MXUS 3000 Hub Motor - V1 V2 V3
teslanv   100 MW
Re: MXUS 3000 Hub Motor
Post by teslanv » Jul 06 2015 8:36pm
markz wrote:.....So Lyens Infineon controllers are what square wave?
Yes, Lyen/Infineon/Xie Chang are Square wave controllers.
DD Hubs, Batteries, Controllers & Custom Ebikes.
http://westcoastelectrics.com
West Coast Electric Cycles
Bellevue, WA
USA
teslanv   100 MW
mikebikerad wrote:I got my second taste of this motor with a sine wave control a week ago on a neighbors bike.........IT IS LIKE RIDING ON A MAGIC CARPET. There is almost no cogging with the sine wave controller, I was speechless how smooth it was.
Adaptto?
Bellevue, WA
USA
wesnewell   100 GW
Post by wesnewell » Jul 07 2015 1:56am
Rix wrote:
wesnewell wrote:I use these on the inside of the dropouts.
http://monsterfastener.com/item/jns-195
As a spacer?
That, but more as something to provide a solid backing for the dropouts at 170mm on the fat tire bike so i can get the axle nuts tight. And like this in regular dropouts.
johnrobholmes   1.21 GW
1.21 GW
Post by johnrobholmes » Jul 07 2015 7:21am
eTrike wrote:I just picked up the Holmes MMP rim I ordered on the 12th. It arrived a couple days ago but I was out of town. I got the Red option rim to save $$ and I had assumed from the post he gave about them that they were new rims, but he wanted to get rid of them as red "got a lot of votes but not a lot of buys" or something similar.
My "new" rim apparently is used.
It has a small dent in one side which didn't seem to happen during shipping as the box was intact and the inside of the rim has baked-in debris that looks like rubber/dirt as if it had been mounted and used for some time.
I'm thankful for the price of the rim anyhow, but wanted to share my experience.
Definitely should have been a brand new rim, we don't have any used ones nor have we had returned rims that could have gotten mixed up with the new ones. Do you still have it uninstalled? Could you take a pic and email it to warranty@ my company name? My apologies on this, I'm quite curious as to how it happened.
BoomerChomsi   1 kW
Post by BoomerChomsi » Jul 07 2015 11:21am
Thank you! 8)
Believe and Do
markz   100 GW
Post by markz » Jul 07 2015 1:21pm
As a spacer?
Ya my frame is the same way. I see my dropouts bending inward, so I like the nut idea for sure.
Rix   100 GW
Post by Rix » Jul 07 2015 3:54pm
As a spacer?
That will work for sure. I use washers cut with a 10mmx14mm hole in the center.
BoomerChomsi   1 kW
Post by BoomerChomsi » Jul 09 2015 2:29am
I am able to install this nice motor 4T V2 into Giant DH with Kiwi dropouts without any cutting on axle.
Waauww I am impressed: very easy to dishing the rim and max. speed freewheel is 5S :mrgreen:
So I can throw my HS3540 and HT3525 into the garbage corner..... 8) 8) 8)
Believe and Do
Rix   100 GW
Post by Rix » Jul 11 2015 7:15pm
Here is a comparison between the TC4080 and MXUS. As can be seen, both motors are similar over all. Even Justin's Ebike Simulator shows close performance between these two with same volts/amps input. Couple of differences I noted. The TC4080 axle on the brake side is 27mm, the MXUS is 17mm, both axles use a 10x14 dimension with 1.5 thread pitch. On my scale, the TC4080 is 19.6 # and the MXUS is 20.2 #. The axles on the freewheel side for the MXUS is 17mm and the TC4080 is 16mm. Overall width of the stator covers are 67mm for the TC4080 and 72mm for the MXUS. The only advantage I see with the TC4080 over the MXUS is the large axle allows for more room for phase wires and sensor wire. If MXUS was to make there axles 150mm and say 20mm on the brake side, they would solve the wire clearance problem I am seeing. The TC 4080 2x as much as the MXUS. There is no way the TC4080 is twice as good. Later this summer, I should have them both laced up and running, the TC on my Fighter, the MXUS on my Flux, should be a neat comparison.
