Paratrooper Build
Fjp   10 mW
Paratrooper Build
Post by Fjp » May 09 2017 8:15am
Hello Everyone, fist time builder here trying to avoid a mistake! Looking for a rear DD hub motor that can handle 2-3000 watts. Having trouble determining which motor will bolt on to the 24 spd paratrooper using the existing disk brake without any mods. ElectricRider appears to be an option, but their motors don't have temperature sensors in them. Any suggestions would be greatly appreciated! Thanking you in advance, FJP
rojitor   100 kW
Re: Paratrooper Build
Post by rojitor » May 09 2017 3:33pm
My montague had a xlyte 5304 and 5306. The 04 was difficult to fit yet possible.
A 9c or mxus will do fine. 160 rotor is the best choice. 180 fits but is troublesome. You will need spacers and also stretch the arms a little. The tire is also something to mind. Wide rim+Wide tire will be very tight. I solved it decreasing psi.
migueralliart's torque arms fit very well.
My advice: mxus. If you go 26" use medium size tire. 160 rotor (put good hydraulic at the front)
cycleops612   10 kW
Location: Sydney Australia, Me: 70kg/154lb. 350w, 22kg ex battery, 24 speed axial mid-drive Bofeili MTB.
Post by cycleops612 » May 09 2017 8:01pm
Or, do 2WD using 2 x; more conventional, less wheel stressing, hub motors, front & back.
Fjp   10 mW
Post by Fjp » May 10 2017 8:35pm
Thank you both for your replies, it is greatly appreciated. Since this is my first build, I'm not up for the complexity of all wheel drive yet. Im trying to follow rojitor's advise and looking hard at the Mxus. Can I trouble you for a link or contact info on the torque arms you recommend..... his website comes up "can not find page". Cheers, Frank
rojitor   100 kW
Post by rojitor » May 11 2017 10:12am
Migueralliart https://endless-sphere.com/forums/viewt ... 31&t=49635 The curved one is perfect.
On the other side http://www.ebikes.ca/shop/electric-bicy ... rm-v4.html
You can use two ebikes.ca too but migueralliart's is a one piece thing. Strong and reliable. Perfect for your is mount.
Other option : you make your own if you can make steel works.
in case you do not care that much about high quality torque arms with a 3kw setup...call your lawyer before you do the first test ride and write your last will.
Also notice that ebikes.ca (justin) owns endless sphere. By buying them you are making a donation to keep this forum alive and ads-free
teslanv   100 MW
Post by teslanv » May 11 2017 4:01pm
Also worth verifying what axle is on the motor you ultimately purchase. If it's an M16 Axle (Some MXUS 3K-Turbo motors use this axle size), then the grin universal torque arms will not fit. (They are for M14 and M12 size).
DD Hubs, Batteries, Controllers & Custom Ebikes.
http://westcoastelectrics.com
West Coast Electric Cycles
Bellevue, WA
USA
rojitor   100 kW
Post by rojitor » May 11 2017 4:56pm
Yes. If you pick the turbo version you will need to grind off the torque arms.
https://fasterbikes.eu/en/parts/235-tor ... parts.html
This seller has 16mm turbo ready torque arms. I am not a big fan of that kind tho. Thin torque arms end up twisting.
Crossbreak has 16mm torque arms (not drilled) https://endless-sphere.com/forums/viewt ... break+16mm
I don't know if he has stock right now.
rojitor   100 kW
Post by rojitor » May 12 2017 6:36am
It seems the migueralliart's torque arms fit the 3k turbo.
Fjp   10 mW
Post by Fjp » May 13 2017 5:23pm
Thanks very much for all the help.... sorely need and greatly appreciated!
Frank
