What throttle? Thumb or twist?
Chalega   1 mW
Post by Chalega » Jul 09 2013 10:12am
Hi guys,
So closing in on my first electric bike purchase. However, I need to choose my throttle: thumb, half twist or full twist. No freaking clue which one to pick.
Intuitively I feel that a thumb throttle would make it easier to brake n stuff since your hand is always in the right place. But I feel from my research that most people prefer a twist throttle? What do you guys think?
migueralliart   10 kW
Re: What throttle? Thumb or twist?
Post by migueralliart » Jul 09 2013 10:16am
I'm more used to half twist just because the thumb throttle is a bit bulky and makes my right shifter not so comfortable.
Full twist I could never use it myself.
Ykick   100 GW
Post by Ykick » Jul 09 2013 10:31am
Thumb if you can get the slim simple version sans LED's.
- Frank Sinatra
dogman dan   100 GW
Post by dogman dan » Jul 09 2013 10:32am
Half twist is my favorite. I kept breaking the tab off thumb throttles hitting a bump when holding WOT. More of a bad right hand with a mind of it's own problem, but half twist works best for me.
Thumb throttles work better with twist grip shifters, but my advice if you have those is to remove one of them, or get some trigger shifters, which work great with half twist throttles.
One option for twist shift, is put the rear shifter on the left side upside down, then do without the front shifter. Just leave it in one gear on the front.
Rassy   10 MW
Post by Rassy » Jul 09 2013 10:43am
I was a thumb throttle user for years, but now prefer a full twist with a thumb protrusion added so it's not always necessary to keep a grip on the throttle. Most of my experience is with recumbent bikes and trikes, so may differ somewhat from diamond frame setups.
-Rassy-
Two Delta Trikes equipped with a Bafang BBS02
viewtopic.php?f=28&t=88536&p=1291260#p1291260
Drunkskunk   100 GW
Post by Drunkskunk » Jul 09 2013 10:47am
Half twist. It works like a motorbike, and you won't have any problem keeping your hand in position for the brakes while using it. Plus you'll have a more solid grip on the bars than with a full twist.
I've found my thumb wants to fall asleep after an hour or so on a thumb throttle.
Trackman417   10 kW
Post by Trackman417 » Jul 09 2013 10:59am
Drunkskunk wrote:Half twist. It works like a motorbike, and you won't have any problem keeping your hand in position for the brakes while using it. Plus you'll have a more solid grip on the bars than with a full twist.
+1 with the thumb throttle. It is also harder to keep the bike at a steady speed than with a half twist or full twist.
K2 Sidewinder
H4065 36 mph
20s2p 10aH lipo battery pack
If it didn't kill you, it just built your character.
You know your bike is powerful when even you, the builder, can't control it.
Customer 00001 at our very own Bigmooses online store http://mtg-technologies.com/zencart/ Great guy, great products.
triggeraa   100 W
Post by triggeraa » Jul 09 2013 11:21am
Twist throttle for me. I rode motorcycles for years so used to it.
wesnewell   100 GW
Post by wesnewell » Jul 09 2013 1:15pm
I rode motorcycles too, but went with thumb throttle for bike and don't regret it. Setting cruise is easier. and no false throttle movement.
MAGICPIE3FOCUSPOWER   10 kW
Post by MAGICPIE3FOCUSPOWER » Jul 09 2013 1:17pm
Thumb for me!
Smaller and have full grip surface when handle the bike (while releasing throttle).
Nothing is perfect until I touch it...
DAND214   1 GW
1 GW
Location: About 1200 miles south of Chicago, in sunny/rainny Port Richey, Florida!
Post by DAND214 » Jul 09 2013 1:23pm
Have used all three and have decided that the Half twist is the easiest to control. With half grip solid it is a place to rest your hand and also hold the throttle at one speed.
Which ever you decide, buy an extra, there cheap but shipping for a second one later is not!.
Dan
jateureka   10 kW
Post by jateureka » Jul 09 2013 2:37pm
A thumb throttle can normally work on either the left or right grip. It's good if you are short on space on your handlebar. Work well with grip/revo shifters.
As for twist throttles, I prefer the 1/2 twist over a full twist for a couple of reasons. If you rest the outside of your palm on the fixed end grip and just use your thumb and forefinger to rotate the throttle you are less likely to accidentally bump the throttle. You are also less likely to damage a 1/2 twist it if you lean your bike against a wall or it falls over on the throttle side. Work well with trigger shifters or 3spd revo shifter mounted on the left.
