » Jan 13 2016 2:24pm
BoomerChomsi wrote:What kind of brand are those controllers?
http://www.ebikes.ca/c-phaserunner.html
BoomerChomsi   1 kW
Post by BoomerChomsi » Jan 13 2016 3:40pm
Thank you!
Also what kind of brand are Cyclone controllers?
Thanks.
Believe and Do
