Dewalt powered mid drive road bike
helno   1 W
1 W
Post by helno » May 20 2019 2:35pm
Decided to update my bicycle for this riding season.
The bike is an old Miele road bike that has been upgraded over the years.
The update consisted of removing a Kepler friction drive and replacing it with a Bafang BBS01. For a power source I wanted to use a pair of 5 Ah Dewalt 20 volt packs.
The mid drive install was pretty trivial. The speed sensor mount would not work on this frame as the space between the spokes and frame is to narrow. The Bafang brake leavers are a bit clunky but they do the trick.
To mount the batteries I 3d printed an adaptor to use an off the shelf battery mount. The install is pretty clean and the batteries can be removed very easily (I work at a secure facility so theft is not an issue.) I might reprint the mounts in yellow to match the batteries.
The install is pretty discrete and the quiet power delivery is very nice.
If anyone would like the part files for the Waitley mount it can be found here.
https://www.thingiverse.com/thing:3643081
StinkyGoalieGuy   100 W
Re: Dewalt powered mid drive road bike
Post by StinkyGoalieGuy » May 29 2019 11:22pm
Very nice. So do you run the two packs in series? Do you use any kind of diode to isolate them in case the BMS trips on one of the batteries?
silentflight   100 W
Post by silentflight » May 30 2019 1:18pm
Your bike looks good with the Dewalt packs on it - utilitarian. Thanks for sharing it.
What material did you use for the 3D printed portion of the battery mount? It needs to be strong enough to withstand all the road chatter and potholes. Maybe it was a type of nylon?
cheapcookie   100 W
Post by cheapcookie » May 30 2019 1:22pm
Nice, have you tried 3d printed ryobi/makita/milwaukee adapters ? for giggles ?
helno   1 W
1 W
Post by helno » Jun 04 2019 6:39pm
silentflight wrote:
May 30 2019 1:18pm
I used ABS. It is a pretty common material on bikes.
cheapcookie wrote:
May 30 2019 1:22pm
The Waitley adaptor will also accept Milwaukee M18 as well as the dewalt packs.
cheapcookie   100 W
Post by cheapcookie » Jun 05 2019 12:24am
helno wrote:
Jun 04 2019 6:39pm
cheapcookie wrote:
May 30 2019 1:22pm
Damn u smart
helno   1 W
1 W
Post by helno » Jun 07 2019 5:52pm
StinkyGoalieGuy wrote:
May 29 2019 11:22pm
Missed this one.
No diode because they are in series. And they do not have a conventional BMS only a basic cell balancer.
