Lesny   100 µW
100 µW
Re: KT motor controllers -- Flexible OpenSource firmware for BMSBattery S/Kunteng KT motor controllers (0.25kW up to 5kW
Post by Lesny » Mar 24 2020 1:44pm
Hi, I try develop my own lcd using arduino but I have problem with uart.
So I use the usb uart conventer and H TERM to check transmison but the controller dont send any data.
Do you know whats wrong?
Thanks for any help .
stancecoke   100 kW
Post by stancecoke » Mar 24 2020 2:15pm
Lesny wrote:
Mar 24 2020 1:44pm
The controller only sends data when it receives a valid message from the display. It "answers" to the query of the display.
Only in diagnostics-mode, it sends data continously.
regards
stancecoke
Lesny   100 µW
100 µW
Post by Lesny » Mar 24 2020 4:04pm
stancecoke wrote:
Mar 24 2020 2:15pm
Lesny wrote:
Mar 24 2020 1:44pm
regards
stancecoke
Thanks for tip.
Lesny   100 µW
100 µW
Post by Lesny » Mar 25 2020 9:47am
So I send to controller this data byte by byte 0012546011006464015014 but controller dont receive any data (I use bluetoth terminal). What I make wrong?
This is my code:
byte txBuffer[13];
byte assistlvl=0;
uint8_t crc = 0x02;
void setup() {
Serial.begin(9600);
txBuffer[0] = 0; //B0 od 0-40 konfiguracja odczytu napięcia
txBuffer[1] = assistlvl; //B1 poziom wspomagania od 0-6; 6 tryb walking
txBuffer[2] = 0b01111101; //B2
txBuffer[3] = 46; //B3 parametr P1 ilość magnesów x przełożenie (w przypadku kt open source wartość jest olewana ale coś trzeba wpisać)
txBuffer[4] = 0b00000000; //B4
txBuffer[5] = 0; //B5
txBuffer[6] = 0b00000000; //B6
txBuffer[7] = 0b01000000; //B7
txBuffer[8] = 0b01000000; //B8
txBuffer[9] = 0b00000000; //B9
txBuffer[10] = 0b00000001; //B10
txBuffer[11] = 0x32; //B11
txBuffer[12] = 0x0E; //B12
void loop() {
int i=0;
for (i = 0; i < 13; ++i){
crc ^= txBuffer;
txBuffer[5] = crc;
for (i=0;i<13;i++){
Serial.print(txBuffer);
davideserin   1 W
1 W
Post by davideserin » Mar 25 2020 10:17am
stancecoke wrote:
Mar 21 2020 1:01pm
There seem to be different PCB assemblies. Some have a pullup resistor at X4, some doesn't. See this post:
viewtopic.php?f=30&t=87870&p=1426450&hi ... r#p1426450
So you can try two solutions: Identify the pullup resistor on the pcb and remove it or add an e.g. 1k pull down resistor between X4 and GND. First solution should be preferred :wink:
regards
stancecoke
This worked for me, thanks so much. I simply soldered a 1k resistor at the back of the plug between signal and ground.
I have x4Throttle branch working now with both throttle on x4 and Sempu torque signal on the throttle input.
I noticed a few possible bugs that i'll report once i'm more familiar with the setup and can recreate and confirm the issues clearly.
Thanks,
David.
stancecoke   100 kW
Post by stancecoke » Mar 25 2020 10:29am
Lesny wrote:
Mar 25 2020 9:47am
What I make wrong?
First idea: You have to reset crc in each loop run, or calculate the checksum outside the loop. XOR2 is the last step normally, I don't know if it's a difference.
add a delay of 500ms in the loop.
viewtopic.php?t=73471
davideserin wrote:
Mar 25 2020 10:17am
This worked for me,
:thumb:
davideserin wrote:
Mar 25 2020 10:17am
I'm looking forward to your feedback!
regards
stancecoke
Lesny   100 µW
100 µW
Post by Lesny » Mar 26 2020 7:48am
Hi stancecoke,
The communications works fine but I have another question if I use OpenSource firmware which parameters from kt lcd3 is used by the controller ?
stancecoke   100 kW
Post by stancecoke » Mar 26 2020 8:22am
Lesny wrote:
Mar 26 2020 7:48am
Only light and assistlevel, see this post:
viewtopic.php?f=30&t=87870&start=3875#p1538316
Feel free to add any function to the parameters :wink:
regards
stancecoke
Lesny   100 µW
100 µW
Post by Lesny » Mar 26 2020 8:31am
stancecoke wrote:
Mar 26 2020 8:22am
Lesny wrote:
Mar 26 2020 7:48am
regards
stancecoke
hmm
it is possible to change the configuration so that the controller uses the speed setting sent by uart like ori firmware ?
stancecoke   100 kW
Post by stancecoke » Mar 26 2020 8:37am
Lesny wrote:
Mar 26 2020 8:31am
of course, if you progam it :D
But you can activate the offroad mode by the "morse code" with the break lever, so there is no need to change the max speed with the display...
regards
stancecoke
Lesny   100 µW
100 µW
Post by Lesny » Mar 26 2020 8:46am
stancecoke wrote:
Mar 26 2020 8:37am
Lesny wrote:
Mar 26 2020 8:31am
regards
stancecoke
I know but I would like to adapt the predefined driving modes and it would be easier to send the speed setting.
stancecoke   100 kW
Post by stancecoke » Mar 26 2020 8:47am
Lesny wrote:
Mar 26 2020 8:46am
If you want to have overall possibilities with your homebrewed arduino display, you should use the protocol of the BluOSEC app. With this you can change most parameters on the fly.
https://github.com/stancecoke/BMSBatter ... Odisplay.c
It uses the modbus protocol, for detailed questions you have to ask @Xnyle. The adresses of the parameters can be found in the BOdisplay.h
regards
stancecoke
Lesny   100 µW
100 µW
Post by Lesny » Mar 26 2020 9:46am
I think it is too complicated for me because I program only in IDE and mainly deals with the electronic part.
The only thing I need is to change the maximum speed to do what I assumed.
Do you know where and what I would have to change the OpenSource code so that the controller does not ignore this value from Ktlcd3 uart?
stancecoke   100 kW
Post by stancecoke » Mar 26 2020 10:05am
you are lucky, Xnyle has implemted it already, I hadn't noticed that before. :-)
Code: Select all
void digestLcdValues(void) {
	ui8_assistlevel_global = lcd_configuration_variables.ui8_assist_level + 80; // always add max regen
	// added by DerBastler Light On/Off
	light_stat = (light_stat&~128) | lcd_configuration_variables.ui8_light_On; // only update 7th bit, 1st bit is current status
	if (lcd_configuration_variables.ui8_max_speed != ui8_speedlimit_kph) {
		ui8_speedlimit_kph = lcd_configuration_variables.ui8_max_speed;
		eeprom_write(OFFSET_MAX_SPEED_DEFAULT, lcd_configuration_variables.ui8_max_speed);
regards
stancecoke
Lesny   100 µW
100 µW
Post by Lesny » Mar 26 2020 10:58am
stancecoke wrote:
Mar 26 2020 10:05am
Code: Select all
regards
stancecoke
So if I use the latest software and ktlcd3 protocol this should not be a problem with speed setting ?
stancecoke   100 kW
Post by stancecoke » Mar 26 2020 11:29am
Lesny wrote:
Mar 26 2020 10:58am
Yes, but I think it isn't prooved in hardware yet, as far as I know, Xnyle has no LCD3. So please report, if it works!
regards
stancecoke
Slipy   1 mW
Post by Slipy » Mar 26 2020 9:11pm
Hi, i made own pcb using s06s KingQeen... scheme for my scooter, a check all seems like scheme, but it didn't work, no any reaction,
Vcap ok
OC 4.3v
An8 1.6v
I phase 2.5v
Using Chinese stlink v2
Looks like a microcontroller doesn't start/work
Help please
stancecoke   100 kW
Post by stancecoke » Mar 28 2020 1:03pm
Slipy wrote:
Mar 26 2020 9:11pm
Help please
sorry, but without the use of a scope, you won't find the error. First check the output of the bootstrap circuit (gate of the hi-side FETs)
regards
stancecoke
Slipy   1 mW
Post by Slipy » Mar 28 2020 4:43pm
No any reaction, no any impulses on mosfet drivers, i think what microcontroller damaged if i can to ask you to do simple code for this stm, print on display uart hello word and enable all output ports as 1 (5v)
I will test it without HV part of pcb. I'm don't a programmer, only electronic, and make own home made scooter
Sorry for my English, I'm Ukrainian
obcd   100 W
Post by obcd » Mar 28 2020 5:21pm
If you use the stprog program, can you read the program memory from the microcontroller?
There also is a feature that the controller isn't starting up if one of the brake inputs is activated.
(It's starting up but not leaving it's initialising cycle.)
Be very carefull. If you activate both the upper and lower mosfet at the same time, they will short your power supply (or battery)
So it's best to at least disconnect the motor phase wires and use a current limited power supply or use a load in serie with your supply wires that limits the current. With the motor phase wires disconnected, the controller shouldn't use much current.
Vbruun   10 W
Post by Vbruun » Mar 29 2020 3:02am
Hello
I am looking for a controller to use @48v with a torque sensor. It seems this one will fit the bill!
I can't realy find any info on how the torque sensor input signal can be calibrated from the documentation i find. Is it possible to calibrate it?
- Victor
stancecoke   100 kW
Post by stancecoke » Mar 29 2020 4:11am
Vbruun wrote:
Mar 29 2020 3:02am
Yes, of course, but only linear. Throttle min is the offset and TQ calib the gain.
We don't use physical units for power/torque/cadence in the code to avoid unnecessary computations, but of course you can calculate them from the ADC and timer values, if you are really interested.
Slipy wrote:
Mar 28 2020 4:43pm
Just flash the controller in diagnostics mode, then you should see communication on the UART pins.
regards
stancecoke
Vbruun   10 W
Post by Vbruun » Mar 29 2020 6:17am
Thanks! I Guess the perfect way to do IT would be to also factor in the cadence in some way and calculate power, but I think this way Will be sufficient for what I am doing :)
stancecoke   100 kW
Post by stancecoke » Mar 29 2020 7:06am
Vbruun wrote:
Mar 29 2020 6:17am
The assistance is proportional to the riders power, not to the torque on the pedal:
Code: Select all
else { // torque sensor mode
	float_temp = (float) ui16_sum_torque;
	float_temp *= ((float) ui8_assist_percent_actual / 100.0);
	if (flt_torquesensorCalibration != 0.0) {
		float_temp *= flt_torquesensorCalibration / ((float) ui16_time_ticks_between_pas_interrupt_smoothed);
regards
stancecoke
