60V E 300 Hub Motor Project Underway
detrailers   10 W
Post by detrailers » Mar 19 2019 9:34pm
Greets all. I'm getting ready to build a batt for my Hyper Racing scooter. Currently its a 16s which gives me a max V of 67.2. Hyper advertises these as 60v. Would it be ok to overvolt to 17s or would I possibly damage the controller or motor
Modded Hyper Racing 2000w
60V E300 Hub Motor - LI Conversion
billvon   1 GW
1 GW
Re: Overvolt OK?
Post by billvon » Mar 19 2019 10:08pm
detrailers wrote:
Mar 19 2019 9:34pm
Most controllers rated for 60V are rated that because they use 60V FETs and 63V capacitors. Or perhaps 75V FETs for margin. You'd have to open it up and look at the components. You care about the input caps, the FETs and the housekeeping regulator; those are the three things generally exposed to full battery voltage.
--bill von
dogman dan   100 GW
Re: Overvolt OK?
Post by dogman dan » Mar 20 2019 6:18am
Yeah, you might be best to look into a new controller once you do go bigger, and then go for 72v at least. Get into the range where you get the fun of melting motors. 8) Assuming of course, the races are not over 10 miles, or 40 min of time.
detrailers   10 W
Amp Draw
Post by detrailers » May 06 2019 8:50pm
Bought this kit to upgrade my E300, does anyone know what I could expect as far as amp draw for the 60w unit
https://s.click.aliexpress.com/e/brhZuayo
TommyCat   1 kW
Re: Amp Draw
Post by TommyCat » May 07 2019 9:30am
:lol: Caught me looking to see a 60 watt motor. Now who would want that I ask myself... :lol:
But a 60 volt, 1000watt motor...
Watts= Volts times Amps
So Watts divided by Voltage is the amperage.
So Amps would be ~16.7. This is at your battery's nominal voltage.
See my completed Magic Pie V5 rear hub E-Bike build Here!
detrailers   10 W
Re: Amp Draw
Post by detrailers » May 07 2019 10:14am
lol thats what i meant thx Tommy
detrailers   10 W
Post by detrailers » May 30 2019 8:45am
Dropped pan 2" to accomodate bigger batt and controller, still have 2" ground clearance. Also had to rework rear frame upright to accommodate disc and cally. Next up ill be making the mount for caliper and welding up unused holes and then final weld and grind and off to powdercoat.
pattyballs   10 mW
Re: 60V E 300 Hub Motor Project Underway
Post by pattyballs » Jun 04 2019 2:32pm
How do you like that hub motor? I have one on the way too!
detrailers   10 W
Post by detrailers » Jun 04 2019 4:00pm
Mine arrived slightly damaged and missing brake cable and throttle plug was incompatible with controller plug. Bought it from vendor on AliExpress and fortunately got a partial refund because Ali does cover your ass. Haven't had a chance to hook it up yet but was finishing the fab on the frame today and will be going to powdercoat soon....
detrailers   10 W
Post by detrailers » Jun 11 2019 6:40pm
Metal work done. Added a gusset for the brake mount since kinda need brakes.... welded up un used holes, stripped and off to powder coat...
detrailers   10 W
Quick but too quick!
Post by detrailers » Oct 13 2019 4:53pm
Greets,
My 60v lipo hub motor conversion is almost done. One thing, it is too quick off the line, I'm thinking maybe it's the thumb throttle, seems like about a half inch of nothing when you push it and then bam!
Would a twist throttle maybe be a bit more manageable??
Bluefang   10 kW
Re: Quick but too quick!
Post by Bluefang » Oct 13 2019 7:00pm
Unlikely to be the throttle, can check by putting a multi meter on the signal wire and ground for the throttle you should have a voltage that changes from about 1-4V over its full travel. If its a smooth change from 0-100%, not the throttle.
Most likely issue is just a cheaper controller and high power do not mix for fine control. If you want to significantly improve the control a Kelly controller is a great option.
Building high powered electric vehicles.
http://www.facebook.com/ausemoto
Goldenmotor dealer in Queensland, Australia.
detrailers   10 W
Post by detrailers » Oct 13 2019 7:04pm
Thanks. Hopefully they have one the exact dims lol
flat tire   1 MW
Post by flat tire » Oct 13 2019 7:34pm
Twist throttles are the standard for high power 2 wheelers. Better than thumb in general.
