Dengfu E05 and E06
jimmyN   100 mW
Dengfu E05 and E06
Post by jimmyN » Sep 21 2019 10:08pm
Anyone have any experience with either one of these frames?
radiorental   100 mW
Re: Dengfu E05 and E06
Post by radiorental » Nov 20 2019 11:23am
I've just ordered one. I'll follow up again once I get it, should be the end of December. In my research I found the exact same frame is used by a number of western resellers, retailing at 2-3 times the price.
So far, I've found Dengfu to be surprisingly communicative and pleasant to work with. They made some tweaks to the components for whatever reasons, upgraded the rear shock to a RS Deluxe.
With that all said, I'm not walking into this blind. I used paypal with an Amex card. I've not had a lot of fun in the past making claims through paypal but vendors are usually shit scared if you mention contacting them, they don't want to get shut down. Amex on the other hand will refund a claim in days with the right paperwork.
My biggest concern next is the shipping, I'm pretty sure the packaging is going to be sub-standard. I went with sea, it was another $150 for air and I'm not in a rush. This is the build out I went with
Item Description Quantity Unit price(usd) Amount(usd)
1 E06 20" in UD matt finish, 12*197mm rear space (rear thru axle included) 1 $2,999.00 $2,999.00
2 Neco headset for E06 1
3 BAFANG M620 G510 1000W 48V 1
4 DENGFU Lithium-ion 48V 14Ah 672Wh 1
5 Suspension fork, air, 120mm travel, 1 1/8"-1 1/2" steer tube, 135x9 QR 1
6 RS DLX R 185X50 DB 2T MM TS B1 1
7 SRAM RD-SX EAGLE/ SRAM CS-PG-1210 EAGLE 11-50T 12S/ SRAM DB LVL/ SRAM SL-SX EAGLE TRIGGER/ BAFANG EB11 170mm 40T/ SRAM CN-SX EAGLE 12S/ 180mm disc 1
8 Aluminum Alloy, 80mm wide, fat hubs, 6-bolt, 135x9 front, 197x12 rear, DT spokes, 32/32 holes, all black (INNOVA 26er*4.0 tire) 1
9 ZOOM, suspension seat post, 31.6mm diameter, 100mm drop 1
10 HB006 handlebar 720mm in 3k matt finish 1
11 aluminum stem 1
12 normal black saddle 1
13 postage to USA by sea 1 $500.00 $500.00
Total $3,499.00
Tom   100 W
Post by Tom » Dec 30 2019 4:50am
I think this build uses that frame. Looks a bit like the Luna X1 on steroids.
https://m.youtube.com/watch?v=wHvMNDBO1KM
waynebergman   10 kW
Post by waynebergman » Dec 30 2019 5:37pm
HI "Radiorental", "EDIT SORRY I HAVE DELETED SOME STUFF I POSTED IN THIS POST AS I JUST REALIZED YOU ARE GETTING THE M620 NOT THE M600 DRIVE"
I hope with the 4" x 26" tires you still get some how a decent chain line, I am sure Dengfu has this worked out but keep us posted.
Good luck with it, I am sure you will enjoy this new M600 drive.
Also, if I can suggest that you check all your pivots that the M screws and nuts are torqued properly. My bike from Dengfu came with impropper torque settings and if things wiggle loose threads can get messed up and pieces lost. Also they cheap out on crappy tubes (or did so on my bike) so I would put decent tubes in or convert to tubless if you can.
All the best Radiorental.......wayne
devean   1 µW
Post by devean » Jan 28 2020 2:53pm
radiorental wrote:
Nov 20 2019 11:23am
11 aluminum stem 1
Total $3,499.00
Any news on the bike?
I am keeping eye on the thread, i have thought about ordering the same frame set, possibly with battery and motor, depends on the price and the quality of battery. I`d personally would order other parts from Europe (no custom fees). I would go with Bluto fork, and DT Swiss BR 2250 wheels with Schwalbe rubber. Should save few kilos as well. Shame that there is no fat bike frame set for Bafang m600 motor, wich imho is powerful enough, it would save few good kilos.
