QS 3000w midmotor
larsb   1 MW
Re: QS 3000w midmotor
Post by larsb » Mar 22 2020 11:40am
There was a video linked, showing this motor at 30S or thereabouts. Would give 9000rpm or so with FW :bolt:
Highly unsecure info though, wonder what the heating is like at those rpms.
With 5 pole pairs it could still be possible considering the lower erpm compared to most motors.
Ride on!
PITMIX   100 W
Post by PITMIX » Mar 22 2020 1:27pm
this video is awesome : :shock:
Aixam 550 Twin retrophite Qs 138 70H, Thermo-Nucular electronics 24F, LG Chem 20s 60Ah
Maarkmo   100 µW
100 µW
Post by Maarkmo » May 26 2020 10:08am
Can someone tell me what the inner pulley diameter is? Or the Shaft diameter? Qs motors doesnt have any available right now with motorcycle shaft they only have them ready with the regular pulley, im wondering if i can find a sprocket that i can fit on there.
PITMIX   100 W
Post by PITMIX » May 26 2020 10:20am
Return to see on the previous pages (page 11) I put photos with all the dimensions.
Maarkmo   100 µW
100 µW
Post by Maarkmo » May 26 2020 11:27am
PITMIX wrote:
May 26 2020 10:20am
Oh wow you did all the hard work for me. Thank you! The measurements seem to be a little different each time you took it, but you said that the inner dimension of the pulley was 25mm is that correct? If this is the case then a sprocket with a 1 inch bore should be compatible with the shaft on that motor.
PITMIX   100 W
Post by PITMIX » May 26 2020 12:25pm
Please note the bore is tapered. 25 mm is for the flange seal
Maarkmo   100 µW
100 µW
Post by Maarkmo » May 26 2020 1:01pm
Yes I'm aware. I think a 1 inch bore will work ill let u know
