Custom 5kW Vector (QS 205v3/Kelly/DNM)
Tony01   100 W
Re: Custom 5kW Vector (QS 205v3/Kelly/DNM)
Post by Tony01 » Feb 13 2019 2:51am
Looking good. I have the same cells but been lagging on my build. I opted to make bus bars from 6101 aluminum full round bar, .25" and .125" thick, gonna have them bolted together. I gotta make a build thread. gonna be 20s3p. Out of 60 cells I got 4 or 5 that were no good. I tried to blow one up by burning it, hammering, cutting, etc, it smoked and puffed a tiny bit but did not blow up like I hoped :roll: Watching your build :mrgreen:
I don't always listen to Pantera.... but when I do, SO DO THE NEIGHBORS :D
Bg-electric-cycle   1 W
1 W
Post by Bg-electric-cycle » Feb 17 2019 7:38am
Very nice build Sir, particular like the side wings.
I’ve also a Vector Typhoon, sitting next door an aborted first temporary build. Short from the long, 20” folder developed a crack, took the motor/wheel off fitted to the Vector, 52v 35Ah battery and the new charger @ 72v wouldn’t charge via the buck transformer, doesn’t see any voltage. Seller confirms this is correct.
Wheels arrive this week.
Have you tried to fit an alarm to the kelly controller? That’s on a things to do list, see post in Ebike technical.
Awesome posts, and watch with a keen eye to the performance of those cells. :bigthumb:
Pb1302   100 mW
Post by Pb1302 » Feb 23 2019 4:08pm
Bg-electric-cycle wrote:Very nice build Sir, particular like the side wings.
Thanks. I have not fitted an alarm. I would like to get one that’s designed for a motorcycle or a moped. Something that alarms when you move the bike and sends me a notification on my phone.
Pb1302   100 mW
Post by Pb1302 » Feb 23 2019 4:09pm
minde28383 wrote:Hi Pb1302,
Share you experience regarding 26650. Did you had chance to test it during winer?
https://endless-sphere.com/forums/viewt ... =3&t=98667
I have not assembled my pack yet. So no winter testing.
Pb1302   100 mW
Post by Pb1302 » Feb 23 2019 4:13pm
Ordered my nickel strip from China. Time will tell if the purchase was worth it. It is a bit wider than most you can find. I found 15mm wide strips. That should help get more current through on the strips once spit welded on. It’s .2mm thick. Ordered 10 meters. Should be enough. We shall see. Says it arrives in April. LOL. So I have time to wait and it’s warm by then too.
Once I get to spit welding I will post my progress again. Got sidetracked by other project and it’s cold so bike has been sitting not used.
Peterfr12   1 W
1 W
Post by Peterfr12 » Feb 23 2019 5:45pm
Hi Pete,
Where did you get your DC-DC 84v to 12v converter if you have already purchased it? and what is the output power?
Thanks.
Best regards,
Pierre
Pb1302   100 mW
Post by Pb1302 » Feb 23 2019 6:05pm
Peterfr12 wrote:Hi Pete,
Thanks.
Best regards,
Pierre
Pierre, here is what I got. It’s from eBay. It’s 15a so plenty for little led lighting and usb Charger for phone. I’m going to wire my horn to it as well.
https://rover.ebay.com/rover/0/0/0?mpr ... 3047381649
Pb1302   100 mW
Post by Pb1302 » Mar 03 2019 6:17pm
Got me some .2mmx15mm nickel strip finally. Let’s hope it works out good. Got it from China and it’s pure nickel. Pretty good price as well.
Now to finish this harbulary battery.
Pb1302   100 mW
Post by Pb1302 » Mar 05 2019 9:39am
Made me a block to assemble these easier. So much faster now. Almost done making the 7P packs. Then onto making two 10S packs so I can join them up and get to the BMS cable installation.ImageImageImageImage
Pb1302   100 mW
Post by Pb1302 » Mar 05 2019 2:02pm
Done with my 7P packs. Now onto the series connections as well as the interconnection and positive/negative leads. Then some BMS wiring and hope to have it done by the weekend.
