Would you be able to tell the winding rating?
ebike11   100 kW
Post by ebike11 » Jul 19 2019 12:11pm
Hi guys
Would anyone have a fairly good idea of the winding of this qs205 motor? I dont see any stamping/markings
https://ibb.co/JvmXCmG
https://ibb.co/L9tSz7V
https://ibb.co/Sykf46z
https://ibb.co/nn33FnF
https://ibb.co/sWYH8rk
flat tire   1 MW
Re: Would you be able to tell the winding rating?
Post by flat tire » Jul 19 2019 12:23pm
QS motor says don't exceed 120C indicated by an internal probe. A rule of thumb for "how good is x" is that in a commercial product, "x" won't be any better than it needs to be, and often is worse than it should be.
ebike11   100 kW
Post by ebike11 » Jul 19 2019 12:45pm
flat tire wrote:
Jul 19 2019 12:23pm
I see.
Is there any noticable way to know if its a 3T 4T 5T etc...? I dont know all the versions that they have
flat tire   1 MW
Post by flat tire » Jul 19 2019 1:01pm
"Winding rating" will be taken to mean max temperature. Are you using a translator?
I'm not sure how the winding count works on that motor since each winding occupies multiple stator slots. But someone else could tell you how to count them and find out the winding count.
ebike11   100 kW
Post by ebike11 » Jul 19 2019 1:10pm
flat tire wrote:
Jul 19 2019 1:01pm
Ah sorry i didnt know the exact term.
I mean "turns"
ferret   1 kW
Post by ferret » Jul 19 2019 3:15pm
If you measure the resistance between the phase wires, someone here could probably tell you which winding you have.
Avner.
Don't believe everything you think.
Cove GNG-Spot build thread
Astral Rune build thread
neptronix   100 GW
Post by neptronix » Jul 19 2019 4:34pm
The easiest thing to do would be to spin it up and measure the RPM, turn that figure into kV, and compare with what's listed as their kV per winding. A $10 ebay digital laser tachometer does the job here.
ebike11   100 kW
Post by ebike11 » Jul 19 2019 5:05pm
neptronix wrote:
Jul 19 2019 4:34pm
I read the less copper the lower the TURN count...maybe i can find other qs205 gut pics to compare to in order to get an estimate
neptronix   100 GW
Post by neptronix » Jul 19 2019 5:16pm
ebike11 wrote:
Jul 19 2019 5:05pm
That's not the case for how most motors are designed. A different turn count is typically the same copper fill, but with more strands of a thinner wire, or less strands of a thicker wire.
ebike11   100 kW
Post by ebike11 » Jul 19 2019 7:21pm
neptronix wrote:
Jul 19 2019 5:16pm
ebike11 wrote:
Jul 19 2019 5:05pm
Ok thx for that..i understand. Would there any other way to determine the turn of the motor? The qs205 has many different turn counts
j bjork   10 kW
Post by j bjork » Jul 26 2019 11:55am
If you know what kind of motor you have, you can probably count the number af strands and compare with the number of strands of the different windings avalible for that motor.
Here it is for the 205 50H:
https://www.aliexpress.com/item/3291120 ... 8015.pic_1
larsb   1 MW
Post by larsb » Jul 26 2019 2:22pm
it really looks like a 2turn in the pics. look at the bundles.
Skärmavbild 2019-07-26 kl. 21.29.24.png (442.13 KiB) Viewed 495 times
why do you want to know?
I think there's a marking on the other side of the stator.
Which width of stator is this?
Ride on!
eee291   100 kW
Post by eee291 » Jul 26 2019 3:01pm
I don't think it's a 2T, looks like a 3T if you look at the top right.
larsb   1 MW
Post by larsb » Jul 26 2019 3:23pm
i'll bet you 1eur that it's 2T :D :D
deal?
Ride on!
eee291   100 kW
Post by eee291 » Jul 26 2019 3:56pm
Make it 5€
larsb   1 MW
Post by larsb » Jul 26 2019 4:10pm
Ok, it's on. :D
You must promise to not bribe ebike11 with 2 Eur to say it's a 3T
Now the big question: which stator is it? Measure the magnets width, it's from 28mm to 50mm according to the table in the link.
If you find the marking then this might help:
Ride on!
