Slow acceleration for 72v 2000w ebike.
Paco007   1 mW
Post by Paco007 » Mar 24 2020 12:40pm
Hi all,
I recently picked up a new electric dirt bike for myself. The specs are as follows:
Battery: 72v 18ah lithium ion
Controller: 48/72v 40amp
Motor: 72v 2000w hub motor. (Unknown model or rpm)
Lcd: sw900
I have been able to ride up to about 35mph although the acceleration is a bit slow to reach those speeds. Is there any way to upgrade my setup and get more acceleration? I feel that the acceleration should be more than what it's at considering the specs. I already made sure to remove the speed limiter jumper wires on the controller.
flat tire   1 MW
Re: Slow acceleration for 72v 2000w ebike.
Post by flat tire » Mar 24 2020 9:27pm
2kw is slow on a bicycle, on a heavy thing like that it will be slower.
To upgrade you want for sure a better controller, maybe a better battery, and then maybe a bigger motor.
goatman   1 MW
Post by goatman » Mar 24 2020 11:14pm
I would open up the battery to see what batteries you have and what amp your bms is to see if you can just get a higher amp controller or you might need a new battery, bms and controller or maybe lace a smaller diameter rim to the motor.
kinda sounds like you might be better off getting a different bike. you have street tires and if you got knobbies it would suck under acceleration even more, now add mud to the equation.
im not trying to beat on your bike, if you like it you can upgrade it but lets see what battery you have.
amberwolf   100 GW
Post by amberwolf » Mar 24 2020 11:50pm
Paco007 wrote:
Mar 24 2020 12:40pm
first step is to replace controller with higher current version. double the battery current limit (at least) would be a good start.
then your batteyr will be being hammered at least twice as hard as it was meant to be, so it's going to sag more and heat up more and wear out faster, and have less range. so your next step is a bigger better more capable battery (which won't be cheap...if it's cheap, it's probably not going to be what you need).
if the motor isn't getting hot, then you can keep the same motor, but if it starts getting hot then it's time to replace that, too.
to learn more about the relationships between the parts, and why you get better acceleration with some configurations than others, you should go to http://ebikes.ca/simulator and read the *entire page*, so you will know what everything is for and what it does and how to use it, then play with different systems to see what they do and what different changes do to the performance.
Balmorhea   10 kW
Post by Balmorhea » Mar 25 2020 12:31am
Paco007 wrote:
Mar 24 2020 12:40pm
Do you know what the free top speed of your motor is? It sounds like you might have too fast a motor for the electrical power you have to spend. Accounting for efficiency losses, your current system has at most 3 horsepower to propel the bike with. If you want affirmative acceleration from 3hp, it has to come available at pretty low speed.
DogDipstick   10 kW
Post by DogDipstick » Mar 25 2020 6:42am
For me on my 85lb bike 40A is slow.. 80A begins to get fun.... 100A is the most fun certainly, and can be uncontrollable fast....
Of course the battery must be able to support that 100A should you upgrade the controller.
On simple thing tht may be an option is a "shunt mod", for more amperage.
83.1v of Ironhorse XC.. :) :bolt: by Chevy :bolt: :D Broke 10 horsies :twisted: (..about 80% healed..).. :? Anybody.. what equals √3 times the line to neutral voltage? Asking for a friend.. :| (gottenymoem4115thangs?Yall?) :confused: Fabricator @ BSECo. Inc.
dogman dan   100 GW
Post by dogman dan » Mar 25 2020 6:56am
Well, nobody yet has asked how much weight you are trying to accelerate. The bike is clearly not light. Does it have lead battery?
And er,, are you heavy?
Your bike may have a 2000w motor on it, but at 72v, you have potentially 3000w.
Battery sag could easily have your voltage low enough under load, to only have 2000w. and that will feel slow, even if you are not a big guy.