4t MXUS TC4080.jpg (72.96 KiB) Viewed 1742 times
TC4080 and MXUS.jpg (89.83 KiB) Viewed 1742 times
Drive side.jpg (60.1 KiB) Viewed 1742 times
MXUS TC4080.jpg (83.55 KiB) Viewed 1742 times
Samd   1.21 GW
1.21 GW
Post by Samd » Jul 11 2015 7:24pm
Thanks rix. Good data. I generally just add a cable tie behind the axle exit to stop the chance of rub.
Another significant point for me is the Mxus' axle material. Much better than the clyte material someone once referred to as 'cheese'.
I've got an older crown in the shed, I think its nearly 3lbs more. Must check. The large radius is a bit of a cop-magnet (no insult intended!)
Anyone else noticed a big drop in clyte prices lately?
http://ballaratebikes.com/
Rix   100 GW
Post by Rix » Jul 11 2015 7:57pm
Samd wrote:Thanks rix. Good data. I generally just add a cable tie behind the axle exit to stop the chance of rub.
Yah, the TC80 is quite a bit heavier than the TC4080. Physically looking at those two side by side, the TC series looks almost as big as the 54xx. Good to know about the axle material, I got a bunch of 10x14 washers for mounting the MXUS onto the Flux, I will grind the edge down, and bevel it so the wires aren't pinched. Will make it work.
BoomerChomsi   1 kW
Post by BoomerChomsi » Jul 12 2015 10:41am
I don't see any prices are dropped for Crystalyte motors?
Any link(s)???
Thanks.
Believe and Do
Rix   100 GW
Post by Rix » Jul 13 2015 11:12am
BoomerChomsi wrote:I don't see any prices are dropped for Crystalyte motors?
Any link(s)???
Thanks.
Haven't seen that from the retailers here locally.... yet, but there is a price drop on these motors for bulk from Crystalyte. I figured it was because of the Chinese Yaun to USD were changing, it never occurred to me that it could be competition related to the MXUS. Hey SAM D, whats up?
BoomerChomsi   1 kW
Post by BoomerChomsi » Jul 13 2015 12:45pm
Thanks 8)
Yeah I was just curious, no more Crystalyte for me!
I have many Crystalyte motors, none of them last long.
Even with mods :evil:
Believe and Do
rhinejuice   10 W
Post by rhinejuice » Jul 14 2015 6:59am
Keen to see you experience Rix! But hoping the mxus wins out!
You can't have too many toys.
Doctorbass   100 GW
Post by Doctorbass » Jul 14 2015 7:28am
BoomerChomsi wrote:Thanks 8)
Depend on how you use them. From my 8 years experience on E-S i can say that the Crystalyte are built really strong. I opened 3 MXUSdifferent motors and none of them have a built quality that is better than the Crystalyte. I used over 10kW in each of my 5300 and 5400 serie motor and none of them burnes or damaged.. one even have shown a stator temp of 260 Celsius after one of my friend cameback from a ride.. the motor was smoking!.. but i acheived a 113kmh with the same motor 1 year later...
The most evident difference is the winding quality. The Crystalyte motor are far better than the MXUS 3000. The MXUS 3000 have alot of loose wires strands, even some of the parallel run are broken sometime... also the protection layers between the stator metal lamination and winding are absent on some tooth... Just open your MXUS you will see what i mean! I have contacted Barent to suggest him to discuss with MXUS about these problems so he can get better QC on the next order.
All 5300 serie motor used 12 gauge wires while the MXUS 3000 use 14gauge... Also the axel of the crystalyte is stronger.
But as well the MXUS are far Superior efficiency many Crystalyte... and weight less.... but i will have to rebuilt all my MXUS to make sure they last long... this include varnish emal on all stator parts, add epoxy on all magnets, insyall 10 gauge phase wires etc.
Doc
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
BoomerChomsi   1 kW
Post by BoomerChomsi » Jul 14 2015 11:14am
Yup I agree with you.
