Motor and controller wiring check-up
Electric cars, trucks, ATVs, NEVs - things bigger than a motorcycle.
M0tWat   1 mW
Post by M0tWat » Mar 23 2020 5:15pm
Hello everyone!
I'm working on an electric go-kart project and have just finished a mock-up/prototype of the wiring for the motor (Golden Motor HPM3000B) and controller (Kelly KBS72151E). For now everything's flimsy and quickly put together; I did it to get a general idea of how all the components will be wired together later on. Before connecting the batteries, I will connect everything properly - with adequate wires and terminals. Then I'd simply attach the positive terminal of my battery pack to the contactor and the negative to the black wire from the controller.
Before I do that, however, I'd like to ask you for advice. Can you spot anything missing from my setup (apart from the batteries, of course)? I've made several pictures, see attachments. I base my circuit on Kelly's manual (https://kellycontroller.com/wp-conte...UserManual.pdf).
I've already double-checked the white connectors. Also, I'm planning to add a fuse (with a resistor in parallel) on the B+ line for additional safety.
