Anyone running a Cyclone motor on an EEB frame?
ebike11   100 kW
Post by ebike11 » Dec 28 2019 5:28am
Hi guys!
Just wondering if anyone has ever installed a Cyclone 3000 on an EEB (Enduro) frame?
Thanks!
ScooterMan101   10 MW
Re: Anyone running a Cyclone motor on an EEB frame?
Post by ScooterMan101 » Jan 03 2020 4:18pm
It has been a week since you posted the question and no one has answered.
I have been waiting for someone to design a better e-bike frame, and one that can use a mid drive like the Cyclone 3000 w kit , and/or the GNG 2019 Cyclone 3000w kit.
The way most every e-bike frame is designed does not allow a good platform for a mid-drive, they are designed around a rear hub motor.
Vector bikes / the Typhoon Frame is shown with a BBS02 mid drive but even that frame needs a re-design for many reasons.
Since you are in Korea it is best to find a bike Bicycle Frame Manufacturer in your country , or in Tiawan if you can find someone there that will work with you. and Start making a frame that is better than any other hub motor e-bike frame.
You can contact me , also you can have someone in Korea / Tiawan contact me , come to the U.S. and meet with me and I will show you some design features that are necessary for a better e-bike frame.
My first conversion ... Sold
viewtopic.php?f=3&t=71378&p=1077497&hil ... 1#p1077497
It's 2018 already, ( now 2019 ) lets get some real , improved e-bike / e-velomobile / e-motorcycle designs .
rockstar195   100 W
Post by rockstar195 » Jan 03 2020 8:59pm
Check this out (look for the post by LightingRods on Nov 26 2017 5:22pm towards the middle of the page with the pics of the Enduro EEB ): viewtopic.php?f=28&t=82938&start=300
ScooterMan101   10 MW
Post by ScooterMan101 » Jan 04 2020 1:46pm
Notice the 2 plates ( 1 on each side of the swing arm at the dropout area of the EBB swing arm ) .
That is necessary to add length in order to fit the Big Block/ Small Block / a Cyclone motor , in front of the wheel .
also
that looks to be a small diameter wheel as well ?
rockstar195 wrote:
Jan 03 2020 8:59pm
Tommm   10 kW
Post by Tommm » Jan 05 2020 1:21am
Cyclone have their own integrated swingarm.
Much better than even the lightning rod version. It is $700 including motor and controller.
I showed it to OP in the cyclone thread, he wanted nothing to do with it, he wants to keep his swingarm. So because of that, he would rather suffer with terrible quality motor mounts, snapping chains because of the stupidy high 2 stage gearing under any real power and freewheel issues. He will spend more than the difference in price in maintenance and hair pulling, but whatever floats his boat.
ScooterMan101   10 MW
Post by ScooterMan101 » Jan 06 2020 5:49pm
I found out about that Cyclone 4.8 kw motor and frame just a month or so after I bought my GNG 2019 3000w motor, So
( perhaps ) like the OP I am stuck , meaning my money has been spent on that . No more money for the 4.8 motor/frame , and now I must also find a e-bike frame that will accept the 2019 motor .
I am not in a hurry to sell the 2019 3k motor just yet because that 4.8 cyclone and most every e-bike frame just is not refined enough to keep up with modern times / modern bicycle geometries . Meaning Longer , Lower , and Slacker
All the e-bike frames IMHO should have much slacker head angles that are more suited to the higher speeds we do on performance e-bikes.
Head Angles of 63 degrees or even slacker, Note in the non-motor bicycle world more regular downhill and
enduro / all mountain bikes are now at 63-64 degrees of head angle . I see 62 degrees coming soon to the bicycle world .
So even though I understand all you are saying about the 2 stage gearing , destroying freewheels , etc. We still need a much updated e-bike frame to work with DIY Mid-Drives.
BTW I have 350 miles or more now on my 2019 3k motor bike and no or very little chain stretch , and no freewheel problems , I am careful to start off with low torque and increase speed and torque slower than on a motorcycle.
Tommm wrote:
Jan 05 2020 1:21am
Tommm   10 kW
Post by Tommm » Jan 06 2020 11:19pm
ScooterMan101 wrote:
Jan 06 2020 5:49pm
If you already have it, it is a done deal, the GNG drive has most of the cyclone kit's bugs fixed, so it is as good as you can get otherwise.
ebike11   100 kW
Post by ebike11 » Jan 11 2020 10:51pm
Tommm wrote:
Jan 05 2020 1:21am
Thats coz i already have the 3000w from another build laying around and also have an EEB kit from em3ev. Why wouldnt i try to try and makebthis work with everything here in front of me before handing over $1000 plus on new stuff??
If doing that floats your boat then you can do it first
problemaddict   10 mW
Post by problemaddict » Jan 21 2020 11:02am
A couple frames that seem like they would work, but you don't see anyone using them with a Cyclone. I'm not sure why, but maybe the bottom bracket isn't compatible? (too wide?)
Teleport Prime
https://rover.ebay.com/rover/0/0/0?mpre ... 3876152282
Qulbix\Risun
https://rover.ebay.com/rover/0/0/0?mpre ... 3068374110
With both of these frame styles the BB is not in the swingarm, so they should work with a Cyclone...
Check out my YouTube Channel: Mike Tinkers and Builds Stuff
dirkdiggler   10 kW
Post by dirkdiggler » Jan 29 2020 3:59pm
Posted in the cyclone thread already. I've done it and removed pedals. Cut the mount to have more ground clearance.
