$80 48v Battery packs with BMS, 48v 13s3p 10.5ah Panasonic/Sanyo NCR18650GA 10A 3500mAh Cells
Got something to sell? Have extra parts that need a good home? Have something that others would need to complete their kits? Post it up here and see if anyone else is searching for what you are selling.
Ellectrico   10 µW
10 µW
Post by Ellectrico » Jan 24 2020 5:05am
Selling lightly used 48v battery packs with 13s bms and NCR18650GA cells. Great condition.
Weight: 5lb
Connectors: Bare wires. Can solder a 7w2, xt30, xt60 or bullet connectors for additional price.
Cell Layout: 13 series 3 parallel
Measurements: Lenght: 15.5 Width: 2.7” Height: 1.5”
Nominal Voltage: 46.8V (Max voltage 52v)
Limited Charging Voltage: 54.6V/3A
Resistance (23 ± 2 ℃): ≤ 250mΩ
Charging time: 4-5 hours
Nominal Capacity: 10.5Ah
Watt Hours: 491.4Wh
Minimum wattage output: 500w
Amount of cells: 39
Cell manufacturer: Panasonic-Sanyo
Cell Size: 18650
Cell model: Panasonic-Sanyo NCR18650GA 3500mAh
$15 flat shipping for USA customers, calculated shipping for international
IMG_6937 (2).jpeg (79.12 KiB) Viewed 534 times
999zip999   100 GW
Re: $80 48v Battery packs with BMS, 48v 13s3p 10.5ah Panasonic/Sanyo NCR18650GA 10A 3500mAh Cells
Post by 999zip999 » Feb 17 2020 3:46pm
What amp discharge does the BMS support ?
