new cyclone 3000 w mid-drive kit?
zekill   1 mW
Re: new cyclone 3000 w mid-drive kit?
Post by zekill » Jan 26 2020 12:59am
Anyone is familiar with android phone ?
i have install the cyclone0926.apk (downloaded on cyclone website) on a xiaomi redmi 7A and app stay in chinese language.
I have try to switch to english in app without success.
HrKlev   1 mW
Post by HrKlev » Jan 27 2020 6:30am
So I just ordered a 1800-3000w kit for a fatbike build, it will probably run it with a nucular 6f controller. I have tried searching, and sorry if it has been asked before, but I can not find info about what kind of voltage I should chose if I still want to use the pedals. Cyclone site states rated rpm 800rpm, and I think it is a 14-48 reductipn to the pedals. That is 233rpm to the pedals, which doesnt make sense. After reading a couple reviews, I was under the impression that it is possible to use the pedals together with this kit? I would be really thankful for some real world experience, and what kind of voltage you were using. Thanks!
Tommm   10 kW
Post by Tommm » Jan 27 2020 4:40pm
HrKlev wrote:
Jan 27 2020 6:30am
Cyclone is 62.5kV, so that many rpm per volt. 72v, 4500rpm. Internal reduction is 6:1, so 750 at the motor cog.
HrKlev   1 mW
Post by HrKlev » Jan 28 2020 1:21am
Ok, so to be able to pedal, motor rpm must be ~40-45% max.
Tommm   10 kW
Post by Tommm » Jan 28 2020 6:52am
HrKlev wrote:
Jan 28 2020 1:21am
Something like that yes.
ebike11   100 kW
Post by ebike11 » Jan 30 2020 5:00pm
dirkdiggler wrote:
Jan 25 2020 8:42pm
Here's what I did to mount the cyclone to eeb frame. No pedals though. Didn't want them. Unfortunately the surron is a better bike for what I want.
Just cut down the stock mount to get it flush with the frame. Had to drill two new holes.
That frame is not like my eeb frame. Is it an older version?
Stanislavchik   10 mW
Post by Stanislavchik » Jan 31 2020 6:02am
Bought 4.8kw coaxial drive, which chain will fit 2 eat so much power?
Tommm   10 kW
Post by Tommm » Jan 31 2020 6:57am
Stanislavchik wrote:
Jan 31 2020 6:02am
How many speeds?
If you are on 6-8, you only have X series, so kmc x8 ept
If you are on 9-12, you have E ebike series, so kmc e9 ept, kmc e10 ept kmc e11 ept, kmc e12 ept.
If you bought the complete bike, the chain required will be quite long(around 124 depending on setup) so always go for 126 link versions of the E series, X series is only 116, so maybe get 3-4 of them to have 2-3 usable chains.
Stanislavchik   10 mW
Post by Stanislavchik » Jan 31 2020 7:16am
No, I have IGH SA 5 speed, so I need 1 speed chain, bmx maybe, i don't know, it is my first mid, i ride on direct drive now...
I saw KMS ebike chains on it's site and yes, they are so expensive, maybe there are more variants... :)
Tommm   10 kW
Post by Tommm » Jan 31 2020 7:22am
Jan 31 2020 7:16am
Only the bling ones are expensive the strong ones aren't bad.
Single speed I got the connex 1e8. It is so beefy it wouldn't fit around a narrow wide chainring though. Just regular chainrings or hub cogs.
In my experience, unless you go for a swiss cheese looking lightened chain, the amount of washing and lubing will get you way more miles than going for an expensive ebike chain.
Stanislavchik   10 mW
Post by Stanislavchik » Jan 31 2020 7:41am
Tnx Tommm, that chain looks great :thumb:
pwd   1 kW
Post by pwd » Feb 01 2020 7:46am
Long story short, my 32T chainring has taken some damage. The one I have looks like this:
Does anyone know where I can purchase a new 32T BCD 104 chainring like this (looks less likely to bend than my old one):
The only place I see them at http://www.cyclone-tw.com/Parts.html and https://elite-motor.com/32t-chainring-w ... 104mm.html but the shipping cost is $30USD/$33USD + $12 for the freewheel; which seems quite high.
