Nucular electronics - complete kit for ev! [beta]
PITMIX   100 W
Re: Nucular electronics - complete kit for ev! [beta]
Post by PITMIX » Feb 10 2020 10:52am
Hi Vasili, I pre-ordered a 6F that I wanted to change to 12F, but do you think it's better to wait for the new 6F model ?
Aixam 550 Twin retrophite Qs 138 70H, Thermo-Nucular electronics 24F, LG Chem 20s 60Ah
VasiliSk   1 kW
Post by VasiliSk » Feb 10 2020 11:01am
Well it's up to you :)
You can send me order number in PM and i will change to 12F
SRFirefox   100 mW
Post by SRFirefox » Feb 10 2020 12:58pm
Thanks! Preorder placed!
serious_sam   1 kW
Post by serious_sam » Feb 10 2020 9:18pm
Hi Vasiliy,
Does it matter which phase wire the DC supply is connected to for charging ? Thanks.
Which Phase Wire.jpg (64.92 KiB) Viewed 2624 times
serious_sam   1 kW
Post by serious_sam » Feb 11 2020 4:41am
Thank you.
bikerpete   10 W
Post by bikerpete » Feb 12 2020 11:46pm
HrKlev wrote:
Jan 27 2020 8:23am
Has anyone tried running a Cyclone 3000w with a Nucular 6f? Just made an order for one, hope it is a good match.
Did you ever get any definitive answer about this?
I'm planning the same - it looks like there should be some headroom on that controller, but I'm on my first build so want some hand holding :wink:
HrKlev   100 mW
Post by HrKlev » Feb 13 2020 10:51am
They recomended a 12F on a 3kw motor, so I put in a preorder for that. I do think I would have made a 6f work for the current build Im planning, but I know myself, so buying a 12f is probably a good idea anyway... 😬
lukashanak   1 W
Post by lukashanak » Feb 17 2020 5:25am
bikerpete wrote:
Feb 12 2020 11:46pm
HrKlev wrote:
Jan 27 2020 8:23am
I'm running 4kw cyclone with 12F. 10kw peaks. Cyclone with Nuc works well.
Cyclone 4kW mid drive + Nucular 12F + 18s lipo = 9kW of fun :twisted: :twisted:
bikerpete   10 W
Post by bikerpete » Feb 17 2020 5:47am
HrKlev wrote:
Feb 13 2020 10:51am
I've now moved to an LMX 30mm motor. Adam at LMX bikes told me he thought it would be a bit under powered on the 6F. Nucular said they thought the 6F would be OK. I need to decide if I would prefer compact controller or possibly more power.
I'll probably buy the insurance of the 12F, but for my build I suspect the 6F might just be OK.
john61ct   100 GW
Post by john61ct » Feb 17 2020 6:32am
I bet you could order both, sell the one you don't use without losing much if anything
PITMIX   100 W
Post by PITMIX » Feb 17 2020 6:57am
If you take the 12F, you can set it for 4 or 5kW to preserve the engine or 10kW for performance. If you take the 6F maybe you will want to take the 12F later for more power.
Ohbse   10 kW
Post by Ohbse » Feb 17 2020 1:03pm
100% buy the 12f. For what you're doing you will want the phase amps, power limit doesn't matter so much.
electraflyit   10 W
Post by electraflyit » Feb 18 2020 7:14pm
Hi,
Is there a link to what order number you are currently up to.
Gives us an idea of how far away our order is.
Thanks for a great controller and your online support. Can't wait to get mine.
Eddie
PITMIX   100 W
Post by PITMIX » Feb 19 2020 11:35am
Hi guys ! Can you give me an idea of ​​tuning to get the most economical operation possible for my 450kg vehicle. :roll:
A minimum of 85A battery is required to drive at 50km / h on a flat road.
VasiliSk   1 kW
Post by VasiliSk » Feb 19 2020 1:00pm
I suggest you to limit speed around 60kmh with %, not with power
Setup some medium phase amps like 250-350 and whatever battery
PITMIX   100 W
Post by PITMIX » Feb 19 2020 2:32pm
Thanks Vasili ! I will try :thumb:
Merlin   10 MW
Post by Merlin » Feb 19 2020 3:32pm
cosmetic bug report :D
Wattage overlays amps in Display.
it would be cool to have the option to change in Display watt to kw.
so low power users can use watts and high power geeks can use kw in display.
VasiliSk   1 kW
Post by VasiliSk » Feb 19 2020 3:50pm
yeah i noticed. will do
PITMIX try different stuff, it may be different
PITMIX   100 W
Post by PITMIX » Feb 22 2020 1:50am
Hi friends :D
Last night I did a little test with the settings in economy mode:
The consumption went from 101wh / km to 70wh / km on the same short route: cool:
Current setting in V1 = 85A battery - 250A phases - 100% speed - FW disabled => 70wh / km
Appropriate acceleration and maximum speed of more than 45km / h real.
Previou setting in V1 = 85A battery - 450A phases - 150% speed - FW= 30A => 101wh / km.
Good acceleration and maximum speed of 54km / h.
Another previous setting in V1 = 100A battery - 160A phases - 150% speed - FW = 80A => 95wh / km.
Soft acceleration and maximum speed of 54km / h.
Thanks Vasili :bigthumb:
PITMIX   100 W
Post by PITMIX » Feb 23 2020 8:02am
Hi !
I connected my little Gophret 6003 directly to charge the battery.
Now that my motor has a sensor on the winding I can use the controller to charge the battery.
On the controller, I set the battery voltage to 83v max, the charging current to 2.5A max. I set the engine temperature to 50 ° c max.
The Gophret is set to 60v and 2.5A.
Willow   10 kW
Post by Willow » Feb 24 2020 3:26am
PLS HELP
what is the name / model / type of plugs used in the back of the screen... I need to replace one and my searching is not fruitful.
Cheers.
Simon.
VasiliSk   1 kW
Post by VasiliSk » Feb 24 2020 4:22am
https://www.aliexpress.com/item/3283649 ... b201603_53
PHD 2.0mm
PNs:
http://www.jst-mfg.com/product/detail_e.php?series=201
to PITMIX:
If you are using engine speed below maximum, or there is strict battery/phase current limitation - FW will not work
Willow   10 kW
Post by Willow » Feb 24 2020 5:17am
Thanks V.
