Car alternators as motors in practical applications, videos.
GeorgeJpindustries   100 µW
100 µW
Post by GeorgeJpindustries » Jul 05 2014 11:31pm
The drift trike
http://youtu.be/_TmlYlsgw1Q
http://youtu.be/c41pqhck4Lk
http://youtu.be/gKK7sdO6Jks
http://youtu.be/YpIt9cNQSPA
The go kart
IMG_2226.gif[/attachment Well , these two and three scooters , and a mower ( no pictures of those yet , sorry) are the living proof that Lundell alternator can be used as a motor reliably , efficiently , and best of all cheaply :D . Best way to share my observations is through a comparison with something we all know - 80/100 outrunners. So here is a list of pros and cons (it took me few years of bittersweet experience to come to these conclusions). [b]Turnigy outrunner:[/b] Pros: -small and light -torquey and powerful (2kw continuous in Australian summer is a max. though) -reasonably efficient (thin stator laminations - better for high rpm) -cheap Cons: -structurally weak (it must be mounted on a plate with auxiliary support bearing) -needs to be rewound with high temp wire -12mm shaft -low inductance and resistance , which makes it hard on the controller -high KV , even when terminated in wye and more turns than original -noisy ( I personally like the noise) Couple of pictures of probably the most elaborate 80/80 outrunner box in history :roll: [attachment=1]8080.jpg
8080 for razor e300.jpg (96.84 KiB) Viewed 1040 times
Alternators
Pros:
-bullet proof (designed to run at 15000rpm)
-massive bearings, and only two of them , not five like the outrunner(including the support one)
-no magnets - no risk of overheating and cooking them
-possibility of field weakening(from my experience this is only partially useful)
-more controller friendly inductance and resistance values
-low KV ( the one on the trike is about 40KV)
-good thermal mass , all aluminium too
-17mm shaft or bigger
-torque , even from mechanical standpoint, the one on the kart has a rotor diameter of 97mm compared to 80mm of the outrunners outer can
-silent running , even sensorless.
-well suited for high temperature operation
-cheaper (I have unlimited supply of free alts. :twisted: )
Cons:
-relatively big and heavy
-only some of them have stator laminations thin enough to be viable as a motor
-energizing the field consumes power (30-60w) , and it has to be around 12v (I have dc-dc converters on all my vehicles anyway though)
-the shaft is too short sometimes
-slip rings with brushes
Plus then there`s the argument of outrunner vs inrunner , but that`s irrelevant , because I use both of these motor configurations , depending on application suitability.
So how do I convert an alt? Here is step by step of what I do:
1.Identify a suitable alt. (ideally one with the lams exposed, to measure the thickness)
2.I rip off the rectifier (not always possible , because the brush holder is sometimes integral with the assembly) , exposing the phase wires.
3.Re-terminate in wye (unless already is), don`t bother with delta, trust me.
4.Solder wires DIRECTLY to the ends of the field exciting brushes, bypassing the voltage regulator. Reason to do this is, the back - emf voltage spikes induced into the rotor by the controller will over short time kill the regulator. Trust me, I know , this was a major headache for me when trying to make this to be reliable. Don`t worry, the field coil`s resistance will keep the current at about 3-4 amps at 12v.
5.Solder cables of equal length to the phase terminations.
6.Hook up to sensor-less controller , field coil directly to 12v supply and there is your motor.
Some observations:
I only run these sensor-less , with 12 fet e-crazyman controllers , that I fitted out with some decent silicon and capacitance and current set at 40/80,on the trike, it never looses sync , even starting from standstill uphill and going full throttle straight up. It just spins the wheel and takes off.
The trike runs 15s li-ion battery so fully charged , with voltage sag of 4v - about 2.3kw . It can run all day full stick , regardless of temperature , pulls like steam train , and heating of the altermotor is minimal. I`d estimate the efficiency of that particular alt. at 85%.
The one on the kart is worse however, running 24fet 4110 controller at 55/125A at 24s a123 lifepo4. At full charge that`s about 4.7kw , but from what i know , it only feels like 3.5kw is being transferred into mechanical work. Heating of that motor is pretty bad (it has zero airflow however). The kart still flies though :twisted: .
When choosing the alt. and it says 14v 105a for example , you`ll be able to feed it about 75A of phase current (70%) , 40 A battery,reliably in all weather conditions.
As you can see it really depends which one you pick to convert , newer Mitsubishi alts ,for example ,have two sets of three phases ( maybe 6 phase stator or double wye , i don`t know), but they have very thin lams (0.28mm) and massive stator width (50mm+) , 120mm rotor diameter and utilizing rectangular wire for maximum copper fill ,so worth investigating further.
Voltage over amperage every time.
Some of these have only single 1.6mm wire coming out of each phase ,after I terminate the stator in wye, limiting the current.
The xiechang controllers have very easy time driving these motors.
Result is virtually bulletproof system,both mechanically and electrically.
In conclusion , these motors are great if you`re on a budget , or just building a toy for fun, and the best efficiency is not you primary criteria.
Tench   100 kW
Re: Car alternators as motors in practical applications
Post by Tench » Jul 06 2014 4:29am
Thank you for joining the ES and sharing your work with the alternators, you have most certainly got a few people thinking about this now. Maybe a few pics to show how you reterminate the windings to help those that wish to try but have no previous experience of doing this would be a very big help.