You can get 1/2 twist throttles for the left side. They are used a lot on the Ezee electric bikes.
I have been riding motorcycles for 35 years and thought a control on the left would be wierd, but it didn't take long to get used to it & I actually prefer it now on the e-bikes where you have a heap of gears as I prefer the shifter on the right.
E-bikes: Bafang 8FUN; Mac; Ezee; FreeGo; Aprilia 7s LiPo; eLation V2; TerraTrike recumbent
E-motorbikes: ZEV 7100 LR scooter, 84V 60Ah LiFePO4.
ZERO 2011 S motorcycle, 51.8V 70Ah LiMno2, 2012 headlight, Kilovac EV-200 contactor
E-mower: EGO 56V mower & line trimmer
bowlofsalad   1 MW
Post by bowlofsalad » Jul 09 2013 3:23pm
Buy both, a couple of each type of throttle, try them out and see what you like best.
Chalega   1 mW
Post by Chalega » Jul 09 2013 4:37pm
^ That makes sense! Gna go with the half twist I think, and have a spare thumb throttle just in case. You guys are awesome, thanks!!
alsmith   100 kW
Post by alsmith » Jul 09 2013 5:22pm
Full width twist with one of these fitted helps relieve the aches from my hand, I found the thumb throttle caused really bad pains (I have spondylosis). They're not too expensive.
Rassy   10 MW
Post by Rassy » Jul 09 2013 6:18pm
Al, do you have a link for that thumb thing that goes on a full twist throttle? It sort of looks like what I do to my throttles, but looks slicker and probably functions a little better.
-Rassy-
skeetab5780   10 MW
Post by skeetab5780 » Jul 09 2013 6:27pm
does that mount to the handlebar or the throttle?
teklektik   10 GW
Post by teklektik » Jul 09 2013 7:18pm
A couple of minutes searching led to these versions on Amazon:
http://www.amazon.com/s?url=search-alia ... rampbuster
cal3thousand   1.21 GW
1.21 GW
Post by cal3thousand » Jul 09 2013 7:22pm
teklektik wrote:A couple of minutes searching led to these versions on Amazon:
Nice!
Get a Cycle Analyst and a Multimeter, you're still a noob if you don't have at least one of each.
Planning on posting questions or buying anything on this site? Put up your country (at minimum) on your profile. This is a worldwide forum and we haven't reached clairvoyance.
Ykick   100 GW
Post by Ykick » Jul 09 2013 7:26pm
alsmith wrote:Full width twist with one of these fitted helps relieve the aches from my hand, I found the thumb throttle caused really bad pains (I have spondylosis). They're not too expensive.
Motorcycle suppliers offer somethng similar called a "throttle rocker" and would probably work on similar size grips.
- Frank Sinatra
alsmith   100 kW
Post by alsmith » Jul 09 2013 10:58pm
It mounts on the throttle. I've seen a few different versions of it, an expensive USA sourced item that is available in different sizes, but I read it slips on the grip if pushed upwards. That's ok if you want to get it out of the way but it is a bit fiddly to get back in position- much safer to stop to do it.
The cheaper item stays put, but it's fine for me- it doesn't get in the way at all.
Anyway- link to the one I got:
(mine came with a silver flame graphic on it- but the thing is just a couple of dollars)
and once you know about them they become common!
alsmith   100 kW
Post by alsmith » Jul 09 2013 11:00pm
skeetab5780 wrote:does that mount to the handlebar or the throttle?
throttle
999zip999   100 GW
Post by 999zip999 » Jul 09 2013 11:27pm
Half twrist. Neat find on the thumb clamp on thing.
izeman   100 GW
Post by izeman » Jul 10 2013 7:00am
i have thumb throttles installed on all my bikes.
it doesn't give me that much wrist pain to operate
i can use the handlebars i like
needs some space - so it can be an issue to find enough space in case your shifters and brake handle are in the way
those are really cheap though. i have several of all types at home and did test ride them. you will always need a spare throttle if you have to do some controller testing/repair on your desk.
dogman dan   100 GW
Post by dogman dan » Jul 10 2013 7:17am
Spares are always good to have. For the longer rides, I jam the grip into the throttle a bit making it sticky. Then an open palm on the half throttle is all I need to hold it open. Po mans cruise control.
