TSDZ2 open source firmware only for KT-LCD3 (v0.19.0 / v.0.20.0beta1)
casainho   1.21 GW
1.21 GW
Re: TSDZ2 open source firmware only for KT-LCD3 (v0.19.0 / v.0.20.0beta1)
Post by casainho » Jan 24 2020 8:51am
mctubster wrote:
Jan 23 2020 11:17pm
The 850c code is still missing the polish of the LCD3, lots of missing bits, odo, soc, light flashing and so on.
You need to read the documentation!! Odometer and battery SOC are surely available and working very well.
Light flashing is not implemented because I do not consider a priority comparing to make SW102 firmware at pair with 850C.
- TSDZ2 OpenSource firmware
famichiki   100 W
Re: Tsdz2 open source firmware only for lcd03
Post by famichiki » Jan 25 2020 6:33am
mctubster wrote:
Jan 14 2020 1:51pm
1 - Measured voltage is too high. Likely due to a change buba made to improve the voltage measured but appears there is a constant that is wrong
Can you elaborate on this please?
michih.   100 mW
Post by michih. » Jan 25 2020 1:13pm
The 0.20 works perfectly with the lcd3! Thanks for the great software! The only thing I don't like is the wrong volt display.
Mfg Michael
famichiki   100 W
Post by famichiki » Jan 25 2020 5:59pm
michih. wrote:
Jan 25 2020 1:13pm
Mfg Michael
What are you findings and how have you measured them?
OSF is reporting 0.5V higher than what my bluetooth BMS reads, so if yours is the same then try these settings below.
The correction to BATTERY_CURRENT_PER_10_BIT_ADC_STEP_X512 was proposed by Stempelo on Github.
https://github.com/stempelo/TSDZ2-Smart ... a158532d4e
/src/controller/main.h
Code: Select all
// ADC battery voltage measurement
#define BATTERY_VOLTAGE_PER_10_BIT_ADC_STEP_X512           44
#define BATTERY_VOLTAGE_PER_10_BIT_ADC_STEP_X1000          86
// ADC battery current measurement
#define BATTERY_CURRENT_PER_10_BIT_ADC_STEP_X512           87
#define BATTERY_CURRENT_PER_10_BIT_ADC_STEP_X100           17
andrea_104kg   100 W
Post by andrea_104kg » Jan 26 2020 6:55am
version 20 beta 1 is practically perfect on lcd03. I think it would be interesting to make it compatible with lcd05, it's cheaper, small but not too much and easy to read and leaves room to put a smartphone on the handlebar.
On lcd03 the voltage is 0.3v higher than the real but it is not a real problem.
michih.   100 mW
Post by michih. » Jan 26 2020 8:32am
famichiki wrote:
Jan 25 2020 5:59pm
michih. wrote:
Jan 25 2020 1:13pm
Mfg Michael
Code: Select all
Thanks, unfortunately I have no idea what to do with it. On 13s is 1.1v higher.....
Can you send me a finished file?
Kt LCD 4 would be interesting
Mfg Michael
famichiki   100 W
Post by famichiki » Jan 26 2020 5:53pm
Open the firmware folder and navigate to the /src/controller folder.
Open main.h in a text editor.
Find these lines in particular:
Code: Select all
#define BATTERY_VOLTAGE_PER_10_BIT_ADC_STEP_X1000        87  // conversion value verified with a cheap power meter
I'm using 52V and reducing the X1000 value by 1 equals approximately -0.5V.
(87 / OSF reported voltage) * actual voltage = new X1000 value (round this up or down to get closest to actual voltage)
But at this stage I don't know if the discrepancy is the same for everyone, depends on battery type or varies individually.
So you will need to experiment with changing that 87 value, saving the file, re-compiling and flashing.
Note that BATTERY_VOLTAGE_PER_10_BIT_ADC_STEP_X512 is related, and calculated at..
(BATTERY_VOLTAGE_PER_10_BIT_ADC_STEP_X1000 / 1000) * 512
Manually calculate that and disregard the decimal places. For example, if you change X1000 to 85 then X512 will need to be..
(85 / 1000) * 512 = 43
In addition to there was a miscalculation with the ADC battery current values identified after the beta release.
BATTERY_CURRENT_PER_10_BIT_ADC_STEP_X512 should be 87 (not 102), being....
(BATTERY_CURRENT_PER_10_BIT_ADC_STEP_X100 / 100) * 512 where X100 = 17.
So, your values for those need to be as below.
Code: Select all
#define BATTERY_CURRENT_PER_10_BIT_ADC_STEP_X512         86
#define BATTERY_CURRENT_PER_10_BIT_ADC_STEP_X100         17  // conversion value verified with a cheap power meter
famichiki   100 W
Post by famichiki » Jan 28 2020 2:22am
I've made good progress with the motor overrun issue, the second video below is what I was previously experiencing in v0.19 and v0.20 initially had similar characteristics. Perhaps some motors are affected more than others, or maybe it just doesn't bother some people as much as me. But this is now a big improvement and I'm very happy. :D
For those who haven't seen what I was experiencing before...
