Huawei R4850G2 PSU RECTIFIER compact for 48v charger 3000w
Got something to sell? Have extra parts that need a good home? Have something that others would need to complete their kits? Post it up here and see if anyone else is searching for what you are selling.
antreou   1 µW
Post by antreou » Mar 03 2020 12:51am
Huawei R4850G2 PSU RECTIFIER.
Output is set at 53.5v 58amp on 240v input
It has been fully tested.
These can be used as PSU for charging batteries or DIY voltage needs.
They will need to have wires soldered onto the pins and 2 pins shorted to switch on.There is a lot of info on the web about the Huawei R4850G2 PSU RECTIFIER.
The output voltage can be adjusted from 42-58 but special program and hardware is needed.
They are £34 each
I have 4 available
They are quite compact and can be built into the bike or pack for charging anywhere.
It is 2kg packed and postage is £18 UK/EUROPE and £23 rest of world.
I ship from Cyprus.EXPECT POSTAGE DELAYS AS NO FLIGHTS.
antreou   1 µW
Re: Huawei R4850G2 PSU RECTIFIER compact for 48v charger 3000w
Post by antreou » Apr 19 2020 8:20pm
48v 54amp
john61ct   100 GW
Post by john61ct » Apr 21 2020 10:43pm
can you adjust to say 56 before shipping?
