QSmotor/SiAecosys/Taizhou CT-22 Programming. 1 of 8
jroeske   1 µW
Re: QSmotor/SiAecosys/Taizhou CT-22 Programming. 1 of 8
Post by jroeske » Jan 20 2020 5:47am
hi there have a ct-22 and with the information in these posts I have been able to program everything but the battery voltage meter any help would be greatly appreciated
THEDON82z1   1 mW
Post by THEDON82z1 » Jan 21 2020 5:09am
My understanding (please if I am wrong correct me)is p-2 through p6 is charging status. (Example p5 is charged at 80%, Then you put whatever Voltage your battery is at 80% charged) So mine is a 60volt battery 80% charged for me would be something like 58volts (0058). My cut off on the bms is 52 volts/Fully charged is 67.8 volts. P7 -P9 is discharging status 20-60%. So if the battery was 20% discharged it would be 58volts for me because I have a remaining compacity of 80%. P-A is if the battery was discharged at 80% of
it's compacity. So mine would be like 57volts (0057). P-B is 100 percent drained or the cut off. So mine would be 52volts (0052). I have not gone it to load test yet so the numbers will probably be fine tuned some more. However this is the general idea,I hope it helps I am currently getting help with speedometer settings. That's the main one holding me up and what does I and H stand for (it's not in the documentation). Anyway cheers I think we all need to continue to work on this thread. So nobody has to suffer on it, the ct22 is a good speedometer. However it's just purely OEM based..lol!
THEDON82z1   1 mW
Post by THEDON82z1 » Jan 21 2020 9:09pm
kiwifiat wrote:Jan 18 2020 3:48pm
You need the circumference of the tire and the number of pole pairs the motor has. You will need to remove one of the side covers to count the magnets. Pole pairs = number of magnets/2. Alternatively you could ask the manufacturer about the pole pair number but ymmv.
Get back to me with that data and I can assist you.
Hello I believe it's 15pole pairs 11inch tire /circumference of 34.54 inches/87.73 cm. Rated at 2400 rpm according to the Seller. Also what is the exact formula for mph (start to finish). I want to write it down and put it in my notes.My scooter is 60 volts. However eventually I am going to Hot Rod my 72volt Onyx RCR. I am going to need it adjust the ct22 on that. Plan to do 2 post on both of these rides. Thanks bro for all your help.
eKZQSN   1 µW
Post by eKZQSN » Jan 22 2020 8:27am
My frequency calc for my set up is 138 assuming 60 kph. I will set the system up for MPH when done. For parameters 0 and 1 using passcode 6610, I put 138 for parameter 0. What do I put for parameter 1 -- also 138 or 60?
eKZQSN   1 µW
Post by eKZQSN » Jan 22 2020 8:35am
I have something odd happening. Over the course of a day or two, either the trip odometer, total odometer or both seem to randomly reset to zero. Any ideas why? I have pin 1 (yellow) always wired to 96v. Pin 2 is connected to 96v, but through my switch. Pins 3 and 4 are both connected to the frame as a common ground as I am using a Kelly controller. Pin 5 is connected to 12+ which is also only active when my switch is turned on and the 96v is converted to 12v. Any ideas?
kiwifiat   100 W
Post by kiwifiat » Jan 23 2020 4:52pm
THEDON82z1 wrote:
Jan 21 2020 9:09pm
If you have set the display for MPH then the display microcontroller is asking you for the frequency in Hertz at say 60MPH.
You can use metric or imperial to do the calculation but since you want MPH let's use imperial.
There are 63360 inches in a mile so in 60 miles there are 60x63360 = 3801600 inches.
There are 3600 seconds in an hour so at 60 MPH your scooter is covering 1056 inches per second.
Your tire has a circumference of 35.54 inches so your tire is rotating at 1056/35.54 = 29.71 revs per second.
Your motor has 15 pole pairs so the frequency on any one of the Hall sensor wires will be 15 x 29.71 = 445.65 Hz so lets say enter 446Hz at 60MPH.
“You never know if quotes on the internet are genuine.” - Abraham Lincoln
THEDON82z1   1 mW
Post by THEDON82z1 » Jan 23 2020 5:19pm
. If you have set the display for MPH then the display microcontroller is asking you for the frequency in Hertz at say 60MPH.
Ok thanks so much for a full explanation. As soon I get home I will put the numbers in and make a note. Thank you so much and I look forward to sharing more ideas with you.
THEDON82z1   1 mW
Post by THEDON82z1 » Jan 23 2020 5:23pm
eKZQSN wrote:
Jan 22 2020 8:35am
Not sure that seems weird. However I have my (non) 12volt negative's going to the battery negative. The only thing I could not figure out was how to use the eco,normal and speed negative lamps (in real-time). How do you get them to switch real-time using only the negative lines. SMH!
eKZQSN   1 µW
Post by eKZQSN » Jan 23 2020 9:45pm
My current dc-dc converter (96v-12v) has a common ground. This forces me to have the frame be grounded for both the 96v battery and 12v system. I suspect this is causing problems not to mention how easy it is to ground out the battery on the frame. I’m going to replace it with a dc-dc converter that isolates the two voltage systems allowing the frame to be just the 12v ground.
I’m curious myself how you can manage the motor torque and display the mode.
Any thoughts on what to enter for parameter 1 when programming the display using 6610 password?
THEDON82z1   1 mW
Post by THEDON82z1 » Jan 23 2020 9:58pm
eKZQSN wrote:
Jan 23 2020 9:45pm
Good idea with splitting the negatives. I am just getting off work so tomorrow I will put in the suggested hertz number recommended to me earlier. Follow the formula recommended to me in the above post and see what you get. However like it was told to me ymmv..lol..Look forward to hearing your results. I won't know with mine until I am ready for load testing. Final parts (Rear brakes hose , kickstand and a few other cosmetic things ) arrive in the mail.Cheers:)
eKZQSN   1 µW
Post by eKZQSN » Jan 24 2020 8:37am
I’m traveling now and won’t be back at it until March. Will post the results.
THEDON82z1   1 mW
Post by THEDON82z1 » Jan 24 2020 8:49am
Sounds good,enjoy:)