Elinx   100 W
Post by Elinx » Jan 28 2020 2:41am
famichiki wrote:
Jan 28 2020 2:22am
I've made good progress with the motor overrun issue, .......
Nice to see that you have found at last a working solution and it isn't a hardware problem.
casainho   1.21 GW
1.21 GW
Post by casainho » Jan 28 2020 3:05am
famichiki wrote:
Jan 28 2020 2:22am
Great!! Can you please explain what was the issue and what was your solution??
michih.   100 mW
Post by michih. » Jan 28 2020 10:33am
Cool, we need the software including the volt adjustment.😁😁😁
Mfg Michael
famichiki   100 W
Post by famichiki » Jan 28 2020 6:14pm
michih. wrote:
Jan 28 2020 10:33am
Mfg Michael
I will test this for a while to make sure there are no problems, but I've posted all the info about doing the volt adjustment because that will possibly vary for everyone. Once we get some reports back from people about their adjustment then we can determine if the code should be updated.
michih.   100 mW
Post by michih. » Jan 29 2020 3:41am
famichiki wrote:
Jan 28 2020 6:14pm
michih. wrote:
Jan 28 2020 10:33am
Mfg Michael
I saw the volt adjustment. but unfortunately I can't do it.
mfg michael
michih.   100 mW
Post by michih. » Jan 31 2020 2:18am
now it works with this value:
#define BATTERY_VOLTAGE_PER_10_BIT_ADC_STEP_X512 43
# definiere BATTERY_VOLTAGE_PER_10_BIT_ADC_STEP_X1000 85
big thx!!!!!!
mfg michael
casainho   1.21 GW
1.21 GW
Post by casainho » Jan 31 2020 2:21am
@famichiki, can you please explain what was your solution for the overrun issue?
casainho wrote:
Jan 28 2020 3:05am
famichiki wrote:
Jan 28 2020 2:22am
thineight   100 W
Post by thineight » Feb 09 2020 7:58am
Hello, quick question on v.20 beta1 (buba) + LCD3 display.
Is the cruise working on your bike?
This is a function I practically never use, but I remember during the debug of buba's alfa versions the cruise was working just pressing the DOWN button while the bike is 10+ km/h, in that case the bike was keeping on going the actual speed even without the pedal rotation.
Now on beta1 (never tried the cruise) I am not able to switch the cruise on. Walk assist is working as intended, I'm saying that because the procedure to activate walk assist and cruise is exactly the same, depending on the bike speed.
Thanks for the feedback.
MTB KTM Ultra 29" - City bike DAYTONA 28"
Waynemarlow   1 kW
Post by Waynemarlow » Feb 09 2020 10:40am
In the V20 you have to activate the cruise function in the setup screen, I think it’s default is off in the initial setup.
thineight   100 W
Post by thineight » Feb 09 2020 12:33pm
Waynemarlow wrote:
Feb 09 2020 10:40am
Of course it is activated. The relevant submenu 0 has value 1.
Do you confirm that after you press DOWN for a second or so your cruise starts working?
Waynemarlow   1 kW
Post by Waynemarlow » Feb 09 2020 2:53pm
thineight wrote:
Feb 09 2020 12:33pm
Waynemarlow wrote:
Feb 09 2020 10:40am
Sorry I have never used the cruise function and have mine disabled. Unfortunately my motor is US at the moment ( water ingress from a damaged plastic side cover ) and awaiting delivery of a controller from PSW ) so can't test for you.
mctubster   100 W
Post by mctubster » Feb 09 2020 3:12pm
thineight wrote:
Feb 09 2020 12:33pm
Waynemarlow wrote:
Feb 09 2020 10:40am
Yes my cruise works. Beta 1. Double check the config including target speed
thineight   100 W
Post by thineight » Feb 09 2020 3:41pm
mctubster wrote:
Feb 09 2020 3:12pm
thineight wrote:
Feb 09 2020 12:33pm
Waynemarlow wrote:
Feb 09 2020 10:40am
Thanks, will check. To activate it, you simply press and hold the DOWN button, right?
Just for comparison, what are your settings for the cruise submenu?
0: 1
1: ?
2: ?
3: ?
Thanks a lot
mctubster   100 W
Post by mctubster » Feb 11 2020 5:10pm
thineight wrote:
Feb 09 2020 3:41pm
0: 1
1: ?
2: ?
3: ?
Thanks a lot
Yes hold the DOWN button over 10? km/h
0:1
1:1
2:25 km/h
3:1
mittkonto   10 mW
Post by mittkonto » Feb 17 2020 10:08am
0.20, makes every ride an early christmas. Can't wait to see what sw102 and 850c when its a bit more mature around the curve! I have seen the awesome torque calibration work that has been done, though my torquesensor is not health personified, I'm holding off a bit. Thanks devs and testers again!!!
By the wholesome Code Gods of Muchgivings!!? A tidy TSDZ2 spliced cable and a nice chunk of HIGO-Z812-B with a tad of temperature mods sprinkled on top, you say?
