QS 3000w midmotor
PITMIX   100 W
Re: QS 3000w midmotor
Post by PITMIX » Sep 08 2019 11:39am
I checked the unscrewing is done well in anti-clockwise direction. I think my impact wrench is too weak.
Aixam 550 Twin retrophite Qs 138 70H, Thermo-Nucular electronics 24F, LG Chem 20s 60Ah
SlowCo   100 kW
Post by SlowCo » Sep 08 2019 12:06pm
It seems to be normal right hand thread indeed.
Looks like you'll have to remove the motor and find a way to clamp the pulley in a vice and then try to loosen the nut. As right now the pulley can move/rotate too much for the impact wrench to have enough effect. Heating up (torch) the nut just before trying to loosen it might help.
PITMIX   100 W
Post by PITMIX » Sep 08 2019 12:27pm
yes I think it's tight with red Loctite. Normally I can disassemble the alternator pulleys like this without any problem.
PITMIX   100 W
Post by PITMIX » Sep 10 2019 12:31am
It's good for me, I managed to disassemble the nut by hand with a 24 key and a claw key to lock the pulley. I also heated the shaft to remove the varnish.
larsb   1 MW
Post by larsb » Sep 10 2019 12:44am
Would you be able to measure the diameter of the shaft at the bearing (want to know inner diameter of bearing or bearing number)
Ride on!
PITMIX   100 W
Post by PITMIX » Sep 10 2019 1:32am
Sorry for the light :confused:
larsb   1 MW
Post by larsb » Sep 10 2019 2:48am
Thanks! Can you read out the part number of the shaft seal?
Ride on!
PITMIX   100 W
Post by PITMIX » Sep 10 2019 5:38am
Number is XJKD-TC-25-45-7-1
25mm interior
45mm external
7mm thickness
1 for a lip I guess :?
larsb   1 MW
Post by larsb » Sep 11 2019 11:38pm
Great, thanks! I guess main shaft diameter is 25 mm then. Good news as i am considering upgrading motor with an extended axle gearbox that currently is dia 25 :D
Ride on!
PITMIX   100 W
Post by PITMIX » Sep 12 2019 12:03am
Yes as you can see on my third picture in the message of September 10 at 8:32 the axis is 25mm and the size of the shaft seal confirms the measure.
PITMIX   100 W
Post by PITMIX » Sep 12 2019 12:14am
On my Microcar I use a reducer of 8:1 and I just needed to replace the engine pulley to lengthen the transmission to 6:1. The engine pulley will now have 30T instead of 22T. By replacing the reducer input pulley I will be able to adjust the transmission from 6:1 to 8:1 very easily.
larsb   1 MW
Post by larsb » Sep 12 2019 12:48am
I plan a two speed gearbox, gears will be direct drive and 1:2 and then a final reduction of 1:4 to the rear wheel.
Mated with the 3000w motor will give 220Nm 140km/h in direct drive and 440Nm 70km/h in first gear.
Ride on!
PITMIX   100 W
Post by PITMIX » Sep 12 2019 1:55am
Whaow !! Impressive !! :shock: :thumb: I am curious to see how you will make this gearbox.
larsb   1 MW
Post by larsb » Sep 12 2019 2:10am
Currently trying prototypes. My design concept works and i’ll order some driveable parts, if it’s still good then i’ll start a thread on it. :bolt:
Ride on!
j bjork   10 kW
Post by j bjork » Sep 12 2019 4:45am
Interesting :)
Are you constructing your own gearbox, or adapting an existing gearbox to the motor?
larsb   1 MW
Post by larsb » Sep 12 2019 5:42am
It’s a completely new design. That’s why there’s a high risk for surprises along the way. If it meets my specs it’ll be good for about 20kW@5000rpm
Ride on!
Grantmac   10 kW
Post by Grantmac » Sep 12 2019 12:25pm
A 2 speed box like that is EXACTLY what small EVs need.
erajomppa   1 mW
Post by erajomppa » Sep 27 2019 4:31pm
I found a great video of a moped fitted with this motor and it looks like a blast! check it out (not my video):
I do actually have a question though for anyone who has this motor (and all other experts):
I plan on fitting this motor to a small rear wheel drive car (of sorts), here are some specs I am aiming for:
-weight with a driver should be below 200kg.
-max speed of 60kmh. I don't NEED high speed, I want good acceleration and wheelspin on loose/icy surface. A sporty and fun feeling is key!
-20s LiPo battery (72~84V) 150A continuous current capable
-Meant for having a bit of fun at a gravel/mud/ice track. Google "cyclekart" if you want to know what kind of a vehicle I'm planning on building.
My chosen tire (17" rim motorcycle wheel, quite smooth tire) is 560mm total diameter, and I did do some math for it:
For 60kmh top speed (at 6000ish rpm) I would need gear reduction of 1 : 10.56 and I'd get 590Nm of torque at the rear axel.
This would most likely need a 2-stage reduction, or TINY front sprocket and HUGE rear one.
Is this realistic? Am I asking too much from this motor? Specs (peak power 14kW etc) seem to be OK, but I'm no expert.
The motor seems to be a GREAT bang for the buck, but is it good enough for what I want to accomplish?
larsb   1 MW
Post by larsb » Sep 27 2019 5:05pm
Yes. 590Nm is 590Nm, can’t go wrong there. Worst thing that could happen is that you want more, buy another motor, put it on the same axle for 1200Nm. That’ll be enough :wink:
Ride on!
erajomppa   1 mW
Post by erajomppa » Sep 28 2019 3:47am
In that case, I'd probably put one motor on each wheel ;)
PITMIX   100 W
Post by PITMIX » Oct 02 2019 1:52am
Hello someone use this engine at 8 or 10kW nominal ? I speak well of nominal power and not the peak power for a few seconds.
larsb   1 MW
Post by larsb » Oct 02 2019 12:14pm
Yes, never actually gotten it warm on the outside, 100-120A won’t be an issue.
Ride on!
PITMIX   100 W
Post by PITMIX » Oct 02 2019 2:18pm
Thank you 120A gives me a lot of margin.
Do you know the best place to install a temperature sensor ?
larsb   1 MW
Post by larsb » Oct 02 2019 3:32pm
never opened one but the windings should be reachable from the harness side if you remove complete side cover (not the hall sensor cover)
Ride on!
ZERONEST   10 W
Post by ZERONEST » Oct 06 2019 11:55am
Really interested in these motors from qs, does anyone have any experience with the 1000 and 2000w versions?
Seeing that some people have pushed the 3000w version to 15-20kw and 10kw continuous I'd love to know what the 1000 and 2000w versions would be capable of even as a rough estimate?
Also does anyone know if the 1000w version is available with a 420/428 sprocket/shaft anywhere?
Any advice would be great!