Test fit into the bike and looks like I have plenty of room for the pack. Going to wrap it in kapton tape and then some neoprene sheets to give it some cushion. Later I will build me a sheet metal box and weld it up to seal it on 5 sides. I will leave one side to put together with rivets or screws or something so I can get u side. I just want it sealed up just in case there is a fire or issues with battery...I can eject it easily. Image
st35326   100 W
Post by st35326 » Mar 06 2019 7:25am
I did a Tracy to Fremont (recharge while having lunch in Livermore) ride last spring. Id be down for an area ride or fool around on a go kart or super Moto track.
litespeed   100 kW
Post by litespeed » Mar 06 2019 7:47am
Nice build.
Tom
Pb1302   100 mW
Post by Pb1302 » Mar 06 2019 10:49pm
So the series connections take way more time than I expected. It’s a slow process but I don’t want it to look like crap or have an incident with this much energy in the batteries. Taking my time. I’m done with 6 of the packs. Hope to have them all done by the weekend still. But I’m pretty sure I’m gonna run out of nickel strip. More is on the way from China. Pretty pleased with the quality of the stuff I have.
Also trying to decide on how to interconnect the two 10S banks to make my 20S pack. Maybe if I get 1/4” gap between the packs I can just weld on nickel strip in 3 layers to help out the bend but in essence just fold it over like a saddle on a horse over my 1/4” gap. Maybe just a piece of 1/4” plexiglass or rubber to help isolate it anyways. Otherwise I just solder in some 8ga cable and link it with bullet connections.
Pb1302   100 mW
Post by Pb1302 » Mar 06 2019 10:51pm
litespeed wrote:Nice build.
Tom
Thanks Tom. It’s been an adventure but fun of course. Learning a lot. Pretty sure I won’t ever build a battery again. So much time invested in it already.
shortcircuit911   1 kW
Post by shortcircuit911 » Mar 07 2019 11:44am
Really nice work. My battery build is on hold, buy will pick it up soon, definitely appreciate the detailed pics.
Cheers
1 W
Post by Bg-electric-cycle » Mar 10 2019 6:59am
Great to see some install DIY battery packs into Vector frames.
I’m going for four hundred cells. However, battery containment is the issue. Cannot find anyone that’s already been there it’s to the metal fabricator.
Pb1302   100 mW
Post by Pb1302 » Mar 10 2019 1:54pm
Bg-electric-cycle wrote:Great to see some install DIY battery packs into Vector frames.
Geesh that’s a lot of batteries. That thing is gonna be heavy as heck. I already know I’m not gonna like mine being heavier but I’m willing to deal with the extra power and range lol.
I have seen battery cases for sale online but not that size. Just a bit smaller. You ever consider no using those supports? I was going to use them on mine but decided against it due to space and me wanting to eventually get a box around my cells. You save about a row of batteries in space not using them. That is enough for space to make a box and some padding.
1 W
Post by Bg-electric-cycle » Mar 11 2019 3:45pm
Definitely considered glue rather than spacers. I like the idea of maximum air flow, ability to install a fan or two. Around my way ambient summer temps up to 30-40c isn’t unheard of.
The plan is to draw less than 1 amp per individual cell. The weight won’t be a problem the frame is robust and 3” tyres easy cope.
If the battery were too big could always reduce the size.
Have some mild steel already cut into a strip. Tomorrow try and create a template. The pack is exactly 170mm wide. Vector Bikes, quote the internal dimensions with the side wings 170mm. If an exact measurement this leaves no room for any box and requirement to reduce the battery size.
smeagol222   100 W
Post by smeagol222 » Mar 12 2019 8:48am
Pb1302 wrote:
Jan 13 2019 6:42pm
I got the same damn ones from my previous order on Amazon and figured all would be well. Not so much. The older set I got was very tight to get the cells in or out. It practically broke the spacer if you tried to take it apart. No big deal...until I tried to match up my older set with the newer set. They were redesigned...of course. So old set is a smidge smaller and won’t line up with new ones. So immediately ordered another 2 sets with the hopes they match the NEW set. Let’s see how that works out. Gonna post me a review on Amazon for those interested in doing the same brand.