BUT, two main points:
1) you are using a speed control, not torque control, mode in your controller. It is known for exactly this type of behavior. There's likely nothing you can do to fix this part but get another controller. It's worth it. Torque control propels you with the force proportional to how far you pull back. So a little throttle off the line is a very smooth, leisurely start and full throttle will send the bike flying! The best of both worlds!
2) You can reduce phase current. Unless your controller really sucks it should allow you to program this value. NOT battery current.
john61ct   100 GW
Post by john61ct » Oct 13 2019 8:15pm
CAv3 gives you very precise user-custom control over ramp-up ratios for whatever throttle type you choose.
Much better than the tuning available from most controllers, and without messing with their overall torque vs speed optimizations.
detrailers   10 W
Post by detrailers » Oct 13 2019 8:47pm
Great info guys thx....should I try a twist grip throttle first??
Who makes the CAv3 & typically how much do they run
john61ct   100 GW
Post by john61ct » Oct 13 2019 10:12pm
detrailers wrote:Great info guys thx....should I try a twist grip throttle first??
Grin https://www.ebikes.ca/product-info/cycle-analyst-3.html
$120?
detrailers   10 W
Post by detrailers » Oct 13 2019 10:15pm
Those are really cool but I have 0 space left to add that
fechter   100 GW
Post by fechter » Oct 13 2019 11:22pm
It would probably be a lot better if you didn't have as much 'dead zone' in throttle. The very first part of the throttle is less sensitive but if the motor only starts when you are at 1/3 or so, it will be very sensitive and twitchy. Depending on the throttle style, you can place a trimmer resistor in series with the ground line and dial in the start point of the throttle. I've done it on a couple of scooters and it made all the difference.
tolkaNo   100 W
Post by tolkaNo » Oct 14 2019 6:44am
Yeah fechter is right its too much dead zone, you need to adjust the input voltages which almost no-one does
Even cheap throttles work really well when the input voltages are adjusted properly
You can do it with resistor on the ground line of the throttle (beginning dead zone) and resistor on the power line (end dead zone)
Or you can do it through a CA
fechter   100 GW
Post by fechter » Oct 14 2019 12:13pm
Here is a schematic of how to install the trimmer pot:
You can use a higher value pot like 1k but the final value is usually around 150 ohms. It's best to use a 10-turn pot but you might get by with a single turn.
Hall Throttle Zero Trimmer.jpg (18.62 KiB) Viewed 1596 times
Here's a picture of an install. You can put tape or heat shrink over the pot when finished.
Throttle smoother.jpg (58.28 KiB) Viewed 1596 times
When adjusting, be sure to have the wheel off the ground as the motor may start without giving throttle. To adjust, start with the pot at zero ohms, then slowly adjust until the motor just starts moving, then back off a little to make sure it stops when you let off the throttle.
flat tire   1 MW
Post by flat tire » Oct 14 2019 5:13pm
Dead zone has little or nothing to do with this guy's issue, but if he wants to change it the CAv3 will do that without ghetto electronics mods.
Furthermore, slow ramps really suck. You should have the thrust you want, when you want it--not the thrust you don't want, AFTER you request it. I totally agree that he needs a Cycle Analyst but not to screw with his ramp rate.
j bjork   10 kW
Post by j bjork » Oct 16 2019 8:50am
Maybe a Nucular 12 fet controller?
detrailers   10 W
Post by detrailers » Oct 20 2019 1:09pm
Yes I want to power and I asked for it but not so that it hits so hard it makes the scooter un rideable standing up...
Unfortunately I built the scooter around the current controller and switching controllers would be very difficult, if it would even fit so a "ghetto mod" really might be the only practical choice....
flat tire wrote:
Oct 14 2019 5:13pm
I Dead zone has little or nothing to do with this guy's issue, but if he wants to change it the CAv3 will do that without ghetto electronics mods.
detrailers   10 W
Post by detrailers » Oct 20 2019 1:11pm
I can do this, rookie here so where do I get a pot, what's it's real name and rating, and how do I adjust it. Hard to see in your pic but what wire is that connected to...dont understand schematics too well but looks like it's on one wire.
fechter wrote:
Oct 14 2019 12:13pm
