Kinaye Motorsports
teslanv   100 MW
Kinaye Motorsports
Post by teslanv » Jan 18 2015 2:32am
http://www.kinayems.com
Kinaye Motorsports
North America Dealer for:
MXUS XF40-45H 45mm 3000W Direct Drive Hub motors (With Rim options you will actually want.)
12FET IRFB4110 Sine Wave Controllers
USA & International Sales for:
Farfle Swing Arm Version 2.0
Kilowatt Bag - The top-tube Saddle Bag for your LiPo Packs.
DD Hubs, Batteries, Controllers & Custom Ebikes.
http://westcoastelectrics.com
West Coast Electric Cycles
Bellevue, WA
USA
brooklands   100 mW
Re: Kinaye Motorsports
Post by brooklands » Jan 18 2015 5:51am
Do you have more information about the Kilowatt bag?
teslanv   100 MW
Post by teslanv » Jan 18 2015 12:48pm
Pricing:
MXUS XF40-45H 45mm 3000W Motors:
Windings I will stock: 21X3T (12 Kv), 16X4T (9 Kv), 10X6T (6 Kv)
Version 2 (Aluminum Stator, 0.35mm Lams)
Hall Sensors
KTY83-110 Temp Sensor
142mm Drop-Out Width
Black Color
Bare Motor: $320 + $30 Shipping to Continental US.
Lacing & Rim Options (All Rims laced with 10ga Spokes in 1-Cross pattern):
  • 26" Downhill Bicycle Rim http://www.jh-power.com/En_ShowPro.asp?id=162 Add $65 (Includes additional shipping costs, Available as Special Order Only. Non-Stocking)
  • 29er BIcycle Rim http://www.power-rim.com/en/product/Dou ... 5/609.html Add $65 (Includes additional shipping costs, Available as Special Order Only. Non-Stocking)
  • 1.6" X 17" Series 7000 Aluminum Type WM Moto Rim, Black Anodized Add $160 (Includes additional shipping costs, This Rim option to be stocked) [Pictured Below]
  • 1.6" X 19" Series 7000 Aluminum Type WM Moto Rim, Black Anodized Add $160 (Includes additional shipping costs, This rim option to be stocked.)
12FET IRFB4110 Sine Wave Controller: $125 including shipping within the Continental US.
Farfle Swing Arm Version 2.0: $250 + $20 Shipping to Continental US.
Designed to Fit the Genesis V2100 Full Suspension Frame, as sold by Walmart.
http://www.walmart.com/ip/26-Genesis-V2 ... e/22899847
Farfle Swing Arm V2.JPG (152.84 KiB) Viewed 1811 times
Kilowatt Bag: $80 Including Shipping within the Continental US.
1000D Cordura Exterior
12 lb. Nomex Interior Lining http://www.dupont.com/products-and-serv ... nomex.html
Top-Tube Saddle Bag Style attachement with Buckles & Handle for Easy Removal and carrying.
3/8" Closed Cell Foam Lined for battery protection.
Interior Dimensions (Approximate): 2 1/8" x 10 5/16" x 8 1/4" on each side. Total Volume = 361 Cubic Inches or 5.92 liters.
Can Fit (10 each) 4Sx5Ah Turnigy Hardcase batteries or (12 each) 4Sx10Ah Multistar batteries or (6 each) 6Sx16Ah Multistar batteries (Up to 2.3 KWH of energy!)
Pre-production Prototype photos (Buckles & Handle have since been added.)
Sorry for the lack of pictures. I will post as soon as the samples arrive.
Presale will begin Once I have received and tested the samples. (Early February)
Bellevue, WA
USA
DanGT86   10 kW
Post by DanGT86 » Jan 18 2015 8:07pm
Any info on the sine wave controller? Sounds interesting for $100!
999zip999   100 GW
Post by 999zip999 » Jan 18 2015 9:45pm
What amp rating will the controller support ? Does it have a plug for a C.A.
teslanv   100 MW
Post by teslanv » Jan 18 2015 10:26pm
999zip999 wrote:What amp rating will the controller support ? Does it have a plug for a C.A.
It is rumored to provide up to 60A battery current, and it does have a CA connector. Specs to be confirmed when I test the samples. Fingers crossed.
Bellevue, WA
USA
teslanv   100 MW
Post by teslanv » Jan 22 2015 11:48am
Speed & Thrust Charts for the MXUS 3000W Motors:
Bellevue, WA
USA
arkmundi   1 GW
1 GW
Post by arkmundi » Jan 22 2015 4:39pm
I'm interested in your 12FET IRFB4110 Sine Wave Controllers. The Kelly controllers, nor the Infineon controllers are sine wave. Would prefer if available. 60 amp phase current needed. More info please as I'm in the market right now. Any idea of when you'll have some in? Costs or approximation? Thanks.
teslanv   100 MW
Post by teslanv » Jan 22 2015 4:43pm
Presale in a few weeks. Availability in 6-8 weeks.