Commuter/Street Build viewtopic.php?f=6&t=98286:
Rocky Mountain Element
Magic Pie 4 front + Leafmotor 1500 rear w/ WCEC 18fet
em3ev 14S5P 30Q + 14S6P 25R pack
Offroad Build viewtopic.php?f=6&t=102195:
2019 Rocky Mountain Blizzard 20
Cyclone "3kw" 13T motor to 36T chain ring then 32T chain ring to 11T-46T Cassette
em3ev 14S5P 30Q or 14S6P 25R pack
Tommm   10 kW
Post by Tommm » Feb 01 2020 8:31am
pwd wrote:
Feb 01 2020 7:46am
No need. Get narrow wide alu, unless you are doing single speed.
https://www.ebay.com/sch/i.html?_nkw=32 ... de&_sop=15
pwd   1 kW
Post by pwd » Feb 01 2020 9:02am
Tommm wrote:
Feb 01 2020 8:31am
Thanks for the link Tommm, I've seen those aluminum ones come up in my search. They seem pretty inexpensive. What is your reason for suggesting the aluminum ones over steel?
Tommm   10 kW
Post by Tommm » Feb 01 2020 9:10am
pwd wrote:
Feb 01 2020 9:02am
Tommm wrote:
Feb 01 2020 8:31am
Cyclone for a lot of parts like to use pig iron. You might have been able to bend it by hand even. The narrow wide is important, they hold the chain better, less chance of it jumping off.
pwd   1 kW
Post by pwd » Feb 01 2020 9:16am
Wunderbar, thanks Tommm!
Tommm wrote:
Feb 01 2020 9:10am
pwd wrote:
Feb 01 2020 9:02am
Tommm wrote:
Feb 01 2020 8:31am
electric_nz   10 mW
Post by electric_nz » Feb 02 2020 3:12pm
Anyone have any idea what MOSFETs the standard controller uses? And the 60A version?
Tommm   10 kW
Post by Tommm » Feb 02 2020 8:36pm
electric_nz wrote:
Feb 02 2020 3:12pm
Afaik the 60a version is the same as the 40a version pre shunted. I have a 60a one, it came with solder on the shunt.
You can open up yours and check, you only need to open the non wire side lid. If the shunt is dry, have at it.
HrKlev   1 mW
Post by HrKlev » Feb 05 2020 3:19am
Where are you guys ordering the cyclones from? Luna is out if stock, so I orderes from the cyclone site in Taiwan. I havent heard anything except a paypal receit. No order confirmation or anything. Tried to email them yesterday, but so far no answer. Anyone experienced the same?
Stanislavchik   10 mW
Post by Stanislavchik » Feb 05 2020 3:51am
china holidays maybe, just wait.
pwd   1 kW
Post by pwd » Feb 05 2020 9:42am
HrKlev wrote:
Feb 05 2020 3:19am
I ordered mine form http://sickbikeparts.com/electric-shift-kits-e-products. As Stanislavchik has pointed out though, the extended Chinese holidays may be affecting orders. Give them some time.
Tommm   10 kW
Post by Tommm » Feb 05 2020 11:06am
HrKlev wrote:
Feb 05 2020 3:19am
They reply to emails pretty fast. I use cyclonebike gmail
2old   100 kW
Post by 2old » Feb 05 2020 12:58pm
Received mine from SBP pretty quickly but that was a year or so ago. Also, they respond rapidly to emails.
bikerpete   100 mW
Post by bikerpete » Feb 10 2020 7:15am
I've looked, I've searched, I've failed.
Can anyone tell me if it's possible/practical to remove the gearbox from the 3KW Cyclone and run a sprocket direct from the motor shaft?
From all the pictures I've found I'm not clear if:
a. the face of the motor is flush. If not can I machine it flat without compromising it?
b. is the shaft diameter sufficient that it could withstand the bending moment from a chain drive on it? I think it's 17mm dia from a post I saw about changing bearings, but not 100% sure.
c. is there anything else in it's build that would make this impractical?
This might work nicely for me on a non-pedal low speed/high torque bike, running maybe 11-99 tooth 219 chain drive.
Thanks
EDIT
This has been solved.
Apparently it is a 17mm shaft at the bearing, then steps down to 10mm with keyway for the steel gear to press on to.
