Reention POLLY DP-6C - 70 cell battery case - how fit BMS?
vulcanears   10 mW
Post by vulcanears » May 27 2019 8:49am
Hey everyone.
I bought a Reention POLLY DP-6C battery case for 70*18650 cells. Build quality seems a lot better than the Hailong cases, especially the little tabs that hold the battery box to the mounting-plate.
http://www.reention.com/product/detail/99
Unfortunately my 30A bluetooth BMS is 9mm thick and when I try to fit it into the case, it won't close. Did anyone successfully fit a BMS and 70 cells into this case? I'd love to hear some ideas or see some photos.
Speady   10 W
Re: Reention POLLY DP-6C - 70 cell battery case - how fit BMS?
Post by Speady » May 27 2019 10:19am
You need a dedicated BMS, same as with Hailong 2 cases.
I wonder why the seller didn't offer a all in one package.
Bought myself a Polly 1with 13s BMS that fits on top, no problem
vulcanears   10 mW
Post by vulcanears » May 27 2019 12:16pm
Some AliExpress sellers offer the case with a BMS, but I prefer Bluetooth bms systems that let me see cell voltages on my phone. That gives me the peace of mind that the bms is working properly.
The Bluetooth bms would fit if I removed the heatsink. I'll try to come up with a custom heatsink design. (running it without a heatsink is probably not recommended, right?)
vulcanears   10 mW
Post by vulcanears » May 29 2019 5:41pm
Could someone please post a picture and the measurements of a BMS that fits the case?
I spent the whole day trying different 3d-printed mockups and can't come up with anything that fits into my case, when it's populated with 70 cells. Even the height of the PCB board + JST connector for the balancing leads is too much. :?
BotoXbz   10 W
Post by BotoXbz » May 30 2019 6:07am
You made a good choice with the 30A bluetooth BMS.
It uses five KIA KNB3308A FETs in parallel, the gate of the FETs is driven with 12V.
The datasheet states a resistance of 6.2mΩ per FET, you have 5 of them 6.2mΩ/5 = 1.24mΩ. (I've measured the resistance on mine at 1A each and got 6.2mΩ - 6.4mΩ per FET)
Let's assume you're running 30A through it, the heat generated by the FETs will be P = R * I² = 1.24mΩ * 30A = 1.116 Watt of heat.
You definitely do not need a heatsink for that. The FETs are mounted on a big copper plane and are big enough by themselves to dissipate this heat.
And at 30A for longer than a few minutes on a 5P pack will cause you more trouble with your cells than the BMS.
Try moving it around a bit in the case, it'll never be 100% perfect but when you screw it down the plastic bends a bit and it's fine.
vulcanears   10 mW
Post by vulcanears » May 30 2019 6:23am
Thank you very much! That helps a lot!
My version does in fact use the KNB3308A, but there does not seem to be a copper bar under the mosfets.
BotoXbz   10 W
Post by BotoXbz » May 30 2019 6:45am
I said copper plane not copper bar :p
There is copper on the PCB under the FETs which is connected with lots of through holes to the copper on the underside of the PCB.
That will dissipate the little heat easily.
But even without that the 1/4 Watt of heat on each of those chunky FETs is nothing.
What I don't like about this new version 1.5 is that there is barely any space between the FETs to properly solder a thick wire to P-
V1.4 Version (60A): https://cloud.botox.bz/s/J6oZWqJDikzpTw8/preview https://cloud.botox.bz/s/2ipzTsJNWQ222TH/preview
Matador   10 kW
Post by Matador » Jun 03 2019 10:20pm
https://endless-sphere.com/forums/viewt ... x#p1299070
Tomblarom   100 µW
100 µW
Post by Tomblarom » Oct 25 2019 3:59am
Just wanted to share my experience on this. I was able to fit a smart BMS 30A (only 1 layered) on top. Pretty tricky to close the case, but it's possible to get it perfectly sealed. I managed to swap charging port and switch, to install an GX16 3-pin port and an 12mm self latching switch.
Image Image
Image Image
Image Image
Image Image
want to build   100 W
Post by want to build » Apr 02 2020 5:20pm
Hi there,
for those of you who have experience in locking batteries, how safe is this battery case considering
it i left outdoors and that the screws bolts have special anti thief Pinhead Locks for the rear rack placed on frame?
how safe is the lock and the plate you fix the case on?
tx
john61ct   100 GW
Post by john61ct » Apr 02 2020 8:25pm
Safety depends on where the bike is, not locks nor any anti-theft hardware.
Social norms, culture, that sort of thing.
Amsterdam, yes just make it inconvenient.
Detroit, carry the bike upstairs.
want to build   100 W
Post by want to build » Apr 07 2020 7:58pm
Is this a polly 2 or polly1 ?
i read polly 2 is strongest? is that true
what is polly anyway alu or plastic?
want to build   100 W
Post by want to build » Apr 15 2020 9:53pm
vulcanears wrote:
May 27 2019 12:16pm
hi did you use nickel part provided by them if yes did you verify if it is pure nickel or just plated nickel? im talking about the battery connect nickel plate sheet .
want to build   100 W
Post by want to build » May 14 2020 10:47pm
Speady wrote:
May 27 2019 10:19am
HI could anyone please explain me what is Polly 1 vs polly 2 , for the love of god if god exists i'm having a hard time finding this anwers. tx
want to build   100 W
Post by want to build » May 17 2020 1:05pm
Hi im trying to figure what type of case holds the strongest on top of a regular rear rack ? how is reention compared to hailong?
john61ct   100 GW
Post by john61ct » May 18 2020 11:02am
Please do not keep repeating the same request across multiple threads.
At least not daily, bumping every couple of weeks, maybe.
want to build   100 W
Post by want to build » May 18 2020 11:30pm
Hi i understand that it is important for you to keep this simple and correct rythm. At the same time asking for a comparaison between hailong and keention means a different interrogation for me.
Since i search for answers something i try to reach different people that is all. I m beginning to understand that those reention cases are not that well known i imagine. i do take note of your demand. I ll try to be more patient with these reention
john61ct   100 GW
Post by john61ct » May 19 2020 9:11am
As mentioned, the best approach would be for you to just buy one each and become the forum expert yourself, would be a valuable contribution to the community.
