Page 55 of 296
Posted: Jan 09 2018 2:21pm
by irrelevant
Found a solution to batteryholder installation: GrinTech BottleBob
http://www.ebikes.ca/bottlebob.html
No need to drill holes on the frame
Posted: Jan 09 2018 5:24pm
by tomjasz
slacker wrote:
Jan 09 2018 11:32am
I believe its called a coaster brake, not coastal. JMO. Easier to understand using proper bike terms. Had interest in this motor but looks like to many maintenance issues for me. I will stick with geared hubs, thank you.
I think it will prove to be less maintenance than Bafang, and with better support. I'm with you on the geared motors, went MAC and sold off my 3 BBSHD's. But when it comes to hills these mid drives are hard to beat.
Posted: Jan 09 2018 11:13pm
by Rydon
irrelevant wrote:
Jan 09 2018 2:21pm
I prefer a more refined fit and finish than hose clamps. Here is a very flexible and elegant solution from Wolf Tooth Components.
https://www.wolftoothcomponents.com/col ... ory-device
Posted: Jan 10 2018 7:09am
by Atrihalov
A throttle can be connected to the TDSZ2.
Posted: Jan 10 2018 8:52am
by Daytriker
wgtnpete wrote:
Dec 01 2017 10:02pm
So I got PSWPower to send me a replacement metal gear on the chance that it was the gear that had stripped. However, I have opened up the unit following the guides that everyone has helpfully posted, but my motor does not slide out once the four screws at the bottom are out. It feels pretty stuck in there. I was originally trying to do this with the motor still on the bike but took it out in case it gave me better leverage, but still no movement.
Any tips from someone who has done this procedure?
I may be a bit late to help you with this but after you have removed the 4 (?) mounting screws for the motor turn the whole unit on it's side & with a flat punch or screw driver edge just tap against the top motor cover around the circumference until you get some wiggle room. Then it's just a case of lifting the whole assembly out. Just seems to be a really good tight fit on some units.
Posted: Jan 10 2018 12:12pm
by tomjasz
Atrihalov wrote:
Jan 10 2018 7:09am
But not all version can run with a throttle. There is a specific controller and display needed.
Posted: Jan 10 2018 12:16pm
by tomjasz
Rydon wrote:
Jan 09 2018 11:13pm
The BB cold be used with zip ties too, but hanging a $500 battery with zip ties isn't all that exciting to me. Thanks for the post, I do like the idea of adding one of the Wolf rails on my down tube with rivnuts.
Posted: Jan 10 2018 8:55pm
by itchyfoot42
Not all zip ties are created equal. My battery is hung from the top of the seat frame using very heavy nylon zip ties and no problems in 8 months of use. Stainless steel zip ties are also available. May install a couple of those as I have had zip ties fail after a couple of years exposure to UV.
Posted: Jan 10 2018 9:26pm
by jbalat
I cant see any cracks on the bearing spline.. am i looking in the right place ?
Posted: Jan 11 2018 2:09am
by Atrihalov
tomjasz wrote:
Jan 10 2018 12:12pm
Atrihalov wrote:
Jan 10 2018 7:09am
Not certainly in that way. I have a kit without the throttle support 6 pins. I added 2 wires from the controller to the display, + 5V and the input signal from the throttle and everything works.
Posted: Jan 11 2018 5:23am
by jbalat
Atrihalov wrote:
Jan 11 2018 2:09am
tomjasz wrote:
Jan 10 2018 12:12pm
Atrihalov wrote:
Jan 10 2018 7:09am
Please share i might want to do the same on my bike
Posted: Jan 11 2018 5:31am
by Speady
jbalat wrote:
Jan 10 2018 9:26pm
Yes, you're looking at the right place, but you need to remove that brown plastic ring (dust seal).
Then you can see those splines, check carefully, all of them need to line up in the same direction.
If you feel a remarkable resistance while backpedaling, at least one of the splines flipped over. That's when you should start looking for a spare.
Posted: Jan 12 2018 1:46am
by jbalat
Thanks speedy just did a service on the other side of the motor and only thing i could find was the 22mm bearing in the housing had a lot of play. Anyone know how to get it out and what it is ?