Hey I have the same cells and ordered some spacers for Aliexpress and they are too small. Are there specific ones that fit these? Seems like LitoKala have a thicker shell than most 26650 cells perhaps?
First project small E-scooter upgrade 3kw 48v 45a https://endless-sphere.com/forums/viewt ... 12&t=86228
Current project medium E-scooter upgrade 8kw 72v 100.5a https://endless-sphere.com/forums/viewt ... 10&t=85164
Pb1302   100 mW
Post by Pb1302 » Mar 12 2019 6:55pm
smeagol222 wrote:
Pb1302 wrote:
Jan 13 2019 6:42pm
How many cells you doing?
I got mine on Amazon. Out of three batches, only one set fit great. I gave up on the spacers. That is why mine are just taped together. Once you spot weld them they are rock solid anyway. So it’s really about some air flow. The BMS has set points for the 4 temp sensors I will mount on the cells. Just gonna ensure that they are shut down when they get too hot.
Good luck with the spacers. My journey got expensive so I gave up.
smeagol222   100 W
Post by smeagol222 » Mar 12 2019 7:11pm
Ah okay makes sense- I only have a small amount for testing since the cells are so damn expensive even from Aliexpress, ill probably just tape them together for my testing with BBSHD 1000w mid drive setup. They are 50a burst and only 20a cont. right?
For my other project I just stuck with 300 cell 18650s in 20s15p and spacers seem to work well with that
Pb1302   100 mW
Post by Pb1302 » Mar 14 2019 6:46pm
smeagol222 wrote:Ah okay makes sense- I only have a small amount for testing since the cells are so damn expensive even from Aliexpress, ill probably just tape them together for my testing with BBSHD 1000w mid drive setup. They are 50a burst and only 20a cont. right?
I got 140 cells so that was pricey. But the power and range is well worth it. I’m just finishing the spit welding in the other half of the battery bank. My fingers and hands hurt. Lol. So many spot welds. It’s taking me about 30 minutes to join one group to another. But again...taking my time. I don’t need any explosions or bad welds. So far so good. Not about another hour of welding and then onto the BMS wiring. Once that is done...gonna warps it up and test charge it. Then for a spin to discharge the beast battery. Sun is out today in Northern California so cant wait for some riding.
They are 50a burst...and 20a continuous but I hope to only be doing that very few times in their life. I beat on it at 120a (about 17a each cell) so I’m under the limit by a few amps. I want this damn thing to last. Next battery is coming from EM3EV cause I ain’t building more.
Pb1302   100 mW
Post by Pb1302 » Mar 17 2019 1:56pm
Got the cells all connected in series. Not to do BMS and power leads. I think I’m going to attach “fingers” so to say to the batteries on each positive and negative end...then put on a parallel strip like I would in the parallel battery banks. Then I can solder to those strips without heat going directly to the cells. Gonna put together the finger bits, solder in some massive wires..lol and then spit weld those fingers to the cells like series connections. We shall see how that experiment works out. ImageImageImageImage
1 W
Post by Bg-electric-cycle » Mar 17 2019 3:01pm
Nice battery pack build.
Did that Malelectrics spot welder have any issues with .2mm nickel?
I’ve since had a prototype metal box built and reduced the battery pack size to 360 cells or 20s 18p. Yet to be final.
Keep us all up to date on the performance of these cells.
Pb1302   100 mW
Post by Pb1302 » Mar 17 2019 3:06pm
The welder did awesome. A few sparks here and there...but I blame that on my application of the tips to the strips and maybe impurities in the strip. Other than that and always making sure a good charge was on the battery...welds went great. It has been flawless when battery is charged well and I keep the tips in good shape. Only complaint I have really is the damn cables and tips you hold get really hot when doing so many welds at a time. Wish they had some plastic holders to dissipate the heat. KWeld does something like that but I like to have my tips separate. It makes welding some areas easy when you can separate the tips by distance.
