new cyclone 3000 w mid-drive kit?
emaayan   100 kW
Post by emaayan » May 31 2015 4:40am
hi..
has anyone heard tried this kit before? http://cyclone-tw.com/order-3chain.htm
i'm referring to the first kit
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
[moderator edit to insert video limk]
https://www.youtube.com/watch?v=RFfw4aeajHk
Trek 7.7 fx, 22.5" frame, 38x700c,10 gears.
ecospeed mid drive 1300 watt engine, max speed 45 kph.
battery1: 48v 14 ah, frame mounted battery, range 40km.
battery2(spare) 52v 10ah frame mounted bag, range, 30km.
district9prawn   100 W
Re: new cyclone 3000 w mid-drive kit?
Post by district9prawn » May 31 2015 9:30pm
Looks just like their "3000w" kit with a 190mm bottom bracket. Nice that they got a motor that fits within the 148mm BB. The gearbox looks the same as their other 3000w kit.
Neu 8057 6kW left hand drive hardtail with 18 fet Vesc: viewtopic.php?f=6&t=96754
emaayan   100 kW
Post by emaayan » Jun 01 2015 1:09am
but the mounting brackets look too thin and look like they might flex
dekes1   100 mW
Post by dekes1 » Jun 02 2015 2:15pm
Yes, I have this kit and am currently running around 2600w at 55 volts. At that power level, there is very distinct flex of the brackets under hard acceleration. As a matter of fact, I have had them flex so much that the chain came off twice. On a positive note, that is 2 chain derailments over around 500 miles of usage so not terribly bad. The motor runs cool, as does the controller. I am a little fearful that if I was to mod the controller to allow higher current draw, the flexing would become a more prevalent problem. Most of my riding is about 50/50 between peddle assist and pure throttle.
emaayan   100 kW
Post by emaayan » Jun 02 2015 2:24pm
i don't run on running it any higher, how fast did you go without pedaling at that power level? are you saying 55 volts charge or nominal voltage
those brackets look like something a machinist might replicate from a stronger thicker stuff.
but i'm more worried about the planetery gear and sprockets wearing out.
dekes1   100 mW
Post by dekes1 » Jun 02 2015 2:54pm
Without pedaling, I've seen a maximum speed of 35mph/56kph. My battery pack is a 14s10p pack which is 58.8 volts fully charged and between 52.5 -55 nominal. The controller is listed as a 40amp continuous and 100 amp peak capable. I use a PowerLog 6s meter to measure only 6 cells of my pack and I have seen 50amps peak current draw. I suspect that's the most i'll ever get out of my 18650 cells.
if you had a battery pack capable of 60amps or more, I'd guess the motor (and correct gearing) would push you over 45mph/72kph. My bike is on the ragged edge at 35mph and I usually ride below 30mph.
jk1   1 kW
Post by jk1 » Jun 02 2015 7:07pm
How quiet is it with the plastic gears ?
What is the peddle cadence like ?
Overclocker   10 kW
Post by Overclocker » Jun 02 2015 8:56pm
i'd rather have a bunch of chains than plastic gears
jk1   1 kW
Post by jk1 » Jun 02 2015 10:48pm
Why so it can be noisy and catch on your pants ?
If these gears have been designed properly to suit the power 3kw then they should not fail and they should also be quieter then steel gears or steel chains. The Bosch and Bafang BBS02 is full of plastic gears. Internal planetary gearboxes are the most compact and clean designs compared to jackshafts with gears and chains flying around and look like something invented in the 1800's :P.
The question is if they have been designed for 3kw ?
emaayan   100 kW
Post by emaayan » Jun 03 2015 12:31am
for something costs 30$? i'm not sure, look at all the options aft bring up from prolonging the life of the gearbox? and that's only for 1680 watts.
i currently own a gng 2015 and it's goes to around 52 kph at 48v nominal baattery at 1700 watts. pretty similar to this, it's usage is 25 wh/km (whats the usage on this i wonder). it works well now after i replaced the entire crank with my own spider.
it's casted jackshaft holder holds and doesn't bend. and that means that if could pull out the jackshaft from it you could replace it with something stronger, that would accept better freewheels and better 8mm chain rings.
the only thing i'm worried about in my gng is the motor's own driver sprocket, there doesn't seem a way to remove it (no key, no allen bolt) it doesn't seem to unscrew. the only way i can think about is it's pressfit into the shaft, or that pressfitted into part of the shaft that was later bolted though the brearings.
if could i could solve that mystery then i'm think i'm golden on all wearable parts.
even more, i may even be able to use a thun 136 mm bb on it, as it seems to have big clearance. unlike this thing.
actually i was these are the same motors
the advantage this motor has is that it can be fitted to any bb. maybe less noisy.
dekes1   100 mW
Post by dekes1 » Jun 03 2015 10:50am
From my experience, the noise level is about a 6 out of 10. It can be loud under hard acceleration, but quiets down once up to speed. It's definitely louder than a hub motor (I also have a Yescomusa 1000w direct drive hub motor for comparison) but seems to be about normal for most mid-drives.
The pedal cadence varies since it's a mid-drive and can benefit from using 2 gears on the front and the full set of gears on the rear cassette. You can change gears to find a comfortable cadence. It has enough torque to run in just about any gear within reason.
It would be difficult for me to comment on power usage since I do a fair amount of pedaling. For example, I went 11 miles (17km) yesterday and only used 2300mah, which seems to be about 7wh/km. I probably pedaled about half the time. I'm also a heavier rider at 220lbs.
