Qulbix Raptor 140
Sean9002   1 kW
Re: Qulbix Raptor 140
Post by Sean9002 » Apr 05 2017 7:53pm
atarijedi wrote:Hey guys,
Just a few questions. I'm finally buying more of the bicycle side components now, and I don't know a lot about bicycle stuff. So some specs first:
Raptor 140 Chassis with the 165mm dropouts
QS 205 50H V3 motor
Warp 9 21x1.85" front rim, 18x2.15" rear rim (waiting for these to show up in mail)
Shinko 241 21x2.75" front tire, 18x3.00" rear tire
I have a 3 ring and 5 ring freewheel for the rear, also waiting for them to show up in the mail.
and I weigh about 205lbs.
1. How many of you use a 10.5" x 3.5" rear shock? Any using a Cane Creek DB? I was looking at getting the CCDB + 400lbs coil. Any issues with length throwing off geometry or the shock hitting the chassis?
2. I was looking at getting an older set of new Manitou Dorado's 27.5". Anyone here running air suspension forks?
3. Anyone else running a TruVativ Hammerschmidt AM with crossbreak's chainring mod? I like the integral design, and being able to put a 38T chainring and then have 61T at the push of a lever sounds nice. Pricey though, although not as pricey as the Schlumpf.
The axle to crown measurement on the Manitou Dorado's 27.5 is going to change the head angle. Do you know what the sidewall height is on the 21 inch front, that will be a factor to the A-C measurement.
If you head over to http://bikegeo.muha.cc/ and enter the numbers for your frame and fork choices you will get a better idea of Axle to crown VS steerer angle less the added sidewall height.
OSET 20+ - Custom frame and swingarm, Motorims - 66V
Ruff Cycles Porucho - MXUS 3000w - whitewalls - Gloss black/Pearl blue/copper leaf - custom tanks - bobber saddle
Giant Glory 00 - Clyte X5404 - Hubsinks - 18FET Sinewave
Fuji Nevada S - MXUS 35mm- Hubsinks - 12FET Sinewave
39inch longboard Dual 50mm, 12s lipo
Vinsanity   10 µW
10 µW
Post by Vinsanity » Dec 20 2017 9:52pm
Bought his qulbix raptor 140 frame a couple of years ago and just finished this build. It has the HPC CROWN motor with hubsink cooling fins and Ferrell fluid. Cooling fins work. Battery is 72 volt X 26 amp/hr from LA ebike. Cable are nternally routed which need some custom holes drilled in the frame. Rear rim is a 19" X 1.6" moto rim with a 3.25 Chang Shen knobby. Front rim is 26" X 65mm Wienman with a Duro 3.0 knobby. Found a 90 volt headlight on eBay and installed a connector to direct plug into the cycle analyst. Installed a CRF70 rear fender, needed lots of cutting but work pretty well. Bike handles really good with good power. Lots of fun.
Mammalian04   100 kW
Post by Mammalian04 » Dec 21 2017 9:27am
Very nice!
Rix   100 GW
Post by Rix » Dec 21 2017 12:02pm
Vinsanity wrote:
Dec 20 2017 9:52pm
Great build, very nice indeed.
electraflyit   10 W
Post by electraflyit » Feb 21 2020 8:11pm
Hi,
I know thread is a bit old but can anyone point me to where i might find the rear brake adaptor, one thread on mine is stripped.
thanks Eddie
Mammalian04   100 kW
Post by Mammalian04 » Feb 22 2020 12:11am
Last time I needed an extra to mill down I had to order from Qulbix. Shipping is a bit expensive so you might grab any other nick nack parts you think you might need at the same time.
briangv99   100 W
Post by briangv99 » Feb 22 2020 4:14am
electraflyit wrote:
Feb 21 2020 8:11pm
Hi,
thanks Eddie
might be easier to find a helicoil kit from your local tool store and fix it.
MXXdriv   10 µW
10 µW
Post by MXXdriv » Feb 28 2020 1:37pm
electraflyit wrote:
Feb 21 2020 8:11pm
Hi,
thanks Eddie
You can use it from Shimano 203 mm rear disc adapter
electraflyit   10 W
Post by electraflyit » Feb 28 2020 5:22pm
I bought a Shimano 203 mm rear disc adapter and its too small.
I think the helicoil is the way i'll have to go.
thanks for the replies
