Revolt RV-series motor review and comparisons
ElectricGod   1 GW
1 GW
Re: Revolt RV-series motor review and comparisons
Post by ElectricGod » Aug 14 2018 1:41am
dead thread
XB-502: viewtopic.php?f=10&t=83302&p=1222730#p1222730
Currie scooter: viewtopic.php?f=35&t=83830&p=1227407#p1227407
Benjamin Franklin - "Any fool can criticize, condemn and complain and most fools do."
ElectricGod   1 GW
1 GW
Post by ElectricGod » Aug 30 2018 6:17pm
dead thread
madin88   1 GW
1 GW
Post by madin88 » Sep 06 2018 8:14am
ElectricGod wrote:
Jul 09 2018 11:35pm
Checked a few things.
Phase resistance: 57.6-57.7 mOhms.
Inductance: .2 to .21 uH
I guess you measured 0.2 mH, or 200µH
because 0.2 µH would be more the inductance of a shorting link then from a motor coil :wink:
Have you figured out where the hall sensors must be installed or how the solution of the manufacturer looks like?
I have seen the motor is wound in delta so the sensors need to be placed with a shift of 30° electrically opposed the directionof rotation.
This would mean you cannot place them between the teeth (or at least all of them).
http://www.bavaria-direct.co.za/scheme/common/#
you could take a look at those winding schemes from above link.
yours probably is wound as dLRK or dLRK evolution. it should not be hard to find out, and than you know where the sensors need to be placed
eg. sensor A with a 30° shift beside the start point of phase wire A, sensor B beside phase B and so on...
- 10kW belt drive with Neumotor 8057: [url]viewtopic.php?
ElectricGod   1 GW
1 GW
Post by ElectricGod » Sep 11 2018 6:19pm
dead thread
ElectricGod   1 GW
1 GW
Post by ElectricGod » Nov 21 2018 3:21am
dead thread
madin88   1 GW
1 GW
Post by madin88 » Nov 22 2018 12:38pm
Pretty good soldering job on those small parts :thumb:
ElectricGod   1 GW
1 GW
Post by ElectricGod » Nov 22 2018 10:27pm
dead thread
ElectricGod   1 GW
1 GW
Post by ElectricGod » Nov 22 2018 10:43pm
dead thread
ElectricGod   1 GW
1 GW
Post by ElectricGod » Nov 22 2018 11:19pm
dead thread
ElectricGod   1 GW
1 GW
Post by ElectricGod » Dec 31 2018 12:20pm
dead thread
ElectricGod   1 GW
1 GW
Post by ElectricGod » Jan 01 2019 2:06am
dead thread
ElectricGod   1 GW
1 GW
Post by ElectricGod » Jan 02 2019 11:46am
dead thread
ElectricGod   1 GW
1 GW
Post by ElectricGod » Jan 17 2019 8:23pm
dead thread
Pyon   10 µW
10 µW
Post by Pyon » Jan 27 2019 11:10am
Hi ElectricGod, any progress with the mount base yet? I am considering bying this motor at some point so I am interested how you are going to end up fixing it.
ElectricGod   1 GW
1 GW
Post by ElectricGod » Jan 27 2019 5:29pm
dead thread
DanGT86   10 kW
Post by DanGT86 » Jan 27 2019 11:36pm
What is this "good solder" you mentioned when you were working with the tiny halls?
ElectricGod   1 GW
1 GW
Post by ElectricGod » Jan 29 2019 4:11am
dead thread
ElectricGod   1 GW
1 GW
A few new Revolt motors to review...
Post by ElectricGod » Feb 27 2019 3:49pm
dead thread
madin88   1 GW
1 GW
Post by madin88 » Feb 28 2019 5:53am
Thank you for the review and the photos :thumb:
What would be nice to have is a brief summary of the performance relevant improvements done on the RV100E in comparison to the PRO version.
Things like:
- phase to phase resistance
- lamination thickness
- kV and number of turns
- no load losses at given RPM
- stator size (i guess they are identical?)
ElectricGod   1 GW
1 GW
Post by ElectricGod » Feb 28 2019 8:36pm
dead thread
ElectricGod   1 GW
1 GW
Revolt RV-120-regular
Post by ElectricGod » Mar 07 2019 4:15pm
dead thread
larsb   1 MW
Post by larsb » Mar 07 2019 4:28pm
Nothing new.. Why waste your time on this? When you are done the conclusion will be that it was not worth the effort.
Only the 120e motor is somewhat interesting since it should have other laminations than the others. If they have learnt something..but i guess not since they still sell the old crap.
Having already tried two crappy revolt motors and seeing more money thrown their way is painful..
Ride on!
ElectricGod   1 GW
1 GW
Revolt RV-120-regular halls and temp sensor
Post by ElectricGod » Mar 07 2019 4:50pm
dead thread
ElectricGod   1 GW
1 GW
Post by ElectricGod » Mar 07 2019 5:04pm
dead thread
larsb   1 MW
Post by larsb » Mar 07 2019 5:18pm
the revolt reviews are in my posts. Well documented, and i think you already wrote earlier that you read some of them.. In the rotor losses thread possibly.
The low copper fill, useless soldering of wires etc has been a general issue for Revolt. It was 22% copper fill in my motor originally..
And if the laminations are low quality like in Revolt case then it's not better with lower pole count.
Etc.
Ride on!
