Fork vibration with Mac hub motor
Jatem   100 mW
Post by Jatem » Aug 28 2019 1:27am
Is it normal for a front hub motor to cause the forks to oscillate/vibrate?
I have just installed a Mac front hub motor with a KT 36/48V sine wave 20a pswpower controller, and a em3ev battery. I'm using Surly Troll cro-mo forks. It pulls well at different levels of PAS, and generally rides as I'd expect. However, I'm concerned that it causes some vibration/oscillation in the forks. It sounds similar to this video ... https://youtu.be/aITlPe3-5SI?t=26
I was expecting a smooth motor sound, not the pulsing that causes vibration. The forks oscillate worst at low to mid current levels, and smooth out at high power/speed.
qwerkus   1 kW
Re: Fork vibration with Mac hub motor
Post by qwerkus » Aug 28 2019 4:55am
Sound like a controller issue. Mac hub are known to work only with certain types of controllers because of the high pole number. What wheelsize/speed are you riding? Are you using the open source kt firmware?
Jatem   100 mW
Post by Jatem » Aug 28 2019 1:31pm
I installed a 10t Mac on 26" and another Mac on a 29er. The resonance/vibration is worst at lower amperage when accelerating around 15-25 km/hr. The motors accelerate well and reach speeds of 40-45 km/hr, power usage seems ok. It's just this chuff chuff chuff noise that causes the tips of the fork to visibly vibrate back and forth, which I'm concerned will fatigue the fork or cause the axle nuts to loosen.
amberwolf   100 GW
Post by amberwolf » Aug 28 2019 7:22pm
If it's sensorless, then it's not uncommon to get a pretty severe shudder at startup from a stop, especially with significant weight vs the torque the motor has via the wheelsize it's in.
My SB Cruiser with a pair of Grinfineons presently in sensorless mode is horribly loud, almost like a really big truck that missed the gear change and the transmission is grinding gears ripping teeth off. :shock: Shakes the whole trike. Once it gets rolling it gets much quieter, and is just a normal trapezoid-controller sound.
The other possibility is there is a wrong phase/hall combination, if it's a sensored setup. It could be a false positive, where it spins forward like it should, but current draw is much higher than it should be. Test it offground and see what current draw is. Should be an amp or so. A false positive may show several times that.
AHicks   100 W
Post by AHicks » Aug 28 2019 9:00pm
I just set up a Mac 10t on a KT controller with sensors. It's smooth as silk right from a stop.
PSWpower does sell sensorless KT controllers, so I'm curious what you are running. With or without sensors?
Jatem   100 mW
Post by Jatem » Aug 28 2019 9:17pm
AHicks wrote:
Aug 28 2019 9:00pm
Great to hear you have a similar setup working well. Any settings you had to change to get it working well?
I'm using the KT36/48SVPR-20A controllers on both bikes. I can check the current draw, but they start and accelerate like I'd expect. It goes well, there's just a major resonance in the hub/wheel on both bikes at middle PAS levels and middle speeds under load.
It's in torque simulation mode, max current reduced to 13A.
I do only have one torque arm, wonder if that could affect it.
E-HP   100 kW
Post by E-HP » Aug 28 2019 9:40pm
Have you checked your rim to verify that it's trued? My wheel had that slight pulsating sound and the wheel needed truing, which smoothed things out once I tweaked to spokes. Tire being out of balance could also contribute, so maybe trying the motor with only the rim may provide some insights.
Jatem   100 mW
Post by Jatem » Aug 28 2019 9:49pm
I built the wheels from scratch, nice and true, used a spoke tension meter. It could be the tyres/balance, but it's a noticeable chuf chuf oscillation.
I tried swapping the 6 combinations of phase leads, and the combo I was using is the only good one. I swapped two leads on the hall sensors, and I found the best phase lead combo was running in reverse, with a similar vibration to my current forwards setup. I think this means I don't have a false positive.
Jatem   100 mW
Post by Jatem » Aug 29 2019 5:46am
Here's a recording of the hub with increasing throttle (and a bit of brake rotor rubbing)...
https://vocaroo.com/i/s118Pq576Ogs
neptronix   100 GW
Post by neptronix » Aug 29 2019 8:06am
It's very normal to get some oscillation through the front fork with a front hub. Moreso when aluminum is involved.
neptronix   100 GW
Post by neptronix » Aug 29 2019 8:09am
Jatem wrote:
Aug 28 2019 1:31pm
The axle nuts will loosen if you let them, by not using a torque arm.
Watching a front fork twist while i applied the throttle from a stall on my first front motor build spooked me out of using front motors forever. That and the lack of traction from putting the drive mechanism on the wheel that has the least weight on it.
AHicks   100 W
Post by AHicks » Aug 29 2019 8:21am
I'm using a heavier KT controller with the MAC 12t. It's a 12 mosfet rated for 35a max. I have it limited to about 1300w (+-) using the parameters over concern for the battery. Plenty of grunt available with that for my purposes.