First, investigate battery sag. See what happens on take off, by putting a volts display on the bike. Chances are very good that a 40 amps controller, plus a battery type that sags a LOT less, will get you more motorcycle like performance.
Lastly, if the motor is a particularly fast wind, it will take off very sluggish if overloaded, but your top speed does not suggest that you have an extremely fast wind motor. I think its battery, and simply that 2000w is still kind of moped performance, vs motorcycle like power. Mopeds also take off kinda slow.
Tommm   10 kW
Post by Tommm » Mar 25 2020 10:31am
Hate to put it this way, but it would of been much better if you asked our opinion before you bought it.
Anything to modify it will require quite some knowledge/time/money.
That said the last part you will need to replace is the motor, they can take 2-3x rated power from factory.
The bad news is, the motor isn't the most expensive part, but the battery.
999zip999   100 GW
Post by 999zip999 » Mar 25 2020 11:16am
Can you give us a link to the motorcycle ? I wonder what mutter they're using is a 35 mm magnet ? And what battery ?
goatman   1 MW
Post by goatman » Mar 25 2020 11:22am
id be tempted to put those parts on a chinese stealth bomber frame or any full suspension MTB. atleast you would have pedals and be somewhat street legal, if only by appearance.
Paco007   1 mW
Post by Paco007 » Mar 25 2020 1:32pm
Hi guys,
Thanks for the helpful input. I will do more research into the lithium battery specs and see if upgrading the controller amps will help. On the lcd it shows watts being pushed out is ~2600watts.
I may just take the bike back to the vendor. I have come to the conclusion that it's mainly just a heavy bike and needs more amps to increase torque. Running the bike with the wheel off the ground the speedometer goes up to 60mph.
I am pretty light at only about 130 lbs but last night I increased the tires psi since they were a bit low and it made a good difference.
Paco007   1 mW
Post by Paco007 » Mar 25 2020 2:08pm
Okay so I requested a refund from the vendor. I can either return the bike to get my refund(I paid 2k for the bike). He can also refund 200 and I keep the bike. I am on the fence if i should return it or keep it and use the 200 to put towards controller or battery upgrades if needed.
My other options if i get a full return would be something like an oset MX10 or similar. I am just looking for a fun mx style ebike for under around $2500. Do you guys have any suggestions for a fun mx style ebike that can pop wheelies and take hills with a battery range of around 30miles top speed of around 30-40mph?
amberwolf   100 GW
Post by amberwolf » Mar 25 2020 5:55pm
Paco007 wrote:
Mar 25 2020 2:08pm
a quick google shows that thing is even *less* power
It has a rechargeable 48-volt lithium pack that drives a 1400-watt, 48-volt Oset neodymium magnet DC motor.
my guess is you'll probably be even less happy with it. (but it depends on it's drivetrain and other stuff i didn't look up).
as for range, that depends on your riding style and speeds and terrain and winds and weight, tire style, tire pressure, road condition, etc.
if you want useful recommendations, you'll have to give us *complete* details, not leaving *anything* out, of *exactly* how you want to ride the bike (not just a general description, be very very very very specific), and *exactly* what the terrain is like, the roads, the weather/winds/etc, weight, specific acceleration required, how much range *at what speed*, etc.
all other details you can think of are probably useful too.
i also still recommend you go to the http://ebikes.ca/simulator and do as suggested before, so you can learn how this stuff all relates, so you will have a better idea of what you're actually looking for.
dogman dan   100 GW
Post by dogman dan » Mar 26 2020 6:15am
Hmm, Its not your weight then.
It could be something really simple, like one connector on the motor is connected, but not well. If that is the case, soon you will see that wire connector melting.
But my guess is that if its taking off too slow for you at 2600w going into that motor, then its just that you expected a motorcycle, which is more like 5000 to 10000 watts of power. You bought a moped, which has 3000w.
But still, at a stop light, you should be keeping up with cars as they take off. Not zooming ahead like a 15 hp 250cc, but keeping up like a moped, with 3 hp. If not, something is wrong.
