Ruff Cycles Cafe concept
FarmerFpv   10 mW
Re: Ruff Cycles Cafe concept
Post by FarmerFpv » Jan 09 2020 5:10am
This is kinda how i want to do my battery encloser except I don't want it to cover the down tube, I might weld little tabs to mount the encloser too so it will look like it's floating in the frame sort of. I'll figure it out, I'm actually excited on working on that portion really considering aluminium or thin sheet metal so I can just have it all powder coated white afterwards just like my rims and hub motor will be, my forks are already white everything else is all black. I should probably start that thread, where would be a good place to post my rookie build?
FarmerFpv   10 mW
Post by FarmerFpv » Jan 12 2020 2:44am
Willow wrote:
Jan 07 2020 1:41am
some photos of one I'm doing now. Swingarms are widened to 160mm.
Where can i purchase the thick dropout or torque arm you have on that white frame with the leather bag? I am most likely going to need one for my build as I will be using re-gen.
Thanks.
FarmerFpv   10 mW
Post by FarmerFpv » Jan 12 2020 3:06am
Willow wrote:
Jan 07 2020 12:56am
not a drama. it can be done by hand very easy. I've spread them to 180mm without an issue.
Lay the frame on it's side on the ground. Stand on the swingarm side on the ground - near to the main frame. Pull the other side of the swingarm at the dropout end till it shifts a little., Flip it over and do the other side. Check the measurement and go again if needed. A little wider than required is fine and makes it easy to install motor. if it's not 100% equal it doesn't matter... just got to get the wheel aligned when it's in place. And they can be pushed back if needed. The steel is very forgiving.
a really fat tyre may interfere with the chain-line. I've run a 3inch motorcycle tyre on the rear without issue.
Get the bottom bracket adapter (sold by Ruff or Classic Cycles), which just pushes into the bottom bracket tube and allows you to run a modern cassette and a standard MTB crank
Bottom bracket adapter? Is that to switch from American BMX to BSA bottom bracket adapter? Are the mountain bike cranks wider than the BMX cranks or something? hopefully, they have 140mm crank arms in the standard MTB crank as the pedals will scrape the ground in turns. I'm not much of a bicycle bike had to look up what MTB meant, I've never had an interest in them until gas prices started rising out of control here in Northern California, Ended up buying 2 Nissan Leafs for the family a street-legal golf cart, we have been running solar power for 6 years now which is the best thing ever.
Thanks
Robert
Willow   10 kW
Post by Willow » Jan 12 2020 9:44pm
FarmerFpv wrote:
Jan 12 2020 2:44am
Willow wrote:
Jan 07 2020 1:41am
Thanks.
Both custom built.
Link to bottom bracket adapter - https://classic-cycle.com/drive/hub-cra ... opc-to-bsa
I can send you a CAD file for laser or water-jet cutting for the torque arms.
I can make you a leather bag for $200... or you can learn a new skill and buy some leather and make your own. Heaps of Youtube tutorials. Make the templates out of paper first, then cut the cutting templates from 3mm acrylic.... such as the below pic. Leather can also be laser cut.
FarmerFpv   10 mW
Post by FarmerFpv » Jan 19 2020 7:13am
Willow wrote:
Jan 12 2020 9:44pm
FarmerFpv wrote:
Jan 12 2020 2:44am
Willow wrote:
Jan 07 2020 1:41am
Thanks.
Both custom built.
The custom-built leather bag sounds tempting, as it will save me lots of time, let me figure out the battery size i need to run my system and order it then I will contact you. Sorry for the late reply I been on vacation getaway. Thanks for all this information, I did order the bottom bracket adapter and 150mm crank arms. I haven't ordered the bottom bracket cartridge yet as I may need a wide spindle to clear the battery?
Can you make leather bags in different colours like white or black or are they brown? This electric bike shop in Russia https://megavel.ru/category/aksessuary/sumki-kofry/ makes nice leather bags for Megavel bikes which I assume are Micargi bicycle clones or Vice Versa? Have you heard of them before? They make some nice looking E-bikes. I wonder how this guy managed to make his bottom bracket wider with spacers on the side of the shell to clear the battery box? https://www.electricbike.com/richards-tango-qs/ looks like he added some aluminium rings and I assume a longer spindle?
Will the leather bag you make have a lid on it? BTW thanks for the offer.
FarmerFpv   10 mW
Post by FarmerFpv » Jan 21 2020 12:14am
Willow wrote:
Jan 31 2018 7:44am
nice.
here is one I did a few years ago.
Wow, Willow, that looks like a real motorcycle with all that nice leather, Is that the leather bags you build? They look fantastic, seems you're very skilled at pretty much anything you do. I don't know how I missed that picture I didn't see it before. My Chrome browser doesn't show lots of pictures especially Photobucket and others. I've tried hotlink fixes but they only work for a while. Anyway, that board tracker looking bike you built is sweet!
FarmerFpv   10 mW
Post by FarmerFpv » Jan 24 2020 2:48pm
Why is it I always get an error message like a little triangle on the right-hand side when I try to upload pictures? I'm trying to post pictures of my build showing how I would like to place my battery and controller with templets I cut out of poster board.
Willow, I'm very interested in a leather bag but I have some questions. Hope I'm not too much of a bother to you. Thanks, bud.
FarmerFpv   10 mW
Post by FarmerFpv » Jan 30 2020 8:03am
Willow wrote:
Jan 12 2020 9:44pm
FarmerFpv wrote:
Jan 12 2020 2:44am
Willow wrote:
Jan 07 2020 1:41am
Thanks.
Both custom built.
Hi Willow, are you still around? I'm very interested in the leather bag.
Thanks
