Hoverboard Motor... extra Hall Wire
Telemachus   10 W
Post by Telemachus » Sep 23 2017 10:28am
This hover board wheel has been through a lot! :shock:
I took it off of a hoverboard that fell into a swimming pool months ago. Besides all the corrosion that makes it difficult to turn, I noticed that it has the three phase wires, five Hall wires, and one extra white wire. The white wire is separate than the hall wire connector.
Could it be a temperature sensor?
The motherboard that it was attached to has a separate white wire that plugs in right next to the hall wore connection but is not labeled.
2017-09-23 08.25.43.jpg (167.14 KiB) Viewed 905 times
latex   100 µW
100 µW
Re: Hoverboard Motor... extra Hall Wire
Post by latex » Jan 09 2020 11:57am
white wire is usually speed sensor wire
amberwolf   100 GW
Post by amberwolf » Jan 09 2020 1:54pm
separate speed sensor not needed on non-geared hubmotors, so probably not that.
meausre resistance from white to hall ground. put motor in sunlight or freezer or whatever, to radically change it's temperature adn watch reading. if it changes with temperatue it's a thermal sensor. if it goe sup with temperature its ptc, i it goes down it's ntc.
TommyCat   1 kW
Post by TommyCat » Jan 09 2020 4:12pm
Is there a light display hub on the outboard side? I've seen one use this wire for powering that.
Regards,
T.C.
See my completed Magic Pie V5 rear hub E-Bike build Here!
