Giant Trance X1 build for MAX range
thundercamel   1 kW
Re: Giant Trance X1 build for MAX range
Post by thundercamel » Apr 30 2019 12:58pm
I read in the Phaserunner manual, that it has a wire that can be separated for regen on a separate throttle for analog braking control. If you have any old throttles laying around, I thought that might be fun to try. Otherwise the front brake regen will probably be good enough.
My Ebike builds - Existing bikes, affordable motor kits, self built 14s6p batteries - Now with more recumbent!
dirt huffer   1 W
1 W
Post by dirt huffer » May 02 2019 7:37am
thundercamel wrote:
Apr 30 2019 12:58pm
I read about that too. I might give that a try. So many options
How are you liking your Phaserunner regen? Can you adjust it powerful enough to lock up the rear tire?
thundercamel   1 kW
Post by thundercamel » May 02 2019 1:18pm
I wish I had a phaserunner. I just have two affordable affordable conversion kits, neither of which have I been successful with enabling regen yet. I was just reading the phaserunner manual in consideration for a car loan or two being paid off.
I actually just tested a pad on my controllers circuit board last night labeled EBS. It floats to 5 volt, but pulling it down to ground exhibited no behavior other than making the motor jump forward every time a brake lever was released. Totally bizarre!
Raketemensch   10 W
Post by Raketemensch » May 02 2019 3:27pm
I’ve seen a few people just setting up a button for the regen, but holding it down while riding downhill doesn’t sound like a lot of fun to me.
I’ll be interested in seeing what you come up with.
