Settings for controller amp output?
Robbygohard   1 µW
Post by Robbygohard » Apr 18 2020 7:20pm
I'm running 72volt 20mah 60amp controller 50a continuous bms on my 3000watt hub my controller amp output is set at 12amps what's a safe amp out put for me to set the amp output ...
goatman   1 MW
Re: Settings for controller amp output?
Post by goatman » Apr 18 2020 8:06pm
depends on what your battery can handle. do you know what cells are inside. do you have good torque arms?
999zip999   100 GW
Post by 999zip999 » Apr 18 2020 10:27pm
Do you have a link for the battery ?
