*** Controller Information Links ***
Locked
Ypedal   100 GW
Post by Ypedal » Jun 25 2010 6:13am
If you post links in here, pls keep it clean and to the point, no chit chat ( it will be kept as clean as possible and to the point :wink: )
:D
Known to Work Brushless Motor/Controller Wiring Diagrams
http://www.endless-sphere.com/forums/vi ... f=2&t=6241
Instant Start 18 fet Infineon Boards are here...
http://endless-sphere.com/forums/viewto ... 12&start=0
Methods 100V 100A Programmable Regen Controller
http://www.endless-sphere.com/forums/vi ... =2&t=13638
24 Mosfet Controller XJC8b116 microchip Information Thread
http://www.endless-sphere.com/forums/vi ... =2&t=14798
Infineon XC846 72V 45 Amp Controller
http://www.endless-sphere.com/forums/vi ... f=2&t=5713
How to miller platau match mosfets
http://endless-sphere.com/forums/viewto ... 94#p763094
Added by Steveo....
Infineon EB2 Series software download (hacked by zombies .. Thank you)
http://endless-sphere.com/forums/viewto ... 01#p718101
Infineon EB3 Series software download (hacked by zombies .. Thank you again!!)
http://endless-sphere.com/forums/viewto ... 22#p752384
ES site status page:
novembersierra28
Re: *** Controller Information Links ***
Post by novembersierra28 » Sep 16 2010 10:29am
Paul and Sabrina's DiY Brushed Controller Diagram for those Warp 11" / Kostovs
http://ecomodder.com/forum/showthread.p ... -6404.html
nebriancent   100 W
Post by nebriancent » Apr 04 2012 12:41am
a doc I found on the Infineon controlers a copple of years ago I'm not sure who wrote it and I can't remember where I found it but it dose have some hardwere mods and links to programs needed to flash them
Infineon doc.doc
(1.74 MiB) Downloaded 2126 times
The same document in pdf
Infineon doc _1_.pdf
(1.97 MiB) Downloaded 1758 times
if at first you don't succeed...dont force it just grab a bigger hammer
back to my gm 901 for now 26"
modified infineon ebikes.ca 40-100a 36-72v controller w/ cruise http://endless-sphere.com/forums/viewto ... =2&t=37068
4s 14p liMn (doc makita pack) and headway 2p 10s in serries
cycle anylist 2.3
top end on flat is about 48kmh hot off the charge
range >40km
best distance in a single charge about 75km
xvision front light. led marker light rear w/ limiting resistor for tail/stop operation
jateureka   10 kW
Post by jateureka » Jul 15 2012 9:29pm
E-bikes: Bafang 8FUN; Mac; Ezee; FreeGo; Aprilia 7s LiPo; eLation V2; TerraTrike recumbent
E-motorbikes: ZEV 7100 LR scooter, 84V 60Ah LiFePO4.
ZERO 2011 S motorcycle, 51.8V 70Ah LiMno2, 2012 headlight, Kilovac EV-200 contactor
E-mower: EGO 56V mower & line trimmer
jateureka   10 kW
Post by jateureka » Jul 24 2012 7:20pm
KU Series controllers info (sold by BMS Battery)
KU63 circuit schematic, current limit mod and other info http://www.avdweb.nl/solar-bike/electro ... oller.html
KU63 mod http://www.endless-sphere.com/forums/vi ... hilit=ku63
KU63 component vopltage info http://www.endless-sphere.com/forums/vi ... hilit=ku63
KU63 versus KU65 & comments regards 3 speed switch http://www.endless-sphere.com/forums/vi ... 3&start=30
KU93 wiring battery/power http://www.endless-sphere.com/forums/vi ... hilit=ku93
Ku123 500W current limit mod info http://endless-sphere.com/forums/viewto ... =2&t=37853
KU123 3 speed switch http://endless-sphere.com/forums/viewto ... =2&t=29977
jateureka   10 kW
Post by jateureka » Oct 01 2012 10:32pm
eZee controllers
photo of pcb and some component details page 2 http://endless-sphere.com/forums/viewto ... 07#p645107
jateureka   10 kW
Post by jateureka » Oct 01 2012 11:32pm
jateureka   10 kW
Post by jateureka » Nov 23 2012 12:10am
Chinese Controller Tests (350W) discussion and page with links to web page with test results http://www.endless-sphere.com/forums/vi ... =2&t=45371
amberwolf   100 GW
Post by amberwolf » Jan 06 2013 4:54am
Locked
