XPD: open-source keywin e-bike lab replacement
redline2097   100 W
Re: XPD: open-source keywin e-bike lab replacement
Post by redline2097 » May 22 2017 2:09am
What could be wrong with my 18Fet infineon KH618 controller. I have been succesfully flashed it with xpd-ebike program many times. Now I tried the original chinese programming software, cause I read it was more solid. The programming went fine but I accidentally turned to throttle regen on. Now when I try to flash the controller I can't succesfully do it. Any of these programming softwares won't flash or even read. I tried new USB-TTL adapter but without luck. Also it halts now on high speed regen. Any help?
methods   10 GW
10 GW
Post by methods » May 22 2017 7:36pm
From road
Multiplexed pins
Timing is critical
Documented well
You need to "poke it"
-methods
(Programming pins are multiplexed - so serve a different purpose after boot. Get it before it boots)
Increasing battery voltage and controller current limit will result in a non linear experience
methods   10 GW
10 GW
Post by methods » May 22 2017 7:38pm
Read back one page.
Disconnect accessories that short that pin set
redline2097   100 W
Post by redline2097 » May 24 2017 12:31pm
I have disconnect every other cable than battery and program cable. It does not program.
redline2097   100 W
Post by redline2097 » May 24 2017 12:33pm
methods wrote:From road
Multiplexed pins
Timing is critical
Documented well
-methods
I didn't get it. Can you explain better please. :)
methods   10 GW
10 GW
Post by methods » May 24 2017 1:01pm
Please focus hard and try to remember everything that changed between when it worked and when it did not.
Something changed....
There is the PC interface and how the USB dongle maps to your COM ports.
There are drivers... Did you install this Chinese software? Perhaps it stepped on your XPD install.
Did any events happen to trigger this work like reverse polarity or poor performance
(FYI whatever software you use... Makes little difference... As the variables can only change within a fixed range)
Did you see any water or rain?
I would focus first on the UART COM port... Perhaps manually set it to 3
Try the software with no connection at controller... Behave differently?
Try the software with no connection at PC... Behave differently?
Did the cable get yanked? Pins bent? Use a DMM to test the signals.
I always like to throw it out the front door into the bushes, wIt 20 minutes to an hour, then start over from scratch.
Good luck
-methods
methods   10 GW
10 GW
Post by methods » May 24 2017 1:04pm
Looks like you are opening and closing controller.
This stresses cabling
Inspect extra close for open and short
DAND214   1 GW
1 GW
Location: About 1200 miles south of Chicago, in sunny/rainny Port Richey, Florida!
Post by DAND214 » May 24 2017 9:50pm
I'm not familiar with that software but do you have to connect the battery to program it? I don't with Kewin's software.
Dan
methods   10 GW
10 GW
Post by methods » May 24 2017 10:01pm
Any dongle that powers the 5-volt buss should not require power from the controller.
Batt voltage down to 12V down to 5V
That said you can run into brown-out issues... if your buss has a heavy load and your dongle can't source the current.
-methods
Edit:. Dated info... These days chips may run on other than the 5V buss....
Green Werks   10 W
Post by Green Werks » Jun 13 2017 12:22pm
redline2097 wrote:What could be wrong with my 18Fet infineon KH618 controller. I have been succesfully flashed it with xpd-ebike program many times. Now I tried the original chinese programming software, cause I read it was more solid. The programming went fine but I accidentally turned to throttle regen on. Now when I try to flash the controller I can't succesfully do it. Any of these programming softwares won't flash or even read. I tried new USB-TTL adapter but without luck. Also it halts now on high speed regen. Any help?
would you know the shunt value for this KH618 controller
any help would be great
teslanv   100 MW
Post by teslanv » Jun 13 2017 12:37pm
GW, where are you located?
Shunt Value is probably around 0.90 mOhms to 1.50 mOhms. Usually that means you have to set the current waaaay lower than IRL. (i.e. program to 50A to get 100A Actual output)
You can test the rShunt value yourself, if you have a iCharger, or even a stable current and observe the voltage drop, then do some math.
If you don't have an iCharger, take a 12V battery/power supply/source, and wire a 12V Light bulb in the circuit, and measure the current draw on this. (Let's say it's 1.3 Amps)
Then run the circuit through light bulb and through the controller (as described in the video below), and measure the voltage drop. Say it's 1.60 millivolts (0.0016 Volts)
Then calculate the rshunt resistance: Resistance = Voltage drop/Current or 0.0016 V/1.3 A = 0.001231 Ohms (1.231 mOhms)
DD Hubs, Batteries, Controllers & Custom Ebikes.
http://westcoastelectrics.com
West Coast Electric Cycles
Bellevue, WA
USA
Green Werks   10 W
Post by Green Werks » Jun 13 2017 1:53pm
Thanks For getting back I am located in Ohio
If I could pick your brain for a second that would be great
I have a ERT 18 fet sine wave controller
Do you know who makes these it came with no shunt value
I am trying to get a grip on how to tune it for what I need
I have a 52v 24ah battery 50 amp continuous 70 amp burst GA cells
I also have a CA
the motor is a Edge 1500w DD 2600w max
where would you recommend that I set max amps on the controller and the CA
Thanks in advance for any input
teslanv   100 MW
Post by teslanv » Jun 13 2017 2:21pm
Green Werks wrote:Thanks For getting back I am located in Ohio
I also have a CA
The rShunt Value will depend on the amount of solder, blobbed onto the board, so I can't say with any certainty, without taking the actual measurement as noted above in the video. You could set it to 1.25 mOhms as a rough guess and probably be kinda close.
ERT is evolutiongts' company. I would ask him if he has more info.
