Will the bbshd fit on this bike?
papabless   100 mW
Post by papabless » Sep 10 2019 1:20am
I am interested in getting this 2011 Carbon Specialized S-Works Enduro SL CompImage.
I plan on asking a reputable battery maker osnpower from aliexpress to make a custom battery pack for the frame as well as installing an asi bac 800 plug n play 72v controller. Will the bbshd fit?
flat tire   1 MW
Re: Will the bbshd fit on this bike?
Post by flat tire » Sep 10 2019 1:39am
Look into the CYC X1 pro instead of the BBS. It's smaller lighter higher quality more efficient and more powerful.
papabless   100 mW
Post by papabless » Sep 10 2019 2:32am
I dont have the funds for that as I already have my own bike, I'm planning to revamp my entire setup. I'm only keeping the motor. But I do realize with the cyc there are more compatible bikes
hypertoric_amplituhedron   100 W
Post by hypertoric_amplituhedron » Sep 10 2019 12:22pm
Carbon frames with an aluminum bb shell might not fit. I wasn't able to slide one on my Scott CR1, just 5mm too thick. BBSHD is almost a guarantee if the shell is as close to a standard metal frame as possible (thin!). If you can post close-up pics of the shell, pref the left side, we might be able to tell.
There are two types of people in this world.
1. Those who can extrapolate from missing information.
ferret   1 kW
Post by ferret » Sep 10 2019 3:21pm
If you fit BBS to this frame in will severely compromise ground clearance.
Avner.
Don't believe everything you think.
Cove GNG-Spot build thread
Astral Rune build thread
Voltron   10 MW
Post by Voltron » Sep 10 2019 9:52pm
Carbon can be funny when loading it in directions it wasn't meant for. The bowing to the right caused by all the extra chain pull can really bust stuff up.... I've seen broken linkages, buckled chainstays, and one buddy opened up a giant vertical crack on the left side of the seat tube that trashed the frame after a few not very aggressive test rides. Not saying your Specialized in particular can't handle it, but it's a consideration on any higher power mid drive.
papabless   100 mW
Post by papabless » Sep 12 2019 5:25pm
flat tire wrote:
Sep 10 2019 1:39am
Its also a bit louder which I don't really like.
flat tire   1 MW
Post by flat tire » Sep 12 2019 5:26pm
Yes, it is very loud. Everyone looks at you like your bike is driven by powertools.
markz   100 GW
Post by markz » Sep 12 2019 5:57pm
Maybe a Sinewave controller will reduce the noise, along with some premium grade grease for the gears.
dustNbone   10 kW
Post by dustNbone » Sep 12 2019 6:54pm
It really depends on the source of the noise. If it's metal gears, then aside from lubricating the snot out of them there's not much you can do.
