No Solder, No welding 48v 20Ah. Cheap battery Pack
bik-e-bik-e   100 µW
100 µW
Post by bik-e-bik-e » Dec 02 2019 6:45am
Please find the new design here in video. Please comment on the design.
https://www.youtube.com/watch?v=_ZgndwUQ4Eo
john61ct   100 GW
Re: No Solder, No welding 48v 20Ah. Cheap battery Pack
Post by john61ct » Dec 02 2019 1:55pm
Video I find a waste of time.
Please post text version with diagrams, photos.
fechter   100 GW
Post by fechter » Dec 02 2019 2:34pm
Obviously the scooter worked, so it was a success. I'm sure the scooter runs much better than it did with lead-acid batteries.
I can't see from the video exactly how the screws holding the cells are arranged. There will be a tendency for the contacts to go bad over time or when you hit a bump in the road.
Used laptop cells are inexpensive, but you run an increased risk of fire when charging. Charge outdoors in a place where a fire won't do any damage.
bik-e-bik-e   100 µW
100 µW
Post by bik-e-bik-e » Dec 02 2019 11:30pm
Actually the screws are rolled with copper sheet contacts to act as a bumper. I would try to post a detailed image.
bik-e-bik-e   100 µW
100 µW
Post by bik-e-bik-e » Dec 02 2019 11:40pm
Hope This helps a little
bik-e-bik-e   100 µW
100 µW
Post by bik-e-bik-e » Dec 02 2019 11:57pm
Another Image with full assembly
WhatsApp Image 2019-12-03 at 10.23.17 AM.jpeg (92.23 KiB) Viewed 2537 times
MAXIMUM_AMPS   10 mW
Post by MAXIMUM_AMPS » Dec 05 2019 5:08pm
Wow, very substantial bus-bars.
How is the voltage drop under load? Judging only by the pics, I would think that the interface between the cell and the bars would impede the performance a bit.
Matador   10 kW
Post by Matador » Dec 05 2019 10:12pm
Don't drop a metal wrench in that trunk with the battery inside... :shock: :warn: :flame: :kff:
Your build reminds me my first solderless battery attemps with plexiglass, copper bussbars, brass nuts and bolts and contact springs:
viewtopic.php?f=31&t=87434&start=25#p1277444
bik-e-bik-e   100 µW
100 µW
Post by bik-e-bik-e » Dec 06 2019 12:57am
In fact my design got inspiration from yours Matador. I am improving my design now with a top cover. and a more compact one. will keep you posted on it.
bik-e-bik-e   100 µW
100 µW
Post by bik-e-bik-e » Dec 06 2019 1:08am
Hope these views helps..
MAXIMUM_AMPS   10 mW
Post by MAXIMUM_AMPS » Dec 06 2019 1:12pm
bik-e-bik-e wrote:
Dec 06 2019 1:08am
Looks like a clever design! I take it those "pillars" provide the necessary clamping force to get a solid connection?
bik-e-bik-e   100 µW
100 µW
Post by bik-e-bik-e » Dec 08 2019 10:52pm
MAXIMUM_AMPS wrote:
Dec 06 2019 1:12pm
bik-e-bik-e wrote:
Dec 06 2019 1:08am
Of course those are 10mm PVC Rods. They should hold it firm. I am in process of building it. Will update once done.
frenchie   1 mW
Post by frenchie » Dec 24 2019 1:32pm
How much does it weigh??
Weight is everything in cycling to my mind (and to my body lol) :wink:
I want to come to India and buy a motorbike but I can't own one as a foreigner :(
SO maybe I can come over, kit out an electric cycle and try and make it back to Europe :lowbatt:
