Motor Design Software
Pedrodemio   10 W
Post by Pedrodemio » Dec 08 2016 7:01pm
Hello guys,
I will shortly start a work in a research in my university to develop and manufacture a hub motor for electric skateboards, my goal is to optimize it as much as possible, since the application requires it or i will step on problems like overheating and huge consumption.
So to the point, what's softwares do all of you use? I fell in love with MotorSolve from infolytica since I've done a 4 day trial, it has everything I need, but after contacting them I discovered that even with a student license it's $1000 a year. Expensive? For what's it's capable I don't think it is, but the truth is that my research will probably no get that amount of funding and I don't have the money to pay from my pocket or it's not going to have money left for all the material and manufacturing costs
Any suggestions? I've found some open source softwares and MatLab routines, but neither of them comes even close in functionality
Thanks
spinningmagnets   100 GW
Re: Motor Design Software
Post by spinningmagnets » Dec 08 2016 7:09pm
I'd just pay Miles $100 for his advice, or...check out what the hotrodders are breaking over in the power board section. Many here find out what works by overloading several different types of available motors, and see what works, and what breaks (The Lotus method of design?).
"Stand-up E-scooters and E-skateboards"
https://endless-sphere.com/forums/viewforum.php?f=35
Pedrodemio   10 W
Post by Pedrodemio » Dec 09 2016 8:38am
That would be a way, but my mais objective is to learn something new, if in the end i can make a good motor that's great, but if the motor its not so good but i know what to improve or where i've screwed, that's even better
I've been following all the hubs on eboard section, from what i've seen from the DIY guys whats lacking is theory behind the design, application of engineering, the goal is not to make a lots of blind tests and by feeling decides whats worked best, but to design and test on the paper first and them, only when the design is mature go and make the real version
nieles   10 kW
Post by nieles » Dec 09 2016 8:52am
have you seen this?
https://www.emetor.com/
learningrc   100 mW
Post by learningrc » Dec 09 2016 9:50am
Typical software used in industry would be MotorSolve, Speed, RMExpert, JMAG-Express, and YES motor design software. There are others, but those are the main ones I've seen. A lot companies develop their own software. And, of course, in addition to this motor design software, most companies use general electromagnetic FEA software to complement these tools.
There is quite a bit of difference between some of these. For example, MotorSolve basically uses a simplified 2D FEA to solve the magnetics and then incorporates that into motor models. YES, on the other hand, uses lumped sum magnetic circuit analysis to solve the magnetics. Both have their place and their limits.
Miles   100 GW
Post by Miles » Dec 09 2016 1:31pm
MotorCAD is the industry standard for thermal analysis of motors but they now have an electromagnetic module that works in conjunction. All the commercial software is extrmely expensive. I would rough out the design in Emetor before choosing anything more sophisticated.
Pedrodemio   10 W
Post by Pedrodemio » Dec 09 2016 4:13pm
nieles wrote:have you seen this?
Miles wrote:MotorCAD is the industry standard for thermal analysis of motors but they now have an electromagnetic module that works in conjunction. All the commercial software is extrmely expensive. I would rough out the design in Emetor before choosing anything more sophisticated.
Nice, i've been playing with it in the last few hours, i think it's everything i need at least, as you said, in the first stages of this project
One thing i didn't figure out is to obtain a torque vs speed curve, it's not possible? so i have to run various speeds for a given design and interpolate?
learningrc wrote:Typical software used in industry would be MotorSolve, Speed, RMExpert, JMAG-Express, and YES motor design software. There are others, but those are the main ones I've seen. A lot companies develop their own software. And, of course, in addition to this motor design software, most companies use general electromagnetic FEA software to complement these tools.
Thanks a lot, it's what i wanted to know, unfortunately i guess most of them will be as expensive as MotorSolve. Ansys AIM have a promise to incorporate EM simulations on the student version, i will keep waiting
ecotech   100 mW
Post by ecotech » Dec 10 2016 4:14am
2D FEMM software is not accurate use a 3D solution look here http://www.cvel.clemson.edu/pdf/ACES09-736.pdf ofcourse you could use a wrong solution I've seen some motor designs in thesises that don't work.
Hummina Shadeeba   10 MW
Post by Hummina Shadeeba » Sep 18 2019 12:45am
spinningmagnets wrote:
Dec 08 2016 7:09pm
viewforum.php?f=35
I'd love to throw hundreds at miles to finish off A 15 tooth stator I've been doing in motorsolve. I somehow got a couple free trials but even still I don't know much about how to run it and their guide and YouTube videos aren't enough.
Other than finding the 15n14p combo having very low cogging torque I'm at a loss for how to go about designing and just modeled it on another stator I was using that was off the shelf and could afford.
Place will do a laser cut, so they say, prototype to confirm before doing the die.
