Rad battery on kit build
Abernathy5pithol7snitcher   1 µW
Post by Abernathy5pithol7snitcher » Feb 07 2020 12:09pm
I'm building a kit bike. Do you see any problems if I use my 2019 rad mini battery to run it? Is it as simple as just connecting the positive and negative terminals to the kit controller?
I want to alternate usage between the mini and the kit bike.
tigcross   100 W
Re: Rad battery on kit build
Post by tigcross » Feb 07 2020 12:20pm
as long as the kit controller is rated for the Rad battery voltage then you should be fine.
markz   100 GW
Post by markz » Feb 07 2020 1:36pm
Hopefully its non proprietary.
Post by Abernathy5pithol7snitcher » Feb 07 2020 10:03pm
markz wrote:
Feb 07 2020 1:36pm
What does that mean?
docw009   100 kW
Post by docw009 » Feb 07 2020 11:22pm
A few systems, like BionX (bankrupt) will configure the battery with extra data wires whose main purpose is to tell the controller it''s a genuine Bionx battery. Sure, they can be useful for diagnostics too, but the main reason is to force the user to use the same brand of battery. Called proprietary.
Radmini is a simple two pin battery. Buy a second cradle so it will be secure on the kit. It makes sense to share a battery between different ebikes. You can only ride one at a time.
Post by Abernathy5pithol7snitcher » Feb 08 2020 7:49am
docw009 wrote:
Feb 07 2020 11:22pm
Thanks, that's what I suspected. This the response I got from rad when I asked them the same question: "We highly recommend against doing any DIY projects with the electrical equipment of your Rad Power Bike, especially with the battery and controller. This could cause a dangerous situation for you, and we want you to be as safe as possible when riding rad. Please do not attempt this for safety and liability reasons. Doing so will void your warranty."
AHicks   100 W
Post by AHicks » Feb 08 2020 8:49am
RAD is worried about 2 things. Warranty costs and tech support.
If they suggested anything but the reply you received, they would be liable for one or both. When it comes to anything but very simple mods, calling or writing RAD is a waste of your time. Best if you don't expect ANY help from them regarding mods of any kind.