Your top speed though, is spot on for 2600w. This makes me think nothing is wrong with it, except you thought it was a motorcycle, since it looks like one.
Improving it is not so hard. Simple to put a much stronger controller on it. But I betcha your battery struggles already, so a more powerful, higher c rate battery is costly, and a type that is not very safe.
It becomes a slippery slope, where go fast money ends up a lot more expensive than just buying a used 250cc motorcycle. Battery alone for what you describe would cost your entire $2500. Time to go back to gas bro, or get out the wallet.
skeetab5780   10 MW
Post by skeetab5780 » Apr 07 2020 7:25am
Ive been eyeing these bikes for some time on Ebay, I actually like the look of it and wish they sold the frame only. For $2400 its too much if it was $1200 id buy one for kicks, you know me
-a few things to point out, they say speed goes up to 50mph when you cut limit wire which requires way more than 2600w with that weight id imagine (even though you are light yourself)so im curious as to what controller is being used(maybe a cheap 12 fet)
-the bike comes with a 72v 18ah battery and claims it can get up to 50 mile range which is impossible with the weight of this bike, you will likely get about 18miles
-i would imagine the stator is atleast 40mm wide and likely a 9x7 wind motor? in a 19" wheel would be around 47mph i guess
-Your body weight is added to the unsprung weight of the rear swingarm because of how they made the bike? Not sure if this is a good thing or not. Depending on how stiff the rear shock is it could make the ride better or worse taking into account the weight of the hub motor already.
if you paid $2000 you already got a better deal than Ebay, they offer local CA pickup so this is probably how you got it
What did you end up doing with the return? Do you know the actual weight of the full bike?
Skeetab
Paco007   1 mW
Post by Paco007 » Apr 19 2020 10:41pm
Quick update! :D I sold the bike and picked up a used Kuberg Freerider 48v 8kw. Dammn thing is like a bat outta hell! This thing is more to my liking it's lightweight and front wheel pops ups if your not careful. Now I just want to customize this freerider as far as height and suspension to make it more comfortable.
torker   1 MW
Post by torker » Apr 20 2020 1:00pm
Is that double the money. Isn't it over 4 grand?
Dave When I die I want to slide in sideways yelling WooHoo what a ride !
Giant Rincon w rear 9C 6*10 36 v x 20 amps
Specialized FSR Comp 9C 6*10 48v x 30 amps
Paco007   1 mW
Post by Paco007 » Apr 20 2020 2:31pm
torker wrote:
Apr 20 2020 1:00pm
I got a deal $2500. Its a bit unkept I will need to look at adjusting the chain since it rubs on the frame a bit and the tires will need to be replaced soon. The battery looks to be in good condition I rode for several miles last night.
Paco007   1 mW
Post by Paco007 » Apr 20 2020 8:14pm
The previous owner of the kuberg replaced the original shock 240mm to a 265mm shock and its causing the chain to rub on the rear arm. I am looking to get the original shock to fix the chain issue as well as lower the ride height as it sits the back is more raised than the front making the ride super uncomfortable.
skeetab5780   10 MW
Post by skeetab5780 » May 04 2020 12:23pm
Pic or it didnt happen!
Nice upgrade and good deal on the Kuberg even if its beat up. I love mine all i did was put larger wheels on it
Paco007   1 mW
Post by Paco007 » May 08 2020 10:26pm
Okay here it is. I installed new rear shock as well as front and rear tires. I freshened up the chain and applied chain oil.
skeetab5780   10 MW
Post by skeetab5780 » May 12 2020 5:45am
Thanks for pic! Looks like you got a killer deal, bike looks nice IMO
How do you like the lighter weight and more power?
Here is mine
IMG_3640 (1).jpg (261.17 KiB) Viewed 261 times
Balmorhea   10 kW
Post by Balmorhea » May 12 2020 1:47pm
It looks like the gas and oil are going to leak out when you do that.