For settings, I'd program it for 40A battery and 80A Phase in the software, and see if that works for you.
Those GA cells are not ideal for high current draw, so keeping your full power sprints to a minimum will keep your battery healthy.
Set your CA to 60A limit.
Bellevue, WA
USA
Green Werks   10 W
Post by Green Werks » Jun 13 2017 2:48pm
Thank you very much
I was thinking on those lines
I was running the 12 fet version of this controller but it was getting hot
I switched to the 18 fet set up and It runs ok but I want to learn what is really going on
the 12 fet program is set to 50.2 amps and phase current limit at 125 amps
the 18 fet program is set to 50.0 amps and the phase current limit to 150.9 amps
I have the CA set at 50 amps max
I would like to alter the 18 fet program but I have had no luck
any thoughts on this would be great
teslanv   100 MW
Post by teslanv » Jun 13 2017 3:19pm
Green Werks wrote:Thank you very much
Maybe a bad/incompatible programming cable.
Here's what you need for these controllers:
Program Cable to controller.jpg (182.19 KiB) Viewed 9286 times
Bellevue, WA
USA
Green Werks   10 W
Post by Green Werks » Jun 13 2017 3:33pm
Thank you so much again
I have that set up it came with the controller
The problem is I can alter the program in edit mode but when I load it
the controller wont work
I have to reload the stock program back in then it works again
I was a little concerned about the 150.9 phase current limit
and wanted to drop it down to the 125 amp phase current limit setting on the 12 fet
what say you
jerome_speedy   10 mW
Post by jerome_speedy » Jul 16 2017 7:09am
Hi all,
I tried to use the XPD program, which seems so much more simple to use than the Keywin software, but I have several problems....
First of all, my Xie Chang controller (supposedly on ver 6, which infineon number does it equate to ?) was delivered with a 5 pin MALE JST plug, which is unsual
Also, my USB-TTL cable, bought from Lyen, doesn't have the same colour order from the picture 2 posts before,and the cable loop is not on the same pin number, which is a bit puzzling.
As for the software itself, XPD used under Linux runs well but didn't recognize my controller (not surprising given the wire problem discussed above).
On Windows XP, XPD 3.3 doesn't even start, although all the packages from Sourceforge were installed (Python 2.7 is in the programs menu and the programs launchs).
Any suggestion ? I only want to program the regen braking on my controller, nothing more ! Thanks
parabellum   10 MW
Post by parabellum » Jul 19 2017 11:51am
jerome_speedy wrote:As for the software itself, XPD used under Linux runs well but didn't recognize my controller (not surprising given the wire problem discussed above).
Did you give all permissions to related /ttyUSB ?
jerome_speedy   10 mW
Post by jerome_speedy » Jul 21 2017 10:05am
It's not a permissions issue, I run XPD in sudo mode. It's just that the program waits forever that the controller is connected to the USB port, whereas it is already ! I pushed the USB-TTL switch for 10 secs but to no avail.
anpaza   10 W
Post by anpaza » Jul 23 2017 10:48am
New version for public testing: 0.4.1 alpha.
Download here.
New features:
* Implemented KHxxx (AKA Infineon 4) controller support.
* Implemented profile downloading (EB3xx and KH6xx)
* XPD for Android (from scratch in Java) (not finished yet, so, no test builds for now)
Shalom_hadad   1 mW
Post by Shalom_hadad » Aug 07 2017 5:43am
Hi. Its very good option. But where I can buy controller?
Who it is this Lab?
vex_zg   100 W
Post by vex_zg » Aug 28 2017 11:44am
I'd like to get my hands on a 12/18FET programmable controller - but it's a bit unclear where to get it and which ones are programmable?
alsmith   100 kW
Post by alsmith » Aug 30 2017 8:28am
vex_zg wrote:I'd like to get my hands on a 12/18FET programmable controller - but it's a bit unclear where to get it and which ones are programmable?
looked in items for sale section?
get in touch with Powervelocity- lots of posts
https://endless-sphere.com/forums/viewt ... 31&t=75888
also website at http://www.Powervelocity.com
vex_zg   100 W
Post by vex_zg » Aug 30 2017 2:48pm
yep contacted the velocitypower guy for purchase, I admire his endeavour, this is exactly what we need.
Still would be nice to have some cheap controllers which I can push over the edge, reprogram and won't cry if I fry them. I cry when I fry something over 100$.
alsmith   100 kW
Post by alsmith » Sep 06 2017 12:56pm
The problem is that these are not mass production items- you'd need something that is mass produced then you lose the nice things such as that programmable settings can be customised to your individual desires. You can get lower priced controllers closer to your vision but you get what they make and that's it- no customising to your needs. Controllers are available at under $100 if that's what you want- try here for around $70 and less.
How about an 18 FET controller for around $35? (guess price- I see them in UKP £), that's got to easily be under your throwaway consumer vision?
Electric Bicycle Brushless Motor Controller 48V 1500W 18 Fets For E-bike&Scooter Hot Sale
or
Me? I prefer the support that you almost certainly will not get with the above.
(demonstrated by the support I've had from vad/power velocity for my questions about my existing controller to add Bluetooth programming to my setup since he first posted info that he was working on it. btw I just ordered the parts today!
When I started out with my ebike I got absolutely loads of advice and help from Ed Lyen, and his service was excellent. That wouldn't have happened if I'd bought from an ebay or aliexpress supplier. He made sure I got something that met my needs as well as educating me- I owe him a lot. Vlad has that same approach. The ali/ebay suppliers will just want your money- I learned that from a 20Ah 18650 celled battery that I eventually identified as only 12Ah. )