In my opinion, this kit is probably the cheapest way to get into the 2kw-3kw domain. There are much nicer kits, like the Lightningrods gear, and this kit is quite obviously sold to hit a low price point. But, for the price it's plenty powerful and relatively easy to install.
emaayan   100 kW
Post by emaayan » Jun 03 2015 10:57am
i can't get l-r kit i'm probably the only guy he'll never sell it to, , i do have the prototype, (long story)
but from my short experience when it worked, it's usage was higher then gng 2015 (30 wh/km) but the most annoying part in it was the belt kept slipping if i tried going wot when the gears were in mid range, i had to keep reminding myself to lower the gears.
i wonder if they all use the same honglinda motor.
lantice13   100 W
Post by lantice13 » Jun 09 2015 3:43am
subscribed. I am also interested in this kit. sadly it came a month before I got my 2015ver of the gng gen 1 kit. so far, I trashed the new style freewheel crankset that they supplied. I'm using the old version now. the price is very competitive with the gng. hopefully we can see someone with an actual kit in use in their build with real world experience and not just speculations on how crappy they are from just looking at the store photos. :wink:
emaayan   100 kW
Post by emaayan » Jun 09 2015 3:58am
from what i can see at least form the brackets at the very least you'd need new ones or weld something in between from the l-r kit i had, it's enough these things might flex just a wee, you'll have an out of balance chain.
now i know they seem to have designed for it, (making the right one thicker then the left one ) but still , look at length they have.
plus i'm not sure it will out perform you current gng 2015 (and have easier parts to repalce like the freewheel and driven sprocket).
lantice13   100 W
Post by lantice13 » Jun 09 2015 4:01am
another question, is your bicycle drivetrain designed for 3kw? lol I would worry about that more than the kit itself. I've seen these kinds of planetary gear box on passenger electric motorcycle that got a side car before, going up a hill with around 6 passengers... crawled slowly but it made it to the top. It's also used on motorcycle conversion. gng got longer motors with similar looking gear box on their trike/golf cart kits. then again the cyclone mounting hardware might not be rated for that power. so like high power GNG kits, a little fabrication is required. I'm interested in the performance on the usual 1kw-1.5 kw power level. if these works pretty good without modification, then this kit might be something good after all specially with the bafang BBS02 being more expensive and have interanl controller issues.
emaayan   100 kW
Post by emaayan » Jun 09 2015 4:08am
so you gave up on your gng2015?
lantice13   100 W
Post by lantice13 » Jun 09 2015 4:51pm
no... I can't, I spent money on it already. :wink: might build another bike using this kit or if My GNG totally crapped out on me like what happened to my very first gng mid drive. I see potential on the design and the price is just right too. right now it's operating as it should with the new controller and the old style freewheeling crank set. almost $200 in upgrades already.... sigh....
emaayan   100 kW
Post by emaayan » Jun 09 2015 5:03pm
lantice13 wrote:no... I can't, I spent money on it already. :wink: might build another bike using this kit or if My GNG totally crapped out on me like what happened to my very first gng mid drive. I see potential on the design and the price is just right too. right now it's operating as it should with the new controller and the old style freewheeling crank set. almost $200 in upgrades already.... sigh....
the major weakness was the crank once i upgraded that to my custom one, the only thing that's failing are the spokes on my rear wheel.
lantice13   100 W
Post by lantice13 » Jun 09 2015 5:17pm
potentially the cyclone is cheaper after all the upgrades on the GNG..... it comes with an ISIS bb and crankset already....
jdevo2004   100 W
Post by jdevo2004 » Jun 09 2015 6:40pm
I feel like this kit has a lot of potential. With the right after market parts to fix some small problems it could be great. My only worry is the gears. Are they easy to replace? Are they cheap?
lantice13   100 W
Post by lantice13 » Jun 09 2015 8:25pm
from the photo of the gear box above, it should be pretty easy to replace them. they are held by circlips so you'll need circlip pliers. The gears replacement I would ask cyclone about availability. The gear box is used on many motor configuration that you can find on aliexpress as well so it's should not be a special/proprietary part just for this kit. you could also do what the guys with bafang geared hubs to prevent their gears from stripping. Replace one planet gear with a steel one. you do need to get someone to cut you a steel gear. memory serves right, there are members here that offer such service.
lantice13   100 W
Post by lantice13 » Jun 09 2015 8:32pm
here is a the thread about replacing one of the nylon planetary gear with steel one to prevent stripping. http://endless-sphere.com/forums/viewto ... etary+gear
lantice13   100 W
Post by lantice13 » Jun 09 2015 8:34pm
here is an example of another similar motor with the same gear box. http://www.aliexpress.com/store/product ... 22872.html
lantice13   100 W
Post by lantice13 » Jun 09 2015 8:36pm
and even GNG use a similar looking gear box on their trike conversion kits. http://www.gngebike.com/36v500w-brushed
dekes1   100 mW
Post by dekes1 » Jun 10 2015 12:21pm
As noted above, I have this kit installed on a late-90s hard tail mtb. I can't say for sure that the plastic gears will have a long service life, but I can say that they have handled over 2500 watts of power with my fat a$$ with no problem. I recently opened up the gearbox to see how well it was lubricated and the gears had only minor noticeable wear after about 550 miles. I suspect they would be good for a few thousand miles and then could be replaced with the nylon gears readily available.
I'm still a little annoyed with the amount of noise under acceleration. I may buy the nylon gears and experiment with different lubes to see if it helps. Also, I had the drive chain pop off again during a very hard run from a dead stop - which was entirely due to the flexing of the mounts. I can take a video if anyone wants to see the amount of flex I'm seeing.
Fortunately, I recently built a CNC machine, so I hope to soon design a better mounting system.
On the positive side, I'm still impressed at the amount of power this motor can handle with no overheating. I downloaded a Powerlog6s log file from my ride yesterday and had burned through 7.4ah with long periods of 2400+watt draw and the motor was only about 95F when I ended the run.