It sounds like you have the color sequence figure out, but I'll show what I used so you can confirm.
Phase Firing order    Motor    Controller
A                    Blue          Yellow
B                    Green        Blue
C                    Yellow       Green
Hall sensors fire in the same order, so they match the phase motor/controller color sequence.
After listening to the sound recording, wondering if you're getting that same resonance when actually out riding?
E-HP   100 kW
Post by E-HP » Aug 29 2019 9:34am
Jatem wrote:
Aug 29 2019 5:46am
Wow. The tail end of that recording sounds like there's something mechanical going on, versus electrical.
Jatem   100 mW
Post by Jatem » Aug 29 2019 2:39pm
AHicks wrote:
Aug 29 2019 8:21am
A                    Blue          Yellow
B                    Green        Blue
C                    Yellow       Green
I used matching colours for the motor and controller, on all phase and halls. PSWpower have a diagram for my 20a sine wave controller showing the controller pins as A blue, B green, C yellow which matches the em3ev documentation.
The resonance is mostly there when riding PAS 1, 2 or 3 and at speeds up to about 25kmhr. At high power and speed it's much better.
There is a setting on the controller C2 which related to hall phase, with two settings 0 or 1. It isn't documented well, but if I turn that on it makes a grinding noise. I wonder if I should turn that on, and then test the 6 motor phase combinations?
AHicks   100 W
Post by AHicks » Aug 29 2019 3:37pm
All the notes I have are showing C2=0, but 1-6 are available. I've always used 0.
Odd that KT would use different firing orders on their colors from one controller to the next.
Jatem   100 mW
Post by Jatem » Aug 29 2019 4:27pm
AHicks wrote:
Aug 29 2019 3:37pm
Does your Mac have any oscillation, or is it completely smooth sounding?
I noticed that your wiring order is in the same sequence at as mine, just moved forward one step in the cycle. Eg. Bgybgybgy. They are probably just two of the three valid forward combinations, still in the same firing order as mine.
AHicks   100 W
Post by AHicks » Aug 29 2019 7:54pm
As mentioned, my Mac is smooth as silk right from a stop! It replaced a 1500w direct drive, and is no noisier than that was. Barely audible. Able to do an "all else being equal" 1500w direct drive vs. Mac 12t comparison, because that's literally all that was changed - if I don't count the added speed sensor and parameter settings.
Mac seems to be using less power as I don't find it necessary to switch to a higher PAS level as often. The torque of the gear driven MAC just kinda pushes right through the stuff the direct drive struggled with at low speeds - which is where I spend most of my time. Bottom line seems to be I have more torque available, while using less power. A real win-win.
Jatem   100 mW
Post by Jatem » Aug 29 2019 10:54pm
AHicks wrote:
Aug 29 2019 7:54pm
Is your KT 35A a sine wave controller? I wish my Macs would run as smooth as silk.
AHicks   100 W
Post by AHicks » Aug 30 2019 7:14am
Yes, Sine wave no doubt. Square runs with kind of a ring that would have been very noticeable when the direct drive was installed.
Jatem   100 mW
Post by Jatem » Aug 30 2019 3:36pm
AHicks wrote:
Aug 30 2019 7:14am
My Macs are using about 200w on the display with WOT and no load, around 40+km/hr, which suggests I don't have a false positive wiring combo. Might just be noisy motors, or noisy controllers.
E-HP   100 kW
Post by E-HP » Aug 30 2019 3:51pm
Jatem wrote:
Aug 30 2019 3:36pm
My Macs are using about 200w on the display with WOT and no load.
Wow, thats a lot a power for no load!!! Seems like a hall/phase issue.
AHicks   100 W
Post by AHicks » Aug 30 2019 6:51pm
Just went out and checked mine. It's floating between 50 and 60w at WOT. Noteworthy possibly, is that the max amperage has been limited to 1300w or so in the parameters.
Jatem   100 mW
Post by Jatem » Aug 31 2019 12:26am
AHicks wrote:
Aug 29 2019 8:21am
A                    Blue          Yellow
B                    Green        Blue
C                    Yellow       Green
Changed to your wiring order, and it's using about 60-110w according to the LCD8 at WOT no load. It seems a bit smoother.
I think there's some resonance happening around 20-25km/hr with the fork, mudguard, tyres. Might try balancing the tyre with some weights, see if that makes a difference.
Thanks for the suggestions!
AHicks   100 W
Post by AHicks » Aug 31 2019 8:34am
My tire seemed way out of balance while running it to check the wattage for you last night. It's not something I notice while riding though. I'm running some sort of snot in the tube for flat prevention, am figuring that's what was causing the seemingly way out of balance while spinning it up.
Point being, wondering if you notice any difference in the resonance while actually riding it?
Jatem   100 mW
Post by Jatem » Aug 31 2019 4:07pm
On the 26" cargo bike, it's really wobbling the fork tips back and forth at 20-25kmhr while riding along. It smooths out after 30kmhr. I'd rather not have the vibration causing the wheel to come loose or the forks to fail.
