Cycle Analyst + Cyclone stock controller throttle cutting off
DtiK   1 mW
Post by DtiK » Feb 09 2020 10:37am
Hello,
i have strange problem.
First of all, i have:
CA 3.1
Stock controller without programmability
Everything working but i have this problem:
every 1-2 minutes while driving, the throttle stops working after release and it is only restored by pushing the ignition switch back and forth :roll:
When problem comes, CA display shows there is throttle coming nicely in, and coming out.
What shall I do?
amberwolf   100 GW
Re: Cycle Analyst + stock controller throttle cutting off
Post by amberwolf » Feb 10 2020 1:52am
i can make some guesses, but need more info from you.
guesses first:
the most likely thing is the controller is timing out from a lack of a sensor input, probably a speed sensor; this is common on some kinds of controllers (programmable or not) that usually have their own lcd units.
second most likley is it is detecting overheating, or low battery voltage, etc. and shutting down.
other possibilities include the ca throttle output range is at the edge of or even outside what the ocntroller can accept, so the ocntroller shuts down when the throttle voltage goes outside the range.
now the more info:
did this system ever work, or has it always done exactly this since it was first assembled and turned on?
if it did ever work, exactly what happened (changed) between the time it worked and the time it started doing what it does now?
DtiK   1 mW
Post by DtiK » Feb 10 2020 9:52am
amberwolf wrote:
Feb 10 2020 1:52am
guesses first:
now the more info:
System is just assembled so problem has been always there.
I measured and throttle voltage goes from CA to controller just fine, so issue must be in controller. But I don't know what actual problem is, why it shuts down.
E-HP   100 kW
Post by E-HP » Feb 10 2020 10:16am
DtiK wrote:
Feb 09 2020 10:37am
CA 3.1
What is a stock controller?
Does the problem occur if you hook the throttle up directly to the controller?
DtiK   1 mW
Post by DtiK » Feb 10 2020 10:44am
E-HP wrote:
Feb 10 2020 10:16am
DtiK wrote:
Feb 09 2020 10:37am
CA 3.1
oops forgot to mention I have Cyclone kit.
Controller is Cyclone 36-72V/40A
DtiK   1 mW
Re: Cycle Analyst + Cyclone stock controller throttle cutting off
Post by DtiK » Feb 13 2020 12:08pm
yes it cuts off when throttle is directly connected to controller
TommyCat   1 kW
Post by TommyCat » Feb 13 2020 2:40pm
Have you tried it with the brake cut-offs disconnected? (low brake connections) And any other non-essentials whilst testing...
Regards,
T.C.
See my completed Magic Pie V5 rear hub E-Bike build Here!
DtiK   1 mW
Post by DtiK » Feb 13 2020 2:59pm
TommyCat wrote:
Feb 13 2020 2:40pm
Regards,
T.C.
I don't have them at use. So yes, they are disconnected. Wires cut off and shielded.
TommyCat   1 kW
Post by TommyCat » Feb 13 2020 3:24pm
What are the actual throttle voltages that you are reading going into the controller? (Closed and Wide open throttle)
DtiK   1 mW
Post by DtiK » Feb 13 2020 3:39pm
TommyCat wrote:
Feb 13 2020 3:24pm
~1.0V and ~3.6V
TommyCat   1 kW
Post by TommyCat » Feb 14 2020 5:11pm
My next step would be to get the bike set up in a static testing position having it properly secured with the back wheel off the ground. Then run it till the issue appears, clamping the throttle at 1/2 twist at that time. Effectively "sticking" it in the broken state. Then measure voltages at that time to verify...1)full battery power, 2) 5vdc controller power, and 3) throttle in/output. If all that checks A-OK... then carefully move the harness/connectors/wiring, pulling and pushing a bit at all locations to see if it will restart. Being wary at all times that the motor may start running.
Does this represent your system?
If so you may find more clues here...
https://electricbike.com/forum/forum/kn ... lone-3000w
DtiK   1 mW
Cyclone 3kw controller 70% current?
Post by DtiK » Feb 27 2020 3:06pm
Hello
Stock 40A controller has wires for configuring "70% current".
What for is it? Is it limited when wires are together or leave open?
DtiK   1 mW
Controller recommended
Post by DtiK » Feb 29 2020 2:21pm
Hello
I have cyclone 3000w motor
Cycle analyst
72v Battery pack
First 40A controller never worked properly, did total black outs randomly when throttle was closed.
