Will a BBSHD interfere with an ISCG-05 chain guide mount?
oatnet   10 MW
Post by oatnet » Jan 20 2020 1:35pm
I've been contemplating another BBS build, but noticed the frame has an integrated ISCG-05 chain guide mount which I'm pretty sure will interfere with the BBS HD's motor can. My searches are not turning up much data, has anyone run into this and what did they have to do?
Assuming it does interfere, I'm wondering if grinding away the flange between the two lower mounting points will give enough clearance, or if I have to take out one of the mounting points too. I hate to cut anything on this frame so I'm trying to figure out how much damage I'd have to do to electrify it.
-JD
Member 117 of 26,000+
153v DUNE BUGGY © 164v Vectrix E-Moto © 72v Norco A-line/x5403 © 60v Specialized Enduro Comp/BMC © 72v x5tracycle © 48v TF IO/BMC © 36v Kepler FrictionDrive © Spot-Welding a123 © Pelican Front Packs © Vectrix Battery Replacement © MORE !!
Image大鸡巴 Motors
Knowledge is acquired through experience, everything else is just information - Albert Einstein
"Cheater?" I'm not competing, I'm Commuting!
