Kionic   1 mW
Re: Your Creation's Before & After Pics
Post by Kionic » Oct 07 2019 12:26am
jansevr wrote:
May 27 2016 6:59pm
QS 205 v3 + 17" rim + 100/80 tire
36fet 4110
20s 20ah LiPo
Loved this one Man, Some more big photos please.
methods   10 GW
10 GW
Post by methods » Oct 21 2019 12:34pm
recumpence wrote:
Sep 22 2019 6:07am
Hey Dude,
Long time no speak! How are you these days?
Matt
Living the dream brother . . . Thanks for getting me into that KMX years ago. It was a great life experience.
I still consider the Tadpole to be my favorite platform
The only drawback is how wide they sit. . . something like the above can cut thru really tight spaces and get you anywhere
Ok - maybe not anywhere once you start pulling a load. . . but. . .
Everybody starts somewhere.
My first bike was a Cruiser on 24S 4.5Ah of no-label Hobby City packs
(it was Hobby City before Hobby King)
Kelly controller. . . thing literally was spinning axles out of the biggest hubs we could get at the time, where were xlyte.
.. Has come a LONG WAY
Was just over at Google and saw a ton of bikes (hundreds)
Mid drive
Hub drive
You name it
and
In Santa Cruz
We have surpassed the 50% mark
You WILL see more mid drive ebikes than standard bikes if you drive around town for 5 hours.
Sweet
We won
Now I can die in peace
-methods
Increasing battery voltage and controller current limit will result in a non linear experience
harmonist   1 W
Post by harmonist » Oct 21 2019 2:48pm
Before upgrade
After upgrade
alphageek702   1 µW
Post by alphageek702 » Nov 30 2019 7:37pm
I just got this and I am going to use it as the base for a new build. The batteries in the frame are dead and there seems to be resistance when rolling in the motor. I also found the accessory pack for the rear. Was told the batteries are good and were repaired last year by EBike Market Place but that the BMS seems to be on the outs. I figured I might try to salvage what I have and add a kit from on line. Any suggestions for a kit would be well accepted. I am in Las Vegas, NV. USA.
Cbisbaf   10 mW
Post by Cbisbaf » Dec 20 2019 12:54pm
I had the bbshd on a voodoo bike previous to this but the frame snapped at the top tube. I spent about a week searching online trying to find the ideal bike for the bbshd 68mm, this one was on sale at chain reaction for £2000 and although my budget was 500 I thought I would go for it :lol: :lol: If I was gona do it though it had to be clean and in keeping with the bike so I switched out the big dpc18 with an sw01 and removed all the cutouts and throttle. I find the throttle nice but I like the clean look of this just waiting on the Luna mighty mini 30t then i can see how i stand with chainline. Also i had to cutout a bit of the frame to get it in, one of the chain guide mounts. For now the battery will be in my bag but I might 3d print something later.
ZERONEST   10 W
Post by ZERONEST » Dec 20 2019 10:19pm
Cbisbaf wrote:
Dec 20 2019 12:54pm
That's a really nice job! I have the same bike and would love to convert it! do you know how much you it set you back minus the bike?
Cbisbaf   10 mW
Post by Cbisbaf » Dec 22 2019 4:49am
ZERONEST wrote:
Dec 20 2019 10:19pm
Cbisbaf wrote:
Dec 20 2019 12:54pm
Bbshd: £600
diy battery samsung 30q 14s2p 300wh ish: £90
bms Bluetooth: £20
charger: 15
chain ring shipped: £45
display: £35
total :£805
moonkagliwicee   1 µW
Post by moonkagliwicee » Dec 27 2019 6:42am
My Kona Coiler 2005 :)
Theodore Voltaire   10 MW
Post by Theodore Voltaire » Dec 27 2019 11:32am
[quote=moonkagliwicee post_id=1518185 time=1577446963 user_id=67421]
[/quote]
Good job making a eBike that actually looks good enough to ride without being embarrassed to be seen on.
moonkagliwicee   1 µW
Post by moonkagliwicee » Dec 27 2019 11:52am
Theodore Voltaire wrote:
Dec 27 2019 11:32am
moonkagliwicee wrote:
Dec 27 2019 6:42am
Thanx :D Now I collect money for bigger accu and a new controller :)
grizzlyginger   1 µW
Post by grizzlyginger » Dec 27 2019 12:42pm
moonkagliwicee wrote:My Kona Coiler 2005 :)
What did you use to make the battery enclosure?
Sent from my moto z4 using Tapatalk
moonkagliwicee   1 µW
Post by moonkagliwicee » Dec 27 2019 1:28pm
grizzlyginger wrote:
Dec 27 2019 12:42pm
Polyester resin and fiberglass
moonkagliwicee   1 µW
Post by moonkagliwicee » Dec 29 2019 12:52am
And battery box inside :D 13s6p Sanyo ga 21ah, kt controller 40a and dc-dc converter for front lamp
bionx 1954   100 W
Post by bionx 1954 » Jan 03 2020 5:47pm
Before Firmstrong 26 in Beach Cruiser
After Norton Commando Replica E Bike
jpacadd   10 mW
Post by jpacadd » Jan 04 2020 9:00pm
It's great to see all of these custom builds.
Here is my little bike shop.
Up on the hook, built my old BBSHD powered 2009 Giant Trance X3 size large this past July, rode it a ton all summer and fall about 800 miles maybe 90/10% on/off-road, loved it. A few extras on it for my taste also. I am about 99% sure that I am going to add a 2nd battery mount under the downtube to double the range (swap the batteries will be a small PITA but less than peddling haha). I'll have 2x the same battery and 3 mounts, so I'll be able to run either a battery on each bike, if sharing, or 2 batts on the big bike if I'm going farther than usual.