Bellevue, WA
USA
arkmundi   1 GW
1 GW
Post by arkmundi » Jan 22 2015 4:47pm
Must see specs please post or PM if you have them. Thnks.
teslanv   100 MW
Post by teslanv » Jan 22 2015 5:00pm
The Controller Specs are still unknown, other than I know it is a Sine Wave and it has 12 IRFB4110 FETS, and has a 3-speed switch for 20A/40A/60A Battery Current. Phase Current ratio is unknown, nor is it programmable.
I have a feeling the 3T motor will be too much for it, but I am hoping the 4T through 6T motors will work well with it.
Bellevue, WA
USA
chucho   1 kW
Post by chucho » Jan 22 2015 5:26pm
I hope you have good luck in your new aventure :!: :!:
Someone who does not doubt is a danger to the rest
9c+24slipo+60A lyen12fets+CAv3+26"hookworms=Fun commute
Cargobike+9c+13s33Ah=Fun transport
Kona entourage+ gng+ 40A lyen12fets+CAv3=Fun crosscountry
Flux+adaptto Max-e+Mxusv2+19" shinko= Monster fun Any Way
cwah   10 GW
Post by cwah » Jan 22 2015 8:47pm
Interested in the controller too.
Can I set regen power? What's the working voltage?
teslanv   100 MW
Post by teslanv » Jan 22 2015 8:56pm
The controller has 2 voltage versions: 40-75V and 56-90V. Both will offer up to 60A battery current. I do not yet have confirmation whether the 56-90V version will support 24S LiPo. I will be checking that when I get my sample.
Regen is standard, but it is not programmable.
Bellevue, WA
USA
spinningmagnets   100 GW
Post by spinningmagnets » Jan 23 2015 12:55pm
These look like good options for the marketplace....I wish you the best of luck.
Here's a farfle swingarm with a 20-inch wheel and a BHT motor (which is the same size as the Lightning Rods big block). BTW, em3ev's small triangle pack fits this triangle. You can get it with the 40A BMS using the Samsung 25R cells, 14.7-Ah
http://endless-sphere.com/forums/viewto ... 22#p883038
cwah   10 GW
Post by cwah » Jan 23 2015 1:59pm
teslanv wrote:The controller has 2 voltage versions: 40-75V and 56-90V. Both will offer up to 60A battery current. I do not yet have confirmation whether the 56-90V version will support 24S LiPo. I will be checking that when I get my sample.
I need max power for regen because most of the time standard regen is set to low. no way to get good regen?
eleven6   10 W
Post by eleven6 » Jan 23 2015 9:01pm
Definitely down to purchase 1 Kilowatt Bag. Are they available now? Just opened up a couple ebay bags that go in the same location today, and they ended up being much too small. BTW I'm minutes away if you do local pick-up..
I'll be watching for the results of the controller as well!
teslanv   100 MW
Post by teslanv » Jan 24 2015 10:25am
eleven6 wrote:Definitely down to purchase 1 Kilowatt Bag. Are they available now?
I just got the updated sample bag this week. There were a couple things that did not get made correctly, that I will want to remedy. But they are pretty simple changes.
Bellevue, WA
USA
tiny_n_terrible   100 W
Post by tiny_n_terrible » Jan 25 2015 12:39pm
I am interested enough to start saving up for a slow wind motor and the 19 inch motorcycle rim.
999zip999   100 GW
Post by 999zip999 » Jan 25 2015 2:53pm
Teslanv I'm willing to test the controller. When can you ship it. Ha Ha Sounds like a winner for lower power and no 9c whine.
teslanv   100 MW
Post by teslanv » Jan 25 2015 3:08pm
I will best getting the first one to test in a week or two. If it is good to go, I'll order some up. It will be at least a month before I have any to sell.
Bellevue, WA
USA
teklektik   10 GW
Post by teklektik » Jan 25 2015 3:46pm
Have you investigated getting the motors drilled for 13ga instead of 10ga spokes?
For those using bicycle rims, this seems like a more desirable option than resorting to washers to fix up the current design. This should be particularly useful when using smaller diameter rims where short spoke length requires thinner spokes for proper tensioning.
If larger gauge spokes are really desired, enlarging an existing hole is not too challenging...
And - ya - I know this is like arguing religion - but just asking anyway.... :D
DAND214   1 GW
1 GW
Location: About 1200 miles south of Chicago, in sunny/rainny Port Richey, Florida!
Post by DAND214 » Jan 25 2015 5:26pm
Very interested in a controller.
Dan
teslanv   100 MW
Post by teslanv » Jan 25 2015 9:06pm
The Samples can't get here fast enough...
Just out of curiosity, Is there any interest in MXUS' other DD Hub Motors?
I might be willing to bring in some other products including:
750W 28mm DD Hub - 12X5T, 9X7T, 8X8T and 6X10T
1000W 30mm DD Hub - 12X5T, 9X7T, 8X8T and 6X10T
1200W 35mm DD Hub - 16X4T, 12X6T, 8X8T
To keep it simple, probably just bare hub motors, for as cheap as I can possibly sell them.
Bellevue, WA
USA
teslanv   100 MW
Post by teslanv » Jan 26 2015 11:43am
Here is a Speed and Torque Calculator for the MXUS XF40-45H 3000W Hub Motor:
MXUS 3000W Calculator.xls
(36 KiB) Downloaded 316 times
Bellevue, WA
USA