Project one http://endless-sphere.com/forums/viewto ... ilit=tench
Project Two http://endless-sphere.com/forums/viewto ... =6&t=37489
The uk's first Stealth Bomber
There is a box inside your head, inside amongst others are the words "Wont fit" stop looking for answers in the box, there are no answers only excuses.
Harold in CR   1 MW
Post by Harold in CR » Jul 06 2014 7:17am
Newer Mitsubishi ? Compared to what ?? Year, model, vehicle type it came from, Amp ratings ?
There is another detailed tread on the forum, showing 6 wires from the stator. No mention of what this alternator was removed from.
Nice write up and good info.
As mentioned, photos would add a lot to this thread.
Thanks for posting. 8)
Thanks to Justin, the forum is open source and NON-commercialized.
Harold in CR   1 MW
Post by Harold in CR » Jul 06 2014 9:02pm
SOOOooooooooo, how many altermotors do YOU have running ??
litespeed   100 kW
Post by litespeed » Jul 07 2014 6:43am
What a great idea!
Tom
wb9k   10 kW
Post by wb9k » Jul 07 2014 12:04pm
Neat stuff! Got any video?
dh
2009 Prius with Hymotion L5 PCM
2008 Prius with Hymotion L5 PCM
2011 Rose Xing Fu 48V 500 Watt commuter scooter (now departed)
1984 Honda Interceptor 48V electric conversion motorcycle
Under construction: 2008 Miles ZX40ST truck with altered DC drivetrain
Departed: 2002 VW Jetta TDI which was run for a time partly on WVO.
Amateur radio station run entirely on solar/battery power.
"You can tell I'm a troublemaker, because I plug in my car."
parabellum   10 MW
Post by parabellum » Jul 07 2014 9:42pm
Nice, informative write up!
GeorgeJpindustries wrote:-only some of them have stator laminations thin enough to be viable as a motor
List or proved to work alternators with thin lams and some efficiency would be great. Thanks!
Skalabala   1 kW
Post by Skalabala » Jul 08 2014 2:41am
Some sort of info I was looking for! My stator that I want to use for a diy motor sucks :(
http://www.endless-sphere.com/forums/vi ... 30&t=58834
I would think if you can use two of those 50mm+ stators and make a neodymium rotor then you could end up with something good? :mrgreen:
Boosted cars are like hot women. A little edgy, every guy wants one, some guys can't handle them, and if you throw a little alcohol in them they'll rock your world! Born a Jap raised as a boer!
100 µW
Re: Car alternators as motors in practical applications, vid
Post by GeorgeJpindustries » Jul 09 2014 5:19am
Tench wrote:Thank you for joining the ES and sharing your work with the alternators, you have most certainly got a few people thinking about this now. Maybe a few pics to show how you reterminate the windings to help those that wish to try but have no previous experience of doing this would be a very big help.
Harold in CR wrote:Newer Mitsubishi ? Compared to what ?? Year, model, vehicle type it came from, Amp ratings ?
Harold in CR wrote:SOOOooooooooo, how many altermotors do YOU have running ??
Skalabala wrote:Some sort of info I was looking for! My stator that I want to use for a diy motor sucks :(
I have 5 altermotors running now : costumer`s evo 800 , stand up scooter , trike , kart and a mower.
I`ll try to put together more comprehensive write up , with photos.
Don`t bother with PM conversion, I have done one and it`s not worth it. The rotor never comes up as balanced as from the factory, magnets are expensive (this is a budget motor solution after all, if you have money buy a real motor) and you`ll lose one of the best features - field coil = extreme temperature operation capability.
I had one of these things at 138 degrees C in summer ( not due to the inefficiency btw , just pure abuse :twisted: ), at that temperature the magnets lose it quickly.
Skalabala   1 kW
Post by Skalabala » Jul 09 2014 6:13am
Picture or link of that 50mm stator please :P
Yes magnets are expensive :( Balancing is not a problem :)
Hmmm, now that I think of it... That rotor field is really strong! Actually like neodymium :?
IanFiTheDwarf   10 W
Post by IanFiTheDwarf » Jul 10 2014 7:03am
Apparently you can fit two ceramic magnets from microwave oven magnetrons to the rotor in place of the copper. It won’t have the torque of a neodymium rotor but you can salvage them for free.
Take care with stripping the magnetron as there is a little ceramic piece on the magnetron which is poisonous
http://cognizantwire.net/HTMLKHSL/ELECT ... GHouse.HTM
Never argue with an idiot, they will drag you down to their level and beat you with experience!
Skalabala   1 kW
Post by Skalabala » Jul 10 2014 5:54pm
ShadowNightmares   1 µW
Re: Car alternators as motors in practical applications, videos.
Post by ShadowNightmares » Jan 07 2020 11:26am
Sorry, i know that this topic is "dead" for a long time already, but i found it today and i loved your builds.
Do you still have your supply of alternators, and where are you from? (here in my country new ones with 85A+ are really expensive and used ones aren't easy to find, i'm thinking of trying to find alternators in other countries)
