pedal assist bypass no more available on Eu controller
stein   1 mW
Post by stein » Aug 30 2009 10:17am
Due to law restrictions here in Belgium(and I supose in the rest of europe) the 48,36 and 24V 20A controllers from crystalyte come without the possibility of disabling the pedal assist system now. This means you always have to pedle before the controller starts. This is very inconvenient for testing at home, and when you get tired of pedalling :). Also the pas system is way to slow to ride comfortable with.
The switch is still present, but in place of disabling the pas sensor it makes thotle 100% now. So you don't have to use the throttle anymore but we have to peddle.
Before I had an older controller, with the same lay out as in Canada. It broke down and I have gotn a new one under warranty. I had to leave the old one in the store for research so I can't see where the switch used to be wired to. Now I do not know where I have to solder to make pas sensor disabled again. Could anyone guide my with a picture where I should solder?
Also I thought it could be interesting for users in Canada to know where you can wire a switch on the controller to get throttle 100% all the time. You see the brown cables on the picture, that is how it is soldered. Onto diode5 and R11.
100%throttleoverview
100%throttlezoom
crystalyte48v20A
rkosiorek   1 MW
Re: pedal assist bypass no more available on Eu controller
Post by rkosiorek » Aug 30 2009 11:10am
just curiosity, what happens if you remove the jumper plug at "J6"?
rick
DISCLAIMER:
We will not be responsible for damage to equipment, your ego, blown parts, county wide power outages, spontaneously generated mini (or larger) black holes, planetary disruptions, or personal injury that may result from the use of this material.
- Samuel M. Goldwasser -
heathyoung   1 MW
Post by heathyoung » Aug 30 2009 9:25pm
PAS is usually just a magnet + reed switch combination, it needs to recieve pulses across it to function - what happens when you just bridge the connector?
GNG offroad build on Craftworks DHR with 12S2P lipo. Light, balanced, powerful, able to climb a tree.
Project Vectrii (2) - status - Finished. Nope. 38S Leaf cells are next. Now have 2 of them - Averages 50Wh/Klm
stein   1 mW
Post by stein » Aug 31 2009 12:29pm
Rick,
I think that was a verry usefull reply, I never payed attention to that jumper, but a short cut jumper is indeed always suspisious and means that an open jumper will propably do something else. I am going to try it right away. Will let you now what it does.
Thanks,
Regards.
Stein
stein   1 mW
Post by stein » Aug 31 2009 1:43pm
Ok Rick,
The answer was so right in front of me, that I couldn't see it. By removing the jumper, the pas was disabled.
Thank you a lott.
Stein
dnmun   100 GW
Post by dnmun » Sep 01 2009 12:21am
rick is DA MAN! great call.
rkosiorek   1 MW
Post by rkosiorek » Sep 01 2009 7:10am
i just got lucky. besides i always get curious when i see a jumper.
rick
DISCLAIMER:
317537   10 kW
Post by 317537 » Sep 01 2009 7:21am
Pas can not be disabled?
dOhhhh noesssssssss!
Leslie