Below that I just picked up off of ebay for a 2nd build to enjoy with friends and maybe flip after build, 2009 Giant Trance X4 size medium. It came with a nice dropper seatpost that I just swapped over to the X3 today. The same battery fits in the X4 medium BARELY! Likely go BBSHD again, but maybe hub, undecided. I'm considering upsizing the rotors to the same as the X3 and put more road oriented tires on it, so I could swap the wheels/tires for road rides on the X3 also, which should increase my speed and efficiency for road rides without the downhill tires.
Also in the last week I have added to the blue X3 a nice light weight rear rack, upgraded the rotors to 203/180 from 180/160, and swiped the dropper post from the X4.
:bolt: :bolt: :bolt:
20200104_203916 shrunk.jpg (391.19 KiB) Viewed 5259 times
Ghetto photoshop showing with the 2nd battery mount I intend to do, which would give me 35Ah @ 52V for pretty awesome range. I've been considering a custom trianglish battery, but I do like the clean look of the bottle mount type and ease of mounting. I still may do a custom battery but within this same case, just buy the battery and rewire it to higher voltage and/or upgrade or delete the BMS along with hack the stock controller.
Trance X3 Double Battery Photoshop.JPG (242.56 KiB) Viewed 5258 times
July 2019 first build: 2009 Giant Trance X3 with stock BBSHD 52V
Next build: Just bought used 2009 Giant Trance X4, likely BBSHD also, maybe hotter controller/battery, undecided
Lots of other fun toys: Wildcat X, Xtrainer, 1978 KE100, Hypermotard 1100
Storapa   100 W
Post by Storapa » Jan 06 2020 7:30am
Nothing too exciting, but this is my daily commuter. It's a Giant Toughroad SLR2.
Mac 8T motor in the rear (from the EM3EV).
Grin Phaserunner
Grin CA V3
Thun torque sensing BB with a rotary pot on the LHS side, under the bars to set the assist level (no separate throttle).
14s x 4p pack with BMS built using the excellent Sixpence spot-welder (Samsung INR 18650 - 3450 mAh)
I swapped from an Infineon controller to the Phaserunner. The difference was surprising. With the Infineon controller you could hear the motor as it spooled up under load. With the Phaserunner, the motor is silent. The tyres are the only thing that you can hear now. With the torque sensing BB and on the fly assist level adjustment, this makes a great ebike.
The battery, BMS, Phaserunner, charge port and ignition switch sit in the cradle that I built. This will now be painted and a frame bag made to cover it all.
Daily machine. - Giant Toughroad, Mac 8T, Thun torque sensor, Phase Runner, CA V3
Scratch built machine - Crystalyte HS 3540, 12 fet IRFB4110 Infineon controller, CA V3, 74v - 20Ah Lipo battery pack. https://endless-sphere.com/forums/viewt ... =3&t=75457
Monkeypowah   10 mW
Post by Monkeypowah » Jan 06 2020 10:33am
I melted the phase wires on my hub drive after botching a repair with 13amp house cable.
See the smoke on youtube
https://www.youtube.com/watch?v=BgBoRG2hmnk
Turbotd04   100 mW
Post by Turbotd04 » Jan 10 2020 2:21pm
DUBRAVKO wrote:
Apr 03 2019 1:54am
Before, and i got this bike with bad rear wheel..
And after restauration;
Best and most stealth one ive seen!
LJay   1 mW
Post by LJay » Feb 04 2020 6:23am
My Btwin Rockrider 520 conversion into a fitness ebike with Bafang BBS02B 48V/750W
and my Trek Roscoe 6 ebike build with Tongsheng TSDZ2 48V/500W
docw009   100 kW
Post by docw009 » Mar 04 2020 8:09am
Back in the realm of senior ebikes, before/after of a $250 Schwinn Loop.
Q100H motor, 17A KT controller, two 10S2P hoverboard packs with balance BMS hanging off rack and in parallel.
DogDipstick   10 kW
Post by DogDipstick » Mar 04 2020 8:42am
B4
After:
83.1v of Ironhorse XC.. :) :bolt: by Chevy :bolt: :D Broke 10 horsies :twisted: (..about 80% healed..).. :? Anybody.. what equals √3 times the line to neutral voltage? Asking for a friend.. :| (gottenymoem4115thangs?Yall?) :confused: Fabricator @ BSECo. Inc.
SlowCo   100 kW
Post by SlowCo » Mar 04 2020 9:44am
DogDipstick wrote:
Mar 04 2020 8:42am
After:
Great build but doesn't the front tire hit the battery box before full compression of the front fork?
DogDipstick   10 kW
Post by DogDipstick » Mar 04 2020 9:59am
SlowCo wrote:
Mar 04 2020 9:44am
DogDipstick wrote:
Mar 04 2020 8:42am
After:
I never : Removed spring to check full articulation; Nor: Bottomed out on a big jump, stairs, or fast Whoopdedos, hard Endos. The fork is a 26", tire is 24", so thats 2" extra there.. the frame's travel is designed around 5", ( for the designed 26" wheel, so there is 7")...
EDIT: I JUST checked:... Lol...
And yeah, I lied. I have been bottoming on big jumps. Lol. Dammmit. Time for a harder spring.
Ebikeotis   10 mW
Post by Ebikeotis » Apr 10 2020 2:04am
Hi guys. Finally got my bike done. Still need to sort out the wires but that’s not to tricky.
It’s a trek fuel x9 2010. 1000w motor. Had to modify the rear axle which I’m going to make a better one at a later date
Minimember   1 µW
Post by Minimember » Apr 11 2020 4:05am
https://youtu.be/xNTUzIoa2Wo
1954 Puch motorcycle converted to an ebike!