Second 40A controller made bike running like on back of kangaroo (on same settings than first one)
Which controller do you recommend for EASY to configure and/or GOOD working out-of-the-box. Don't need any fancy things ...
DtiK   1 mW
cyclone running
Post by DtiK » Mar 01 2020 10:03am
what could cause this
https://www.youtube.com/watch?v=8oN-e6Owqhg
It's 3000w cyclone and black 40A controller without bluetooth/programmability
Accelerating = does that as on video
Accelerating on full power = goes ok for a moment
Speed limit enabled or power limit achieved = does that as on video
speed limits are disabled
throttle running on "current" mode
40A current limit
3000W power limit
flat tire   1 MW
Re: cyclone running
Post by flat tire » Mar 01 2020 8:06pm
The cyclone is a POS. Heavy, inefficient, big, made for bottom dollar and easily dies on overheat. It will always suck, even when it works.
Give it up, get a CYC X1 pro.
minimum   100 W
Re: cyclone running
Post by minimum » Mar 01 2020 10:32pm
I'd say it's either controller or BMS issue. No info on either one, so cannot help.
Nothing wrong with motor though.
ScooterMan101   10 MW
Re: cyclone running
Post by ScooterMan101 » Mar 01 2020 10:59pm
It is heavy , 10 lbs not including the cranks/freewheel that add another 2-2.2 lbs ,
However
In what way is it inefficient ? ( I do what to know since I have one the 2019 GNG )
What power levels ( amps and watts ) does it overheat ?
and
Have you tried the 2019 Cyclone 3000 watt one that GNG sells ?
That is reported to have solved many/the problems of the previous cyclone .
Regarding the X1 pro, I just went to the CYC website yesterday to see what the X1 Pro 2 ( which has necessary improvements over the X1 Pro Gen1 and the cost to the door to the U.S. is ... $ 1,048 !
The 2019 Cyclone 3000 watt that GNG gets to the U.S for around ... $ 650
Big difference price wise , , heavier than the X1 Pro gen 1 & 2, by about 2-2.5 pounds , but nearly half the price .
quote="flat tire" post_id=1533540 time=1583111196 user_id=36583]
[/quote]
My first conversion ... Sold
viewtopic.php?f=3&t=71378&p=1077497&hil ... 1#p1077497
It's 2018 already, ( now 2019 ) lets get some real , improved e-bike / e-velomobile / e-motorcycle designs .
DtiK   1 mW
Re: cyclone running
Post by DtiK » Mar 02 2020 2:28pm
minimum wrote:
Mar 01 2020 10:32pm
Thanks. This issue came after changing controller. But reason for changing controller was another issue with throttle (disappearing randomly).
Skaiwerd   100 W
Re: Cyclone 3kw controller 70% current?
Post by Skaiwerd » Mar 04 2020 1:30pm
You have to search the cyclone posts. This has been answered many times. If I knew I’d let you know but I know the information is there when I need it by searching. Pink wire and a paper clip is what I remember.
flat tire   1 MW
Post by flat tire » Mar 04 2020 7:45pm
Try it and see which one is weaker.
Tommm   10 kW
Re: cyclone running
Post by Tommm » Mar 06 2020 7:48am
DtiK wrote:
Mar 02 2020 2:28pm
minimum wrote:
Mar 01 2020 10:32pm
Thottle wiring needs to be checked.
Was the acceleration ok with previous controller?
Test this controller with the wheel in the air.
DtiK   1 mW
Re: cyclone running
Post by DtiK » Mar 06 2020 7:53am
Tommm wrote:
Mar 06 2020 7:48am
DtiK wrote:
Mar 02 2020 2:28pm
minimum wrote:
Mar 01 2020 10:32pm
checked.
yes it was.
wheel on air = seems to run ok.
I replaced controller with new one (xld brainpower), and now it runs OK!??!.
So faulty controller maybe.. brand new though :cry:
minimum   100 W
Re: cyclone running
Post by minimum » Mar 06 2020 8:45am
I guess it was a sinewave controller, which are sensitive to c3k motor "ghost hall signal" issue, discussed already a while back.
Either generic trap controller or nucular (which filters out those false signals) runs fine.
DtiK   1 mW
Re: Cycle Analyst Repair
Post by DtiK » Mar 12 2020 7:49am
What could cause this:
First came this:
No output voltage to "throttle out" (but on screen it shows there should be)
Then this problem
Input voltage shows 5V, no matter if anything connected to throttle in
display blinks "throttle error"
I opened it but did not see burned components