I think I have to be more specific, I am talking about Crystalyte HT and HS series.
I have modded these motor before using them, even than they don't last long.
E.g. axles are now worn out, nuts are broken etc...
Yup I have opened MXus 3000 V2 before using it.
I have done some mods first before.....playing with WOT :mrgreen:
I hope this motor last longer, looking at it I have faith in it 8)
Believe and Do
markz   100 GW
Post by markz » Jul 14 2015 2:18pm
Has anyone pushed the limits of this motor?
If its a nominal 3000w, and max is 6000w. Then at what point does this motor get hot.
Just wondering when I go to 72V battery and beef up the traces on my 18fet Low RDS Overclocker Ready 72V 65A, which would hopefully do 80-90A then Im at 6100-6500w. Has anyone rocked out in that range? I do plan on going with a smaller diameter moto wheel.
Allex   1 GW
1 GW
Post by Allex » Jul 14 2015 3:00pm
Well the motor will overheat even at 3000W depending on the use.
markz   100 GW
Post by markz » Jul 14 2015 3:35pm
I've seen several videos on youtube, and no one seems to get it screaming hot.
The controller gets hot before the motor.
zener   1 kW
Post by zener » Jul 14 2015 3:41pm
It also depends on Ambient temp.
Doctorbass   100 GW
Post by Doctorbass » Jul 14 2015 4:49pm
markz wrote: The controller gets hot before the motor.
It depend on the motor winding...
Low turn count.. ex 3T and 4T will make the controller hot while the motor will stay warm
High turn count..ex 5T or 6T will make the controller warm while the motor will become hot.
a simple thumb rule by experience :wink:
Doc
Samd   1.21 GW
1.21 GW
Post by Samd » Jul 14 2015 6:52pm
I'm getting requests to unecessarily upgrade things because of your comments above Doc. Everyone is entitled to their view.
But a lot of noobs don't realise what you are suggesting I think. The extra ! marks also get them twitchy.
Can I temper it with the fact that you're running ten kilowatts?
I actually think these motors are fine out of the box for 90 percent of people and I think people would be surprised at what the stock phase wires and bearings can do.
I also feel confident that the axles are holding up better than the infamous cheese ones from clyte and needs to also temper the view of modifying a Mxus.
Sam
madin88   1 GW
1 GW
Post by madin88 » Jul 15 2015 2:45am
markz wrote:Has anyone pushed the limits of this motor?
Its simple: if the windings get above 100°C than i would call it hot.
Im no friend of talking about watts in this case. its about phase amps!! As example 1000W at low RPM can make it even hotter as 3000W at high RPM.
The really interesting thing would be to know at what torque levels the core starts to saturate. Or with other words at what point the relation between amps and torque output discontinues to be linear.
Justin did some tests with 9C motors (unfortunately i don't have the link to the thread) and after i did extrapolate it to 45mm wide mxus stator i found out this point probably is at about 120A (4T winding).
This depends on the kind of iron the core is made, so the saturation point also could be lower or better.
Samd wrote: I'm getting requests to unecessarily upgrade things because of your comments above Doc. Everyone is entitled to their view.
It is not about problems that may occur when running it far beyond for what its made for. The real PROBLEM is the BUILD QUALITY!
summarized known issues:
- loose single strands / windings
- gaps between magents, broken off edges
- poor stator lamination assembly with rough and uneven surface
- hall sensors not at the right place (the one in the middle that is placed between two teeth) -> i think this will worsen performance and efficiency
- poor sealing
- 10kW belt drive with Neumotor 8057: [url]viewtopic.php?
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
litespeed   100 kW
Post by litespeed » Jul 15 2015 6:33am
My halls sensors went out on the first ride and my motor didn't get over 130 degrees Fahrenheit. Luckily I bought extra genuine halls from Digikey on my last order that I made for my capacitor dischage welder. Was simple to do but I can definitely call that pour quality or maybe just bad luck? The Doc is right about the higher turn motors (6T) getting hot and the controller only getting warm. I probably should have gone with a 5T or 4T.
Tom
