Newbie bike build connectors advice
smaua   10 mW
Post by smaua » Nov 07 2018 7:33am
Hi all! I'm trying to put together ebike bits I got from bmsbattery. Some wires don't seem to fit together, wonder if I could get some advice.
I got this controller:
https://bmsbattery.com/ebike-kit/721-s1 ... e-kit.html
And the wheel/motor connector looks like
https://pasteboard.co/HM3RvOk.jpg
Guessing that needs to connect to the hall sensors and to the 3 bullet motor cables.
-anyone know what the motor type connector is called?
-do you think I could cut it off and just connect wires one by one with chocolate boxes? If so, wonder how to know which wire is which?
-otherwise how do you suggest I connect it up?
Another thing, I'm not sure what this yellow cable should connect to? https://pasteboard.co/HM3SeZQ.jpg
That's it for now still trying to figure it out.. Thanks!!
E-HP   100 kW
Re: Newbie bike build connectors advice
Post by E-HP » Nov 07 2018 4:26pm
I tried looking for those type of connectors to allow me to disconnect to wheel for tire changes, but came up empty. I'm using an IP68 cable connector for the Hall wiring, and Andersen connectors for the phase wires.
Try searching ebay for "IP68 cable connector" and you might find something that lines up (although I gave up).
I think the yellow wire goes to the battery (+) to work the power display bars. I could be wrong, but I'm hooking up a throttle with similar wiring this weekend, so I'll see.
spinningmagnets   100 GW
Post by spinningmagnets » Nov 07 2018 4:46pm
Convert the battery to controller connection to an anti spark XT90, buy a couple sets. BMS-Battery is famous for the connectors and wires being undersized. That multiple pin cable is good for frequent 20A, or...occasional 30A plus continuous 10A.
Keep that multi-pin for the halls. Open the motor and run thicker cable for the three fat motor phase wires.
docw009   100 kW
Post by docw009 » Nov 07 2018 6:27pm
BMSBattery forgot to send you the motor extension cable. It looks like this. It will allow you to connect the motor to your controller.Send them a pic and request it. It has come with every motor I've purchased from BMSBattery,
People like me prefer the 9 pin connector because it goes thru an axle nut and allow easier removal of the wheel. You could cut off the 9 pin connector and wire in whatever you want, but it's a tedious job. I've done the opposite, which is wiring in a 9 pin plug to a motor that didn't have one. Unless you have good stress relief, it just makes for a cable more susceptible to damage.
How big is the motor (watts) and do you plan to run 30A-40A to it?
smaua   10 mW
Post by smaua » Nov 12 2018 5:45pm
Thanks everyone! In the end I diy'd it instead of waiting for a cable to come through the post. Kind of annoying that bmsbattery didn't send everything, doesn't make me wanna buy from them again. I wired in a long enough cable with chocolate boxes so it can be relaxed. Probably not the best idea but it was quick.
I guess one day I will take up the advice and rewire the thick motor cables with better ones.
I'm just so impacient to ride already, so many obstacles :)
amberwolf   100 GW
Post by amberwolf » Nov 12 2018 11:03pm
smaua wrote:
Nov 12 2018 5:45pm
chocolate boxes
smaua   10 mW
Post by smaua » Nov 21 2018 3:23pm
How did it go with that throttle? Does it literally connect to the battery positive wire? at the same time as the controller is connected to it also?
E-HP wrote:
Nov 07 2018 4:26pm
E-HP   100 kW
Post by E-HP » Nov 27 2018 8:29pm
smaua wrote:
Nov 21 2018 3:23pm
E-HP wrote:
Nov 07 2018 4:26pm
Yup. When I was installing my watt meter, I pigtailed a few extra (+) connectors from the battery for future use (adding DC-DC converters for 12 V and 5 V for accessories), and used one of them for the throttle voltage display and it works great.
smaua   10 mW
Post by smaua » Nov 28 2018 10:25pm
thx!
smaua   10 mW
Post by smaua » Dec 01 2018 12:02pm
thx! so it needs to be converted in order to show the right info on the battery meter?
E-HP wrote:
Nov 27 2018 8:29pm
smaua wrote:
Nov 21 2018 3:23pm
E-HP wrote:
Nov 07 2018 4:26pm
E-HP   100 kW
Post by E-HP » Dec 01 2018 1:12pm
smaua wrote:thx! so it needs to be converted in order to show the right info on the battery meter?
to it also?
Not for mine, because mine has digital readout of actual volts. Yours may, since it depends on what voltage range it was designed for.