Checked the splines like you said and they all appear to be fine
Posted: Jan 12 2018 3:01am
by Rydon
tomjasz wrote:
Jan 10 2018 12:16pm
itchyfoot42 wrote:
Jan 10 2018 8:55pm
I agree wit itchyfoot42 on the stainless steel zip ties. They are clean, add a little bling and are extremely strong. You don't need the $200 tool either. Just cut them off after tightening about 1/2-3/4 inch and then roll up the end with some 90 degree needle nose like a sardine can lid. They will hold over 150lbs. Here is where I get mine: http://amzn.to/2CTemKY
Still like the Wolf-tooth B-Rad the best: https://www.wolftoothcomponents.com/col ... ory-device
Posted: Jan 12 2018 3:39am
by tomjasz
A decent rivnut tool is under $30. I have black bikes and cover black hose clamps with black shrink wrap. I do use added zip ties, but not as primary. Three of my 6 rides are like are loaned out for friends on rides. I like friend proof, one dropped battery gets expensive. I aint handsome and worry little about looks. <wink>
Posted: Jan 12 2018 11:13am
by thomfellow
I purchased a Bullitt in December (2017) and ordered a TSDZ2 a few days later and after my first installation attempt I don't think it's possible to use these two together anymore. I'm not sure if I'm missing something or if the design of one or both have changed such that, even with significant grinding, they will not be compatible. I may be overly pessimistic.
I'm curious if anybody that's done this recognizes how tight this looks and thinks I'm just not visualizing it properly. :roll: To my eyes it doesn't look like I can remove enough material to make it clear. I may make another attempt this weekend. (see attachments)
I see that @Dr.Electric says they had to remove nearly all of the mount, as well as is illustrated by @mscoot.
Wondering if the clearance I'm seeing looks familiar matte2k@? The photo you show seems to have more space than mine.
matte2k wrote:
Jul 19 2017 12:45pm
Dr.Electric wrote:
May 25 2016 2:29pm
So i finally had some time to test it some more.
Se added picture for clearance. I had to cut away almost all of the motor mount on the right side.
But the motor fits snugly.
With a freshly charged 10 s 5p Samsung 35e pack I have 550-620 watt under load.
The motor delivers this continually going uphill. Used 2Ah on 10 minutes and the motor was probably about 35 Celsius after this workout.
It has a quite nice engine sound. Almost like a little motor cycle engine.
Works fine with the alfine 8.
I changed some settings in the controller. Now is powers the bike until 35 km/h. But the power change setting didn't change the motor wattage.
The bad stuff:
I can feel a little wobble in the main bearing from the crank.
This is a little surprising!
I hope that the main bearing will last!
mscoot wrote:
Jul 05 2017 3:18pm
mscoot wrote:
matte2k wrote:Have some questions before ordering a kit for my Bullitt cargo.
How many milimeter more to the right was the chainline after installation than before the installation?
Is it possible to mount the lekkie bling ring direktly on the "spider"? to get a better chain line?
Hom long is the cables from the motor to the display and to the battery?
What connection is the cable from the motor to the battery. I hope bullett connector?
Are there any difference between the displays? What would you recommend and why?
I have this motor mounted on a Bullitt.
Just so that you are warned, it does not fit out of the box.
However, it is a really nice motor though, and compliments the Alfine 8 or 11 IGH in a nice way if you have that. It's also very discrete once fitted to the Bullitt. I just hauled my entire family with beach stuff and all (a total of perhaps 250kg) all the way from the beach and 3 km long ride going up hill all the time. This was on a regular 250w EU-street legal motor, btw. It was slow at about 15-20 km/h, but the motor did fine without overheating.
To make it fit, you need to go at it with a dremel and trim off som bits of the motors casings. That's a 30 minute job if you've got the right bits, or perhaps half of that if you're sloppy.
The rear mounting point needs to be completely removed and grinded away off. If you're interested, I can give you some more details on where to cut and how to fit it.
There's also the issue about noise. Because the rear securing plate thingie is removed the motor pushes towards that big main centre tube on the frame. The slight hum of the motor is amplified by the frame and the cargo box in front unless you get creative with adding rubber o-rings and the like where it touches the frame.
Ok, so you're interested. Here goes:
Look at the two pictures. You have to remove the metal marked in red. Take care to not take too much, but just enough to clear the frame around the bottom bracket. Take away some, then test fit and repeat until your happy. To slide the motor in and out of the bottom bracket you need to unscrew the left side cover. Once the motor is seated properly, you can put the cover back on. Don't forget to blow away any metal debris that might have found it's way into the motor when the cover was off.
What's marked in blue are the three points where the motor touches the frame. You might want to put some sort of rubber o-ring or other soft material there to dampen the noise. (I forgot to add the second o-ring in the picture showing the front of motor). Especially the front part of the motor can be difficult to isolate properly from the frame. Put you could try without as well. It seems to me the newer versions of these motors are a fair bit more quiet.
