Recommended Soldering Iron for 5AWG?
rg12   100 kW
Post by rg12 » Apr 12 2019 6:51pm
I have a Hakko Presto which I use to solder up to 8AWG and that little thing does it amazing.
I would like to hear about any recommendations for quality yet affordable soldering irons/stations for a higher power setup to solder 5AWG wires.
Mind that the Hakko Presto is the best soldering iron I ever used and it's super cheap ($30-$50).
major   10 kW
Re: Recommended Soldering Iron for 5AWG?
Post by major » Apr 12 2019 7:23pm
Ever consider a torch?
john61ct   100 GW
Post by john61ct » Apr 12 2019 8:14pm
or crimping?
Ohbse   10 kW
Post by Ohbse » Apr 12 2019 10:19pm
Best soldering iron for wiring that size is no soldering iron, it's just not the right technique for connections at that scale.
Best option is to invest in a hydraulic crimper - they can be had pretty cheaply from ebay etc. I love mine.
tomjasz   10 GW
Post by tomjasz » Apr 12 2019 11:18pm
Get The TS100 Digital OLED Programmable Soldering Iron is an internal heating intelligent CNC soldering iron.
Check out the reviews. A real winner!
dogman dan   100 GW
Post by dogman dan » Apr 13 2019 7:48am
Big fat tip iron will do, even low wattage, if the tip is fat enough. But personally, I'd go to crimps or lugs by 5g.
spinningmagnets   100 GW
Post by spinningmagnets » Apr 13 2019 8:41am
rg12   100 kW
Post by rg12 » Apr 14 2019 9:19am
Thanks guys, I guess I will go with crimping then
Schlafmutze   10 W
Post by Schlafmutze » Apr 14 2019 3:23pm
I solder 4 AWG with a weller WS81, using fat tip.
A TS100 with a fat tip will work too.
That 80w Iron is enough to solder long pieces of AWG4 onto my BMS PCB even.
rg12   100 kW
Post by rg12 » Apr 15 2019 4:35am
Schlafmutze wrote:
Apr 14 2019 3:23pm
Good to know, thanks alot :)
tomjasz   10 GW
Post by tomjasz » Apr 19 2019 10:28pm
TS100
A couple of optional tips and bob’s yer uncle.
john61ct   100 GW
Post by john61ct » Apr 20 2019 2:37pm
Schlafmutze wrote:I solder 4 AWG with a weller WS81, using fat tip.
https://youtu.be/83STpUXHilk
Just love this guy!
