ES DIY Motor Challenge
Farfle   1 MW
Re: ES DIY Motor Challenge
Post by Farfle » Nov 10 2012 11:54am
pkirkll wrote:Maybe we could get one kudo just for entering??????
:D
At least one kudo for entering a legit torque number, that takes a bit of dedication to find.
Test Review Revise Repeat
Miles   100 GW
Post by Miles » Nov 10 2012 11:56am
Steady on.... We don't want to devalue the kudo... :)
Farfle   1 MW
Post by Farfle » Nov 10 2012 11:57am
Miles wrote:Steady on.... We don't want to devalue the kudo... :)
Lol, no false kudo inflation.
pkirkll   100 W
Post by pkirkll » Nov 10 2012 12:43pm
:D
Miles   100 GW
Post by Miles » Sep 24 2013 3:43am
Edited the first post to add the new rules.
http://www.endless-sphere.com/forums/vi ... 30&t=14484
Lebowski   1 GW
1 GW
Post by Lebowski » Sep 24 2013 4:07am
somehow to me the rules don't make sense (sorry :| )
with the specific torque etc, what it boils down to is
Torque should be larger than 0.2 * kg ^2 + 3 * kg
The weight (kg) squared means... well... lets say we have a motor with a certain weight. Taking two of
these and putting them on the same axle means the motor weight doubles and the torque doubles. But,
because of the square term the torque should more than double to be conform the challenge.
My feeling is that if one motor is conform the challenge, two of these motors combined should also
be conform the challenge...?
Miles   100 GW
Post by Miles » Sep 24 2013 4:15am
Let's try with the example I gave.
1.2 kg motor needs to output 3.9 Nm
2.4 kg motor needs to achieve 2.4 * 0.2 + 3 = 3.48 Nm/kg
This requires 3.48 * 2.4 = 8.35 Nm
What's wrong with that?
Lebowski   1 GW
1 GW
Post by Lebowski » Sep 24 2013 4:21am
Miles wrote:Let's try with the example I gave.
Well, what this means is that a 2.4 kg motor needs to perform better than two 1.2 kg motors, meaning that it is not 'allowed' to put 2 motors on one axle (which doesn't make sense).
Miles   100 GW
Post by Miles » Sep 24 2013 4:27am
Why would you want to do that? Of course, 2 small motors won't perform as well as one big motor.... :)
The whole point of the calculation is to allow for the advantage gained as motor weight increases. This means that you are leveling the field for motors of differing weights, within each weight category.
Of course, you could dispute the level of advantage we've allowed for....
Miles   100 GW
Post by Miles » Sep 24 2013 4:54am
Miles wrote:Of course, you could dispute the level of advantage we've allowed for....
Suppose we changed it to 0.1 * motor weight + 3.2 ?
1.2kg motor needs to output 3.96 Nm
2,4kg motor needs to output 8.25 Nm
Is this more realistic?
Miles   100 GW
Post by Miles » Sep 28 2013 1:40pm
As we also have the three weight classes, now, I think it would be quite sensible to start with a low value for the multiplier.
Any objections to: 3 + 0.1 x motor weight in kg, for the specific torque in Nm/kg ?
Anyway, it's all a bit academic, at the moment.... :mrgreen:
Lebowski   1 GW
1 GW
Post by Lebowski » Sep 28 2013 2:25pm
Miles wrote:As we also have the three weight classes, now, I think it would be quite sensible to start with a low value for the multiplier.
how many peoplle have ever build a motor from scratch ?
Miles   100 GW
Post by Miles » Sep 28 2013 2:27pm
Lebowski wrote:how many peoplle have ever build a motor from scratch ?
You :)
Arlo1   100 GW
Post by Arlo1 » Sep 28 2013 2:55pm
And me
Does your project need a high performance motor drive, battery charger or other power electronics developed? Let's talk!
www.powerdesigns.ca
Leaf motor controller build. http://endless-sphere.com/forums/viewto ... 27#p963227
YSR build http://www.youtube.com/watch?v=BRo8r5g4NBg
Support me on Patreon. https://www.patreon.com/user/posts?u=6842045
http://www.undergroundelectrics.ca/
Lebowski   1 GW
1 GW
Post by Lebowski » Sep 28 2013 3:32pm
farfle?
I'm now coming up on one year commuting to work with my motor, about 5000 trouble free km's :D
Arlo1   100 GW
Post by Arlo1 » Sep 28 2013 4:21pm
Lol yeah mine was 100% troubble with the iron powder epoxy but a fun project and I will return to it.
www.powerdesigns.ca
Farfle   1 MW
Post by Farfle » Sep 29 2013 1:42pm
Sadly I don't think I am eligible, as I only have peak dyno numbers. If I were to hazard a guess, I would say that its good for 160-190 phase amps continuous which would leave me at 58-69nm. it weighs 15Kg, so if my WAG continuous numbers are close, I am at 3.8-4.6 Nm/Kg. No idea where that puts me at the current contest rules.
Miles   100 GW
Post by Miles » Sep 29 2013 3:09pm
Using 3 + 0.1 * motor wt. you'd need to be able to sustain 4.5 Nm/kg continuously.
Using 3 + 0.2 * motor wt. you'd need to be able to sustain 6 Nm/kg continuously.
Considering that your motor is far from being optimised for weight ...............
Farfle   1 MW
Post by Farfle » Sep 29 2013 4:33pm
Miles wrote:Using 3 + 0.1 * motor wt. you'd need to be able to sustain 4.5 Nm/kg continuously.
Awesome, it doesn't look half bad. I could probably shave 2-3kg off of it without too much work, but on top of all of the structural modifications, Its copper/iron ratio is not set up for maximum continuous power, more towards burst power without saturating.
Miles   100 GW
Post by Miles » Sep 29 2013 4:40pm
So, shall we start off with the 0.1 multiplier, then? :)
Farfle   1 MW
Post by Farfle » Sep 29 2013 4:46pm
Miles wrote:So, shall we start off with the 0.1 multiplier, then? :)
.1 is pretty achievable for a novice with some preparation, but if we are shooting for something special, then .2 should be the metric.
(It also gives me something to shoot for with the next motor :mrgreen: )
Miles   100 GW
Post by Miles » Sep 29 2013 4:56pm
It's the base number that we'll be increasing to "raise the bar". The weight multiplier factor will be adjusted to smooth the transition between the weight groups. So, it's more related to addressing the advantage of scale.
Farfle   1 MW
Post by Farfle » Sep 29 2013 5:20pm
Miles wrote:It's the base number that we'll be increasing to "raise the bar". The weight multiplier factor will be adjusted to smooth the transition between the weight groups. So, it's more related to addressing the advantage of scale.
Then I say that .1 is a great place to start :pancake:
Miles   100 GW
Post by Miles » Sep 29 2013 5:30pm
Ok. I'll make the change. No more changes after this..... :)
KarlJ   100 W
Post by KarlJ » Mar 20 2014 6:04am
most efficient is going to be an axial flux design......, quite simple to DIY also.
EG use an otherwise destroyed motor as a base neo's on the outside coils on the inside
pick magnets you can get at reasonable money
http://www.fieldlines.com/index.php?act ... 2538;image
pick big wire = power handling without melting
no laminations to saturate = pump in as much power as you can, keep an eye on the temps.
a 5kW wind turbine motor will run 50kWW in short bursts no problems similar RPM's required too match made in heaven.