To your other questions: the cables are more than long enough - no worries there. I think the small display is the nicest, Less cables, less fuss, but you loose the ability to charge your phone very, very slowly if that's your thing. With an IGH the chainline offset is negligible. I think it's off by about 1 cm. That doesn't bother me. Mine came with bullet connectors.
Posted: Jan 12 2018 3:20pm
by Rydon
Atrihalov wrote:
Jan 11 2018 2:09am
... I have a kit without the throttle support 6 pins. I added 2 wires from the controller to the display, + 5V and the input signal from the throttle and everything works.
Atrihalov, It is good to know that is possible. Could you provide a picture of the controller and display with the wires you added for the throttle? I am sure a lot of us following this thread would like to copy what you did.
Posted: Jan 12 2018 8:05pm
by Rydon
tomjasz wrote:
Jan 12 2018 3:39am
I don't want to go too far off topic but FYI, here is my favorite rivnut tool (and under $30). Unlike the gun type this can get up in the corners of bike triangles. http://www.aircraftspruce.com/catalog/t ... cfer=15526 Also, I use zinc plated steel rivnuts and don't worry about drilling holes in aluminum frames.
As for the last line in tomjasz quote above, I am in the same boat but I use what levers I have to try to increase my curb appeal - like dentist, barber and e-bike. <wink> :)
Posted: Jan 13 2018 4:18am
by Chalo
That rivnut setter is equipped only for SAE sized fasteners, but fortunately that's OK!
#10-32 threads are so close to M5x0.8 that you can either put a 5mm fastener right in them or (more likely) open them up to metric size by running an M5 tap cleanly into the #10-32 hole.
Posted: Jan 13 2018 1:18pm
by RTIII
Atrihalov wrote:
Jan 10 2018 7:09am
To clarify what Tom said: The TSDZ2 does NOT come standard with the wiring in the harness for the throttle and all indications are that if your TSDZ2 did not come with throttle from new, you cannot add one later unless you're as brave and adventuresome as Atrihalov is! Please, Atrihalov, tell us how you did it in pictures if you can!
Posted: Jan 13 2018 1:34pm
by RTIII
Chalo wrote:
Jan 13 2018 4:18am
Good to know, Chalo. Also, that same company sells the metric version as well:
http://www.aircraftspruce.com/catalog/t ... -03708.php
Posted: Jan 13 2018 2:32pm
by tomjasz
RTIII wrote:
Jan 13 2018 1:18pm
Atrihalov wrote:
Jan 10 2018 7:09am
RT, but we can add one with a new display and controller? Mine failed, but that was my understanding. Too cold to play bike mechanic so I'm waiting till spring. I am VERY interested in their in frame series...
Posted: Jan 14 2018 12:35am
by RTIII
tomjasz wrote:
Jan 13 2018 2:32pm
RT, but we can add one [a throttle] with a new display and controller? Mine failed, but that was my understanding. Too cold to play bike mechanic so I'm waiting till spring. I am VERY interested in their in frame series...
No, depending on what you mean by "controller", I am pretty sure you cannot; the wires just are not there to do it with, and adding said wires is exactly what Atrihalov appears to have done - along with also some magical connection inside the controller that makes it work.
So, IF you mean by "controller" the electrical system inside the same housing as the motor itself, well, it sounds like Atrihalov has managed to use the original, non-throttle-equipped controller and added the wiring and got it to work. However, as I have one of each unit, I can tell you the "wiring loom" up to the thing I think of as a controller (not "the" controller) - you might call display - is different. I THINK you have to have a VLCD-5 display to get the connection point, and if so, as that display has a removable base, MAYBE you can just replace the base and the loom running to the motor, and then make the appropriate hookup at the motor. But I don't have that experience (yet?), and I was hoping Atrihalov could tell us!
Clarifying
Posted: Jan 14 2018 2:14pm
by tomjasz
When I received my sample kit it was torque sensing only, no brake/motor cut off, and no throttle. I said I needed both for sales in the market (USA). I was sent a new controller, the electronic controller in the motor housing, and a new display. I was informed they were needed to have those functions. In retrospect I think it would have been a better kit without either. Unfortunately sometimes I MUST have a throttle. I will test more once it warns up. -7F yesterday. Test rides HURT!
Posted: Jan 15 2018 11:17am
by pamlico
Can you help me in some gaps in the XH-18 display?
to start shooting would be in the number 1 turbo function,
the 2 would be speed and following, another doubt: for the wheel size what would be the steps to follow? mine is 29'. forgive my bad English, I am Spanish and I write through a translator, thank you
